Need a little help!
  • Thread starter scw287
A computer is reading data from a rotating CD-ROM. At a point that is 0.030 m from the center of the disc, the centripetal acceleration is 118 m/s2. What is the centripetal acceleration at a point that is 0.050 m from the center of the disc?
Ac=v^2/r-centripual acceleration
possibly v=2pier/T
Aa=Va^2/Ra
Ab=Vb^2/Rb
substituted Va=1.667*r*a, 1.667*ra<<<1.667 I got by dividing .050m/.030m to get the ratio of the radius'
I set up the equations like this:
118^2/.5^2=(1.667*118 m/s^2*V)^2/(1.667*.30)
>>crossed multiplied .25(196.706V)^2=13924(.5001)
solved for V and got V=.720<<<this is wrong
I think I'm on the right track I think theres an error on the way I set up my equations before substituting in the numbers.
Answers and Replies
berkeman
Mentor
60,016
10,224
What is Va?
How does V ratio with radius?
Doc Al
Mentor
45,140
1,442
Not quite sure what you are doing, but here's a hint that might help: Rewrite the formula for centripetal acceleration in terms of angular velocity (omega) instead of tangential velocity (v). (How are those two quantities related?)
Va means velocity times the acceleration
I haven't learned angular velocity yet so I'm not sure how to relate the two. I was trying to use the formula for centrepitual acceleration A=v^2/r
I then set up the equation for the first distance from the center of the CD and then set up a second equation for the second distance from the center. I used the ratio .05/.03=1.667 to tie the two distances together. I then subtitued all the known and solved for the velocity.
berkeman
Mentor
60,016
10,224
No it doesn't, not as you've used it:
Aa=Va^2/Ra
Ab=Vb^2/Rb
You've used a and b as the first and second points. Call them V1 and V2 if you like to be clearer.
Whatever notation you use, my hint was to calculate the linear velocity (Va or V1 or whatever), and then use what you know about how the velocity varies with radius to solve the problem.
use the expression for centripetal acceleration and see how it is related to the radius. thry to write it in terms of something that these two points have in common (like period of the motion)
then solve for the period. since the period is the same for both, equate the two get the answer.
So I'm trying to learn how to do it using the angular velocity way. I'm not familiar with this method and I was hoping if you could check my work.
a = omega^2 r
So a is proportional to r.
a(r) = a(@ r') (r / r')
plug the numbers in and i get
a(.050)=118(.030)(.050/.030)
=118<<i don't think this answer is right, I have a feeling there is something wrong with the left side maybe I'm not supposed to multiply a*the radius???
a is proportional to r but not as "constant = a*r"
look at the equation you wrote first a=omega^2 r
then you get "omega^2(which is a constant) = ........)
Its equal to the angular velocity so would it be 118*(.050/.030)
Doc Al
Mentor
45,140
1,442
a = omega^2 r
Exactly right.
Careful with your notation. Express it like this:
a_2 = a_1 (r_2/r_1)
See my note above.
Doc Al
Mentor
45,140
1,442
Exactly.....
Exactly right.
a_2 = a_1 (r_2/r_1)
See my note above.
that is much easier to understand!
Related Threads on Need a little help!
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
