Calculating Galaxy Coordinates to Avoid Star Misplacement
  • Thread starter Daminc
  • Tags
    Galaxies
In summary: If you could do this, whatever star coordinates you place in would automatically display what galaxy it is part of.
Daminc
39
Thank's to the help I've received here I've created rules to turn the polar coordinates into cartesian coordinates but, say I had the coordinates for the galactic centre for Andromeda and the Milky Way and I also had coordinates for certain stars. I want to put a limit on my database that not allow me to accidently place a star that should be in the Milky Way into the Andromeda galaxy.
The way I see this would be to create a rule that:
Andromeda galaxy=
X coordinate +/- a
Y coordinate +/- b
Z coordinate +/- c
and the same for other galaxies.
If I could do this, whatever star coordinates I place in would automatically display what galaxy it is part of.
Any ideas about how I could find/calculate the boundaries?
I think this data might help but I'm not sure:
http://www.maa.agleia.de/Cat/Vol1/Constell/constell.doc
and
http://www.maa.agleia.de/Cat/Vol1/Constell/eq2000.dat
all of the polar coordinates I've found for the stars in Andromeda so far do not have the distance which is a problem :(
Astronomy news on Phys.org
Well, the database you linked actually describes the boundaries between constellations -- the imaginary lines drawn on the sky to separate what astronomers, by convention, call the constellations. These boundaries have no physical meaning and have nothing to do with a star's parent galaxy. Perhaps you are mistaking the constellation Andromeda for the Andromeda Galaxy, a large galaxy which just happens to be in that constellation.
The bottom line is that all the stars you see in the night sky are in our own galaxy. You'd need a pretty good telescope to pick out individual stars in the Andromeda galaxy.
Seeing as I have no idea where you've gotten your datasets, or what they actually mean, I can probably do little to help you. You may want to begin at the beginning, and tell us what you've done and what you're trying to do.
- Warren
OK, from the beginning...
A friend and I had an idea for an RPG (Role-playing game) and it grew and grew. It's been 6 years and it's in it's 4th edition.
Now, I love stats and Math, he doesn't. So when I proposed mapping out the stars I was given a blank look.
As with everything I started out with researching and I found lots of data with stella coordinates in the Polar format. I figured if I could convert them into cartesian coordinates I could calculate the distance between the stars for the purpose of travel time within the game. I've done that so that's no longer a problem.
Within my database I have different Galaxies (with the coordinates of their centres) as well as the type of galaxy they are in one table.
In another I have star coordinates(and there type).
I could just make them up but I'd rather have the whole mechanics based upon as much factual data as is feasible. Now, when I place a star into my database I want it to automatically select it's parent galaxy. To do that I need to know the boundary limits, in cartesian coordinates, of the galaxies I place into my database. Hence my previous post.
I love most things to do with science but I'm not an expert with any stretch of the imagination. And so, when I need an educated answer, I go to the only experts I know; which is the people here.
This project is going to take a long time, I know this, that's why I'm trying to link everything together as efficiently as possible at the beginning to minimise the errors in the future.
Hope you can help
Oh yes...
I do find this a bit confusing..
Chroot already answered this, or else you are using the words "galaxy" and "Star" incorrectly. Your small quote I used above is about placing a star in your database. Chroot already explained that every star you can see is in just one galaxy, our own! So, the "parent galaxy" for all of your stars is our own. Otherwise, I don't understand if you mean galaxy or consellation?
There would be:
Stars in the Milky Way galaxy,
stars in the Andromeda galaxy and
stars in galaxy X
I want to have fixed coordinates for individual galaxies (their centres) AND fixed coordinates for individual stars.
IF I can define the volume of space that holds a particular galaxy (with cartesian coordinates)then I should be able to state that if a star is within that volume of space then it is part of that galaxy
Originally posted by Daminc
There would be:
stars in galaxy X
That won't work, because too many galaxies have "foreground" stars, and sometimes even "background" stars, quasars and other background galaxies, galaxy clusters, etc. But, even in that volume, three dimensions, individual stars are usually impossible to resolve.
http://www.sai.msu.su/apod/ap030611.html
Okay, let's begin here. What stars are listed? I'm going to make the (educated) assumption that they are the coordinates, probably in the form (right ascension, declination, distance), of stars in the Milky Way galaxy. No one, to my knowledge, has made a catalog of stars in other galaxies. Why not?
