Homework Help: Natural Logarithms
  1. Sep 18, 2007 #1
    ln(x^2 + 1 ) -3lnx=ln2
    Solve for x.
    2. Relevant equations
    3. The attempt at a solution
    I used laws of logarithms to simplify it down to -x^2(x-1)=1 . I don't think this is the answer I'm under the impression you need x = for the answer. First I brought the 3 up to a exponent and then put everything e^ to get rid of the ln's. Could someone please point me in the right direction.
  3. Sep 18, 2007 #2
    D H
    Staff Emeritus
    Show your work on how you arrived at this result and we can help you further (hint: its not correct).
  4. Sep 18, 2007 #3
    sure thing;
    I started with ln(x^2+1)-3lnx = ln2
    I brought the 3 up so its
    ln(x^2+1)-lnx^3=ln2
    then I did
    e^ln(x^2+1)-e^ln(x^3)=e^ln2
    and got
    x^2+1 - x^3 = 2
    -1 from both sides
    x^2-x^3 = 1
    -x^2(-1+x)=1
  5. Sep 18, 2007 #4
    D H
    Staff Emeritus
    OK so far. You're mistake is here:
    Can you see what you did wrong or do you need a bit more help?
  6. Sep 18, 2007 #5
    Should I have made it
    ln((x^2+1)/(x^3)) = ln2
    before doing the e^ ?
  7. Sep 18, 2007 #6
    D H
    Staff Emeritus
    That works. So does using [itex]e^{a+b} = e^ae^b[/tex]. You did the equivalent of [itex]e^{a+b} = e^a+e^b[/tex], which is incorrect.
  8. Sep 18, 2007 #7
    I'm not sure how to use that to help
    but doing it from the way I stated
    I put
    e^ln((x^2+1)/x^3) = e^ln2
    (x^2+1)/x^3 = 2 If this is correct I'm not sure how to do the algebra to get a single x
  9. Sep 18, 2007 #8
    D H
    Staff Emeritus
    Multiply both sides by x3. You won't get a single x (its a cubic equation, after all), but only of the three solutions is a real number.
  10. Sep 18, 2007 #9
    Hurkyl
    Staff Emeritus
    Before you started working with exponentials and logarithms, didn't you spend a lot of time solving equations just like (x^2+1)/x^3 = 2?
  11. Sep 18, 2007 #10
    yes I can get it to a cubic expression of 2x^3-x^2 -1 i just didn't htink this was right I thought it was looking for a x = would this be considered the correct answeR?
  12. Sep 18, 2007 #11
    Hurkyl
    Staff Emeritus
    I assume you meant to say you can derive the cubic equation
    2x^3-x^2 -1 = 0.​
    Again I ask, haven't you spent a lot of time learning how to solve equations exactly like this?
  13. Sep 18, 2007 #12
    the only thing I remeber about solving equations like this is using P's / Q's and testing the 0's however I don't remeber what the P's over Q's were is this the correct direction?
    Edit:
    Is the answer x=1 ( and yes I have in precalc and algebra 2 but those were like 2 and 3 years ago and I am a bit rusty on this)
  14. Sep 18, 2007 #13
    Plug it in and see what happens.
  15. Sep 18, 2007 #14
    Hurkyl
    Staff Emeritus
    In terms of studying, math resembles foreign languages -- you cannot forget what you've already learned if you want to progress! You shouldn't be afraid to pull out your old textbooks to refresh your memory when necessary.
    Anyways, x=1 is, in fact, one of the solutions to that cubic equation. Now that you know one solution, do you remember what to do to find the rest of the solutions?
    (And, incidentally, you always need to check that the answers you derive actually satisfy the original equation: some common algebraic techniques can introduce fake solutions)
  16. Sep 18, 2007 #15
    yes I plugged it in and it worked out :); can you keep using synthetic division that is what I used to find the first solution
Loading...
