1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Natural logs (e) problem
  1. Nov 11, 2007 #1
    e^x - e^-x all divided by 2 = -1
    express answer in natural logs
    2. Relevant equations
    No equations, just properties of logs and natural logs
    3. The attempt at a solution
    First, I multiplied everything by 2
    e^x - e^-x = -2
    then i took the natural log of both sides and brought down the exponent
    (x)Ln(e) + (x)Ln(e) = -2
    so you can simplify that i think to
    2xLn(e) = -2
    so x= -2/(2Lne)
    which Lne is 1 so
    I don't think thats right because it says express answer in natural logs so it should simplify out that easily.
  3. Nov 11, 2007 #2
    I think you missed something.
    When you turn
    e^x - e^-x = -2
    the -2 is part of it too. So it should be
    (x)Ln(e) + (x)Ln(e) = Ln(-2)
  4. Nov 11, 2007 #3
    Unfortunately you are both wrong. You can't just "turn e^x- e^-x= -2 into Ln(e^x)+ Ln(e^-x)".
    You can't "take the natural logarithm of both sides because, as sourlemon said, you must also take the natural logarithm of -2 and that is not defined: the domain of Ln(x)is "all positive x". Even if it were +2 on the right side, Ln(x+ y) is NOT Ln(x)+ Ln(y).
    Instead, go back to e^x- e^-x= -2 and multiply both sides by e^x: (e^x)^2- 1= 2(e^x) or y^2- 1= 2y (taking y= e^x) so y^2- 2y= 1. You can solve that by completing the square on the left: y^2- 2y+ 1= (y-1)^2= 2 so y= [itex]1\pm\sqrt{2}[/itex].
    Once you have [itex]e^x= 1+ \sqrt{2}[/itex], then take the Ln of both sides. (Do you see why [itex]e^x= 1- \sqrt{2}[/itex] is not possible?
    I beat you Compuchip!
  5. Nov 11, 2007 #4
    Also note that in general, log(a + b) is not equal to log(a) + log(b). For example, log(1 + 0) = log(1) = 0 =/= log(1) + log(0) = [itex]-\infty[/itex]. There is just a rule saying that log(a * b) = log(a) + log(b). Instead, multiply both sides by [itex]e^x[/itex] and first solve it for [itex]y = e^x[/itex] as a quadratic expression. Then you can take the logarithm.
    [edit]Wow, you are fast :smile:[/edit]
  6. Nov 11, 2007 #5
    I think you can't do [itex]e^x= 1- \sqrt{2}[/itex] because it would be a negative answer and logs have to be greater than zero.
    I understand how you solved the problem but I was never taught to do it that way, are there other way to solve the problem other than completing the square?
    Is it possible to factor it?
Similar Threads - Natural logs problem Date
Natural Log Proof Oct 22, 2016
Properties of natural log and absolute value Sep 24, 2014
Natural Log Problem Oct 14, 2009
Natural log problem Jul 25, 2007
Natural logs test problem Sep 4, 2006
