Natural Log Equation
  • Thread starter max0005
max0005
52
Given the Equation ln(x+1)-ln(x)=0 find x (If it exists.
ln(x+1)-ln(x)=0
ln(x+1)=ln(x)
x+1 = x
1 = x-x
Solution does not exist. (My book "agrees" with me in the solutions.)
However, typing up the equation in my TI-84 and using the equation solver it finds a solution at around 9.785*10^98. (Which, in fact, works.)
Am I doing something wrong?
Answers and Replies
HallsofIvy
43,010
969
No, it doesn't work. For x= 9.875 x 10^90, ln(x+1)- ln(x) is about 0.0907, not 0. I don't know exactly what you did but I suspect that the "10^98" caused a round off error. I did ln(10.785 x 10^98)- ln(9.785 x 10^98) the "hard way" first, ln(10.785 x 10^98)= ln(10.785)+ 98/ln(10),and the same for ln(9.785 x 10^98, and then simply as ln(10.785 x 10^98/9.785 x 10^98)= ln(10.785/9.785)= 0.0907..., not 0. There is no real x satifying ln(x+1)- ln(x)=0.
max0005
52
Ok, thanks! :D
I just wanted to be sure I hadn't missed out on anything.
gb7nash
805
If you're wondering why you were getting 0, it was roundoff error. Depending on what computer system you use, subtracting two values that are relatively the same will give you 0.
max0005
52
Ok, got it, thanks! :D
praharmitra
311
just to clarify 9.785 x 10^98 + 1 is NOT equal to 10.785 x 10^98.
HallsofIvy
43,010
969
I don't believe that was ever in question!
Delta2
Insights Author
2,477
Yes there is a "kind of" solution x=infinite... your calculator just approximate infinite by a very large number of the order 10^98 ... But ofcourse infinite cannot be considered as a solution to an equation.
praharmitra
311
It definitely wasn't. But in your calculations of ln(x+1) - ln(x), u have calculated ln(10.785/9.785). Though it doesn't change the logic behind your explanation, I was just clarifying that the numbers are wrong.
Mentallic
3,798
94
If you punch [tex]10^{99}-(10^{99}-1)[/tex] into your calculator you will get 0. Again just another demonstration of roundoff errors.
This is another reason why it's sometimes a good idea to do some easy simplifications to an expression before punching it in.
HallsofIvy
43,010
969
Finally, the coin drops! Of course you are right. Thanks.
Suggested for: Natural Log Equation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
