Need help disproving this
  • Thread starter Melodia
Melodia
Thanks for the help on the last problem. Here is the final problem set I'm stuck on:
To me it seems that there will always be a positive c so that cg(n) is greater or equal to f(n). No matter how large n is, since there's no limit to how large c can be (can even be a decimal), wouldn't that always be possible?
Thanks.
Answers and Replies
8,207
First off, g is not a polynomial, as it is not the sum of multiples of integral powers of n. It might be helpful for you to graph the two functions, because you would see that for n larger than about 20, the linear function dominates the other function. Although f(n) = 2n + 3 is a linear function and grows at only a constant rate, that rate is larger than that of the other function, for large enough n.
Melodia
Oooh I see. Since c is fixed and chosen before the n, then there will always be an n that contradicts the statement right?
I'm guessing the same thing applies to this other problem right?
vela
Staff Emeritus
Education Advisor
15,514
2,158
Yes, essentially. For the first problem, there's no fixed value of c that works because you can always make n large enough so that the inequality doesn't hold. In other words, no such c exists.
Suggested for: Need help disproving this
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