Well, you first must understand something about measuring distance. Measuring distance is one of the most difficult things astronomers have to do. Think about why: a nearby dim star and a distant bright star look the same to us. Since stars come in all kinds of inherent brightnesses (called luminosities), you can't use brightness as an indicator of distance.
Within some fairly small distance from the Earth, we can use an effect called parallax to measure distances. When you view the same object from two or more different positions, the object appears in a different position relative to distant background objects. You have two eyes -- each eye sees a slightly different picture of the things in front of you. Your brain uses those slightly different pictures to measure distances to things. Astronomers do the same thing. They precisely measure a nearby star's position relative to much more distant stars. Then they wait six months (so the Earth is on the opposite side of the Sun) and they do it again. The small change in the star's position relative to the background allows them to calculate distance.
All of the naked-eye stars, and quite many others, have had their distances measured this way. The most recent experiment conducting precision parallax studies was the Hipparcos satellite, which I believe measured about 10,000 distances. Chances are, you have a catalog of these nearby stars.
Now, things get substantially harder when you start dealing with stars in other galaxies. Parallax no longer works -- the angles are far, far too small to be measured accurately (with existing technology anyway). Astronomers generally measure the distances to the galaxies using tools like Cepheid variable stars, which are a special class of stars which vary in brightness in such a way that we can determine their luminosities from the period of their variation.
Galaxies are so far away (millions or billions of light-years) that astronomers generally just give one distance estimate for the entire galaxy, and do not generally ever bother with the distances to individual stars.
I suspect that you have a catalog of nearby galaxies (was that you asking about the Tully catalog a while ago?), which gives the 3D positions of some galaxies.
What you're failing to realize is that your datasets do not overlap. Your star catalog lists stars near the Earth (some hundreds of light-years away), while your galaxy catalog lists entire galaxies (some millions of light-years away). There are no stars in your star catalog that are not in the Milky Way.
Good of you to mention this. Let's talk about constellations a bit.
The sky appears two-dimensional to us -- we can imagine a giant sphere surrounding the earth, with white dots painted on its inside surface. We can ascribe two coordinates to any point on the inside surface of this imaginary sphere. In a very similar way, we can ascribe two coordinates (latitude and longitude) to any point on the surface of the earth.
Now for the sake of naming, astronomers have chosen to break the sky up into small interlocking regions -- like a jigsaw puzzle. In a similar fashion, we've also chosen to break up the surface of the Earth into interlocking regions. We call the regions on the Earth countries, states, counties, and so on. These so-called 'political boundaries' are not physical -- you don't trip over a big black line when you cross from one state to another. The regions on the sky are called 'constellations,' and the boundaries are no more physical than the boundaries between states.
The states have cities within them; you would then say that San Francisco is within the state of California. Constellations have stars and galaxies and so on with them, too -- so you might say that the Andromeda Galaxy is within the constellation of Andromeda.
The only difference is distance. All of the cities on the Earth are, quite obviously, on the surface, at more or less the same altitude -- the same distance, say, from the Earth's center.
The stars and galaxies and other objects inside a constellation, however, can be a vastly different distances. The stars in a constellation are pretty close to us. The galaxies are very, very much further -- and the quasars further still. The things in a constellation are not all physically related.
So it sounds to me like you have a mixture of concepts and datasets which isn't going to accomplish much. I believe you have:
1) a catalog of nearby stars' 3D positions (all of which are in the Milky Way).
2) a catalog of nearby galaxies' 3D positions (none of which contain any specific star information).
3) a list of the boundaries between the constellations on the sky.
(Keep in mind that 'nearby' means very different things for stars and galaxies! A nearby star is a few hundred light-years or less distant, and a nearby galaxy is a few tens of millions of light-years or less.)
With this information, you're not going to be able to accomplish what you want -- what you're looking for is data on the positions of individual stars in other galaxies (like Andromeda), and this data simply doesn't exist. It isn't very important to us astronomers!
- Warren
If that doesn't cover it, nothing will. Gee, chroot, are you a little short on time to type a complete answer?...
Bl**dy hell chroot, that was excellent, thanks
How about if I start a bit smaller.
Can I find the coordinate limits on just the Milky Way Galaxy for example, I've read on estimate that says that it is about 100,000 light years in diameter and about 1000 (3000? at the centre?) light years thick.
