Mystical Ball - Uncover the Mysteries
  • Thread starter darkar
  • Tags
    Ball
In summary, this ball is able to predict the outcome of simple math problems based on the numbers you input. It works by subtracting the sum of the two digits of the number you are trying to predict.
darkar
187
http://www.mysticalball.com/
this is weird, it turned out to be quite accurate when i play with it.
How? How they do tat? Any theory behind this?
Its simple maths. If you do the sum it gives you, there are realatively few answers that it can give, and all these answers are assigned the same symbol on the chart, and then brings up that symbol when you click it.
Try working out more than one number before you click on the ball, and see if they all come up as the same symbol.
An even simpler way to root out the trick here is to try the same number several times in a row. Try doing the example (23) several times. Your answer is always 18. But do you notice anything odd? On any given try, 18 in the chart is always the symbol that appears in the ball.
The key then is to realize that, no matter what initial number you picked, only certain answers will apply:
Code:
99 : 9+9 = 18 : 99-18=[B]81[/B]
98 : 9+8 = 17 : 98-17=[B]81[/B]
97 : 9+7 = 16 : 98-16=[B]81[/B]
96 : 9+6 = 15 : 98-15=[B]81[/B]
90 : 9+0 =  9 : 99-9 =[B]81[/B]
89 : 8+9 = 17 : 89-17=[B]72[/B]
88 : 8+8 = 16 : 88-16=[B]72[/B]
80 : 8+0 = 8  : 80-8 =[B]72[/B]
Note that both 81 and 72 are the same symbol, as are 63, 54, 45 etc. This repeats all the way down to 0.
No matter what initial number you choose, it is going to result in one of those few special answers.
It's basically just a computerized version of one of the old stage 'mind-reader' tricks.
Uh well, sure, but that doesn't really explain anything does it? :uhh:
Blindingly obvious. You have a two-digit number, xy in digit form. You substract the sum of the two digits,
xy - (x + y) (xy means two digits, not multiplication)
=(xy - y) - x
=x0 - x
=x * (10 - 1)
=9 * x
qed
So the only possible numbers are 9, 18... 81, and they all have the same * symbol.
I didn't have to explain anything. I was just elaborating upon your post. :tongue:
What is the purpose of the Mystical Ball?
The Mystical Ball is a tool used for divination and seeking guidance. It is believed to have mystical powers that can reveal hidden answers and insights.
How does the Mystical Ball work?
The Mystical Ball works by tapping into the subconscious mind of the person asking the question. It uses a combination of symbols and patterns to trigger the brain to find answers and make connections.
Is the Mystical Ball accurate?
The accuracy of the Mystical Ball depends on the person using it and their ability to interpret the symbols and messages. It should not be used as a substitute for professional advice or decision making.
What kind of questions can be asked to the Mystical Ball?
The Mystical Ball can be asked a wide range of questions, from personal and spiritual matters to more practical and mundane ones. However, it is important to keep in mind that the answers should not be taken as absolute truth.
Can anyone use the Mystical Ball?
Yes, anyone can use the Mystical Ball. However, it is important to approach it with an open mind and a healthy dose of skepticism. It is not a magic tool and should not be used as a substitute for critical thinking and rational decision making.
  • DIY Projects
  • Classical Physics
  • General Discussion
  • Set Theory, Logic, Probability, Statistics
  • Quantum Interpretations and Foundations
