Swetha.M.L
- 11
- 1
why light shows both particle and wave nature?
Swetha.M.L said:why light shows both particle and wave nature?
bhobba said:The wave particle duality is actually a myth:
http://arxiv.org/pdf/quant-ph/0609163.pdf
muscaria said:I get the feeling myth is maybe a bit of a strong word no?
muscaria said:The connection was made by Einstein who showed that the flow of energy associated with the translation of relativistic particles at the rate of the speed of light is precisely the flow of energy associated with these light waves.
Are you sure it's (much) better? It doesn't seem so:bhobba said:Here is a MUCH better way of looking at QM:
http://www.scottaaronson.com/democritus/lec9.html
Could you please elaborate a tiny bit more on this ?bhobba said:Its a myth.
Its perpetrated by the semi-historical approach most beginner level QM texts use. Here is a MUCH better way of looking at QM:
zonde said:Are you sure it's (much) better? It doesn't seem so:
"Come read about why quantum mechanics, far from being a mysterious, arbitrary structure foisted on us by experiment, is something that mathematicians could easily have discovered without leaving their armchairs. (They didn’t? Minor detail…)"
Sure.Nick666 said:Could you please elaborate a tiny bit more on this ?
julcab12 said:..One variable is involved -- Observer, act or some form of interaction which breaks (in a sense) duality. Well, we can say ways about QM. As a layman. It boils down to broad approaches; QM has both particle/wave property, waves is a property/illusion of particle (QM), particle is a property/illusion of wave(classical) and so on.
bhobba said:I know this and other myths, like virtual particles are real, are very difficult to shake because its widely used in popularisations and beginner texts. This forum is likely the first place the truth is told for many posters. It leads to long threads where people wedded to the myth quotes this and that - but they really go nowhere because it doesn't change the facts.
Brage said:The point is that we don't actually know why we observe particles but theories describes waves,
bhobba said:Remember what I said before:
julcab12 said:Please read my whole statement.
bhobba said:I did - and you clearly mentioned the wave particle duality 'QM has both particle/wave property'.
Thanks
Bill
I just meant that Maxwell Calculated the energy and linear momentum of his E-M waves. Then Einstein came up with relativity and showed that relativistic particles traveling at c had the same energy and linear momentum.bhobba said:That's not what he did.
Patrickhttp://en.wikipedia.org/wiki/Particle_physics
Although the word "particle" can be used in reference to many objects (e.g. a proton, a gas particle, or even household dust), the term "particle physics" usually refers to the study of "smallest" particles and the fundamental fields that must be defined in order to explain the observed particles.
microsansfil said:We say Corpuscular theory of light which is different from Particle physics, isn't it ?
I don't quite get what you are actually saying so the following may be wrong, but IF you are saying that the real distinction from classical mechanic to quantum mechanics is that QM is it mathematics formalism that would be false because classical mechanics (at least classical statistic mechanics) can be described using the same formalism as QM.bhobba said:Sure.
Here is a more detailed argument along the same lines.
Suppose we have a system in 2 states represented by the vectors [0,1] and [1,0]. These states are called pure. These can be randomly presented for observation and you get the vector [p1, p2] where p1 and p2 give the probabilities of observing the pure state. Such states are called mixed. Now consider the matrix A that say after 1 second transforms one pure state to another with rows [0, 1] and [1, 0]. But what happens when A is applied for half a second. Well that would be a matrix U^2 = A. You can work this out and low and behold U is complex. Apply it to a pure state and you get a complex vector. This is something new. Its not a mixed state - but you are forced to it if you want continuous transformations between pure states.
QM is basically the theory that makes sense out of pure states that are complex numbers. There is really only one reasonable way to do it - by the Born rule (you make the assumption of non contextuality - ie the probability is not basis dependant, plus a few other things no need to go into here) - as shown by Gleason's theorem.
The following gives a more rigorous development of this idea:
http://arxiv.org/pdf/quant-ph/0101012.pdf
The key idea, and what distinguishes QM from standard probability theory, is you must have continuous transformations between pure states. But in modelling physical systems it pretty much what is required ie if a system changes to a another state after one second, it must go through another state after half a second.
Thanks
Bil
I find that assertion to be too extreme, in fact it seems close to a straw man or a fight over just grammatical terms.bhobba said:The wave particle duality is actually a myth:
andresB said:I find that assertion to be too extreme, in fact it seems close to a straw man or a fight over just grammatical terms.
andresB said:I don't quite get what you are actually saying so the following may be wrong, but IF you are saying that the real distinction from classical mechanic to quantum mechanics is that QM is it mathematics formalism that would be false because classical mechanics (at least classical statistic mechanics) can be described using the same formalism as QM.
You could be right here or not, but this last post from you seems to not have anything to do with the paper you quoted (it seems to me that the author of that paper say the opposite of what you just said)bhobba said:What dimension does the wave-function of two entangled particles propagate in? Why would you consider such in any sense a wave? A basis expansion is arbitrary - why do you want to enshrine the position basis?
At an even more basic level, for there to be a wave, what is the medium? What is physically waving?
The bottom line is in some contrived circumstances we have solutions that look like the mathematics of waves but really are nothing like it - and that is only in some circumstanes - in most it doesn't even look like it marthematically.
This whole thing is a hangover from De-Broglie and was superseded when Dirac came up with his transformation theory in 1926 - likely before then - but certainly at that stage:
http://www.lajpe.org/may08/09_Carlos_Madrid.pdf
De-Broglie's ideas led to Schroedinger's wave equation. It was first thought to be just that - an equation about waves - but after a bit of experience that changed rather quickly and Schroedinger lamented he ever became involved in it. Then Dirac combined it with matrix mechanics and it was obvious it had nothing to do with waves - the key thing was this abstract thing called a state.
Thanks
Bill
andresB said:You could be right here or not, but this last post from you seems to not have anything to do with the paper you quoted (it seems to me that the author of that paper say the opposite of what you just said)
From this paper you quotedbhobba said:How you got that beats me.
Thanks
Bill
andresB said:"electrons and photons always behave as waves, while a particle like behavior corresponds only to a special case"
tallal hashmi said:I think that dual nature of light is its nature.
tallal hashmi said:You should check this link