...the halo which is a spherical region, centred on the nucleus, with a radius of about 50000 light years. This halo contains very old stars, produced early on when the galaxy was still forming. Most of these stars are in vast collections called globular clusters
This bit isn't essential.
If I can do that with the Milky Way then later on I can use a bit of poetic licence to determine other galaxies
Looking back on what I've wrote I decided to get the catesian coordinates for the centre of the Milky Way and came up with this:
X=-1648.59626554521
Y=-26203.687272137
Z=-14513.7487816649
if I give myself a rectangle that is 100,000 by 100,000 by 3000
I should have a limit of
X=-1648.59626554521 +/- 1500
Y=-26203.687272137 +/- 50000
Z=-14513.7487816649 +/- 50000
Do you think that might work?
The Milky Way is about 100,000 ly in diameter, but I think the 3000 ly figure refers to the thickness at our location (28,000 ly from the center of the galaxy). The thickness of the galaxy is somewhat hard to pin down as it depends on what you use to define the upper/lower edges (stars? molecular clouds? dark matter?)
X=-1648.59626554521
Y=-26203.687272137
Z=-14513.7487816649
What do these numbers mean? To make sense of coordinates, you need to specify both the origin and the orientation of your x, y, and z axes.
- Warren
- Warren
... and unit value
Originally posted by enigma
... and unit value
Oh yeah... and that too.
- Warren
Regardless of the three meaningful posts above, I still cannot see any use or value to this excercise. What would be a purpose to "map" in this fashion?
It's an RPG, labguy... it doesn't have to have a point
In my history, RPG stands for "Rocket Propelled Grenade". No wonder I couldn't see a purpose._____..
The Cartesian coordinates are converted from Polar coordinates where the zero points defined by the point where the Sun crosses the equator on the first day of Spring for RA and the celestial equator and poles for declination. RA is measured in hours, minutes, and seconds (24 hours equals 360 degrees of "longitude"; RA increases in the eastward direction). Declination is measured in degrees (0 at the equator; 90 at the Celestial North Pole; objects below the celestial equator are assigned negative declinations).
... and unit value
The scale is in light years.
I'd use the stars to define the edges and from how I understood what I read about the thickness, the 1000ly was referring to where we are and the 3000ly was the centre.
Okay, stop calling them "polar coordinates." They are spherical coordinates. And astronomers call them "equatorial" coordinates, not polar or spherical, to distinguish them from many other coordinate systems in common use, like galactic and so on.
In any event, you didn't answer the question in entirety. I gather that the Earth is the origin of your coordinate system, and the unit length is light years. Where do your x-, y-, and z-axis unit vectors point?
- Warren
OK, check this out: http://www.essex1.com/people/speer/starmodel.html
In math I think we have spherical polar coordinates and cylindrical polar coordinates and it was my understanding that 'spherical polar coordinates' and 'spherical coordinates' are the same except I took away the 'spherical' because of the context.
I think that X would follow in the direction RA=0 and Dec=0 with the Y and Z 90 degrees out of phase
Okay, you're a third of the way there. You've given us one of the unit vectors. The other two vectors, however, could be "90 degrees out of phase" in an infinite number of ways. It would be instructive for you to give us the other two vectors, too.
I'm not being hard on you -- I just think you could stand to have some of your ideas tightened up a bit. The first step is often to begin using the right terminology and methodology.
- Warren
I understand. The difficulty is that I'm not an astronomer. The fields which I've worked with have been electronic communications (British army), Mathmatics (tutoring/teaching) and lately information analyst/web design/marketing/anything my boss wants to throw at me.
I've recently completed a Search Engine Marketing Glossary that is supposed to help combat the problem that you've just highlighted that's happening in my area. Often the same words are used in different context in different subjects, but I'll do my best.
How about this:
X: RA=0 Dec=0
Y: RA=6 Dec=0
Z: RA=0 Dec=90
I hope our language is coming into alignment
Unless I'm mistaken, that coordinate system you have described is called a "Geocentric Equatorial Coordinate System" or an "IJK" system.
I'm not entirely sure which way +RA rotates.
I haven't heard of them, but that's not saying much :wink:
Latest development...I've managaged to automate the distance calculations so all I have to do now is place in the stars and the user can choose two stars via a dropdown and the distance, in light years, will automatically be displayed.
Since this is a relational database (and, in the end, it's just a game) the +RA rotation won't be a biggy if it's wrong. Do we have enough info here to be able to work out some sort of limits for some galaxies or would
this suffice?
