Effortlessly Convert AC to DC for Your Cushman Scooter | Tips and Tricks
  • Thread starter kellyconway
  • Tags
    Ac Dc
In summary, the conversation discusses how to convert a small 9hp engine with electric start and a stator that puts out between 5-18 volts ac into dc to run lights and charge a battery on a cushman scooter. The solution suggested is to use a rectifier, which can transform the ac input to a desired dc output. It is also mentioned that switching supplies can be used for this task. Additionally, it is suggested that the battery in the engine and the battery in the electric scooter may have the same voltage, making it possible to use some of the engine's power to charge the scooter.
kellyconway
Hello,
I have a small 9hp engine with electric start and a stator that puts out between 5-18 volts ac, it only has one wire coming out and would like to convert it to dc to run lights and charge my battery on a cushman scooter. any help would be appreciated...
What you're looking for is a rectifier. Remember that the Vdc out of the rectifier will be a function of the ac input. It's usually easier to transform the ac going into the rectifier to a value that will give you the desired dc output than to convert the output dc into another value.
denni is right, you can get tons of switching supplies (some rather small) that can probably do the task you want.
Your alternator is electric start, so it must have a battery and a battery charging arrangement in it already.
Do you know what voltage this battery is and what voltage is the battery in your electric scooter?
If they are the same voltage, it may be possible to borrow some of this power to charge your scooter.
1. What is the difference between AC and DC?
AC stands for alternating current, which means the flow of electricity periodically changes direction. DC stands for direct current, which means the flow of electricity only goes in one direction.
2. Why do we need to convert AC to DC?
Many electronic devices, such as computers and smartphones, require DC to function properly. AC is the standard form of electricity used in power grids, so it needs to be converted to DC before it can be used by these devices.
3. How is AC converted to DC?
This conversion is typically done using a device called a rectifier, which contains diodes that only allow current to flow in one direction. The AC is passed through the rectifier, which converts it to pulsating DC. To smooth out the pulsations, a filter circuit is used to produce a steady DC output.
4. What are the different types of rectifiers?
There are two main types of rectifiers: half-wave and full-wave. Half-wave rectifiers only use half of the AC cycle, while full-wave rectifiers use both halves. Within these categories, there are also different designs such as single-phase and three-phase rectifiers.
5. Are there any other methods for converting AC to DC?
Yes, there are other methods such as using a transformer and a bridge rectifier, or using a switching regulator. These methods are commonly used in power supplies for electronic devices.
  • Electrical Engineering
14K
