ohlhauc1
- 27
I know that this is probably a pathetic question to ask, but I shall ask anyways. How do you get the picture/avatar that appears under your name in posts? I know that many members have it, and I want one too. Please help.
To add a picture or avatar to your post, first click on the "Insert Image" button in the post editor. Then, you can either upload a new image or select one from your existing media library. Once you have chosen your image, click "Insert into post" and it will be added to your post.
The recommended size for a picture or avatar in a post is typically no larger than 150 x 150 pixels. This allows for optimal display on all devices and prevents the image from taking up too much space on the page.
You can use either a custom image or one from your media library. If you choose to use a custom image, make sure it is in a compatible file format such as JPEG, PNG, or GIF.
To change the position or size of your picture or avatar in a post, click on the image and then select the options available in the post editor. You can align the image to the left, right, or center, and adjust the size by dragging the corners of the image.
If you have set a default picture or avatar for your account, it will automatically appear in all of your posts. However, if you choose to add a custom image to a specific post, it will only appear in that post and not in any others.