I'm sure that would be fine, Daminc.
Remember, if a star were in another galaxy, it would have at least one of those +- margins with several extra zeros after it.
Other galaxies are REALLY far away, even compared to the size of our own galaxy.
Yep, I appreciate that
According to my sums, centre to centre, the distance between the Milky Way and the Andromeda galaxy is 1,974,634 light years compared with Sol and By Draconis being 53.38 light years distance.
Thanks for all your help guys, especially chroot, for teaching me something I didn't know (that's a sure sign of having a good day )
According to your sums? What sums?
The Andromeda galaxy is actually 2.4 Mly (million light-years) away.
- Warren
I was just going with the data I was given:
Milky Way centre:
RAhours=17
RAminutes=45.6
DECdegrees=-28
DECminutes=56
Distance=30,000
Andromeda centre:
RAhours=0
RAminutes=42.7
DECdegrees=41
DECminutes=16
Distance=2,900,000
Gives:
Milkyway cartesian coordinates
X=-1648.59626554521
Y=-26203.687272137
Z=-14513.7487816649
Andromeda cartesian coordinates
X=2142055.26297486
Y=403777.605987481
Z=1912737.01675498
Using the formula [squ]((X1-X2)^2+(Y1-Y2)^2+(Z1-Z2)^2)
gives approx:1974634.00 light years
although, this afternoon I'm definitely going to get my calculator to run though it all manually because using the caculator that's built into the computer I can't make it balance out :frown: but then I've always had difficulty with that thing.
Ah-ha the problem has been sorted out...
My automated calculations wasn't taking the Z coordinates into consideration on account that when you choose a column to calculate with Access starts from column 0 as apposed to column 1.
Bugger...something so simple took a couple of days to spot
Anyway, the new calculation puts the distance to be 2,914,557.54 light years. I suppose the difference between 2.9 Mly and 2.4 Mly might be
1. Small amount of rounding of
2. Calculating centre to centre
Slowly but surely I'm getting there :smile:
1. How do you calculate galaxy coordinates to avoid star misplacement?
To calculate galaxy coordinates and avoid star misplacement, we need to use a combination of mathematical formulas and data from astronomical databases. First, we need to determine the location of the galaxy in the sky using its right ascension and declination. Then, we can use the galaxy's distance from Earth and its radial velocity to calculate its coordinates in a three-dimensional space. Finally, we can convert these coordinates into a standard celestial coordinate system, such as equatorial or galactic coordinates, to accurately place stars in relation to the galaxy.
2. What are right ascension and declination?
Right ascension (RA) and declination (Dec) are the two coordinates used to locate celestial objects in the sky. RA is measured in hours, minutes, and seconds, and is similar to longitude on Earth, while Dec is measured in degrees, minutes, and seconds, and is similar to latitude. These coordinates are used in a coordinate system called equatorial coordinates, which is fixed to the celestial sphere and allows for easy tracking of objects as the Earth rotates.
3. What is radial velocity and how is it used in calculating galaxy coordinates?
Radial velocity is the measure of a celestial object's motion towards or away from Earth along the line of sight. It is usually measured in kilometers per second. In calculating galaxy coordinates, radial velocity is used to determine the galaxy's distance from Earth. This distance, combined with the galaxy's right ascension and declination, allows us to accurately place stars in the galaxy's vicinity and avoid misplacement.
4. Can different coordinate systems be used to calculate galaxy coordinates?
Yes, there are various coordinate systems that can be used to calculate galaxy coordinates, such as equatorial, galactic, and ecliptic coordinates. Each system has its own advantages and is used for different purposes. For example, equatorial coordinates are useful for tracking objects as the Earth rotates, while galactic coordinates are better for studying the structure of our galaxy. The choice of coordinate system depends on the specific needs of the study.
5. How accurate are galaxy coordinates and what factors can affect their accuracy?
The accuracy of galaxy coordinates can vary depending on the precision of the data used and the methods used to calculate them. Generally, coordinates calculated using modern astronomical databases and formulas can be accurate to a few arcseconds. Factors that can affect the accuracy of galaxy coordinates include measurement errors, uncertainties in the galaxy's distance and radial velocity, and the limitations of the coordinate system being used.
  • Astronomy and Astrophysics
  • Science Fiction and Fantasy Media
