Need Help in C Programming
  1. Mar 2, 2008 #1
    Hello,
    I am writing a c program to Prompts the user (altogether 10 times) to enter a word not longer than 9 characters: for this part, it doesnt seems working. it didnt return back to the loop to re-entry a correct word(less than 9 characters) " And it needs the modification of each word by changing lower case to upper and then the reverse of the word is concatenated with the word- i can only print out the word (my input : chester, output CHESTER). it cant show like (my input : Chester , output RETSEHccHESTER) , show them in unsorted way and sorted way.
    After that, the program terminates. I have made many attempts at writing this program and this is where i am at right now and it still doesnt work. Thanks in advance for the input.
    Code (Text):
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    char toupper(char);
    char tolower(char);
    int main(void)
      #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    char toupper(char);
    char tolower(char);
    int main(void)
       char words[10][19];
       char c;
       int i, j;
       int k;
       char swap[10][19];
    while ( j != 10)
       for ( i = 0; i < 10; i++ )
          printf("enter the character \n");
          fflush(stdout);
          for ( j = 0; j < 10; j++ )
             words[i][j] =fgetc(stdin);
             if ( words[i][j] == '\n' )
                words[i][j] = '\0';
                break;
          printf(" you have entered more than 9 characters! \n");  }
             k = (int)(words[i][j]);
             if ( k >= 64 && k <= 91 )
                words[i][j]= tolower(words[i][j] );
             else if ( k >= 96 && k<= 123 )
                words[i][j]= toupper(words[i][j] );
       printf("unsort \n");
          printf("%s \n ", words[i]);
          fflush(stdout);
       printf("Sorted: \n");
       for ( i=9; i>0; i-- )
          for ( j=0; j<i; j++ )
             if ( strcmp(words[j],words[j+1])>0 )
                strcpy(swap[j],words[j]);
                strcpy(words[j],words[j+1]);
                strcpy(words[j+1],swap[j]);
          printf("%s \n", words[i]);
       return 0;
    char toupper(char let)
       int d;
       d = (int)let;
       let = (char)d-32;
       return let;
    char tolower(char let)
       int d;
       d = (int)let;
       let = (char)d+32;
       return let;
  3. Mar 2, 2008 #2
    jtbell
    Staff: Mentor
    Can you please be more specific than "doesn't work?" Do you get compiler error messages? Does the program compile, but crash when you try to run it? Does it produce the wrong output? (If so, please give a sample input, the output you expect, and the output you actually get.) Does it make your monitor flash on and off? :smile:
  4. Mar 2, 2008 #3
    jim mcnamara
    Staff: Mentor
    Another suggestion. Us C/C++ programmers cannot read unindented code.
    Please use [ c o d e ] [ / c o d e ] tags (I wrote them with spaces between each character, remove the spaces.) We are helping you, but you have to help us old f*rts.
  5. Mar 3, 2008 #4
    Eus
    Hi Ho!
    Let's do it bit-by-bit:
    Duplicated function declarations. Here is your zeroth bug.
    'j' is not initialized. Here you have your first bug.
    Unclosed 'while' block in which 'j' is not incremented properly. Here you have your second bug.
    I think I must stop here till you provide a better code.
    Best regards,
    Eus
  6. Mar 3, 2008 #5
    rcgldr
    Also you could use _gets(), a getline function that goes back to dos (int 21h, function 0ah).
    Code (Text):
    #define LINESZ 10
    static char acBuffer=[LINESZ+2];
    int main()
    int iNumChar;
        acBuffer[0] = LINESZ;   // initialize # of characters in buffer
        _cgets(acBuffer);       // read up to LINESZ characters into acBuffer[2...]
        iNumChar = (int)(acBuffer[1]); // get number of characters input
        // ... acBuffer[2]  == 1st character of user input
  7. Mar 3, 2008 #6
    Jeff, showed you how to apply the techniques. You, should code it using a descriptive style associated with your particular solution. I added one storage byte, and tacked on a null byte making the buffer, c-compatible, when it does a name change to "word". Pack this code into a function and you have go.
    Example using _gets(), a getline function that goes back to dos (int 21h, function 0ah).
    Code (Text):
    #define WORDsize 10
    static char inWORD [WORDsize+2+1];
    static char *word = &inWORD [2]
    int main()
    int charactersIN ;
        inWORD[0] = WORDsize   // initialize # of characters for read buffer
        _cgets(inWORD);       // read up to WORDsize  characters into buffer/inWORD[2...]
        charactersIN = (int)(inWORD [1]); // get number of characters input/entered
        inWORD [charactersIN+2] = '\n' ;  // termniate sequence entered with a null byte.
        // ...  inWORD [2]  == 1st character of user input
        // ...   word is now a c-string, strlen(word) will return charactersIN
        // ...   and it can be used as: firstCHARACTER = word[0] ;
  8. Mar 3, 2008 #7
    thanks alot !
    it really help!!
  9. Mar 3, 2008 #8
    rcgldr
    For a C string, you would want
    inWORD [charactersIN+2] = 0;
  10. Mar 5, 2008 #9
    Eus
    Hi Ho!
    I think the use of _gets () is not portable.
    I have revised the code to make it clearer and more portable.
    Just give it a try.
    Code (Text):
    #include <ctype.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    int main(int argc, char **argv, char **envp)
        char words [10][19] = {0};
        char swap [19] = {0};
        int i = 0;
        int j = 0;
        int k = 0;
        int word_len = 0;
        for (i = 0; i < 10; i++)
            printf ("Enter at most nine characters [#%d]: ", i + 1);
            for (j = 0; j < 10; j++)
                words [i][j] = fgetc (stdin);
                if (words [i][j] == '\n')
                    words [i][j] = '\0';
                    break;
            if (j == 10)
                printf ("You have entered more than nine characters! Please repeat!\n\n");
                i--;
                while (fgetc (stdin) != '\n');
                if (isupper (words [i][j]))
                    words [i][j] = tolower (words[i][j]);
                else if (islower (words [i][j]))
                    words [i][j] = toupper (words[i][j]);
            word_len = strlen (words [i]);
            words [i][word_len * 2] = '\0';
            for (j = 0; j < word_len; j++)
                words [i][j + word_len] = words [i][j];
            for (j = 0, k = word_len * 2 - 1; j < k; j++, k--)
                words [i][j] = words [i][k];
        printf("\nUnsorted:\n");
            printf ("%s\n", words[i]);
        printf("\nSorted (Ascending):\n");
        for (i = 0; i < 9; i++)
            for (j = 9; j > i ; j--)
                if (strcmp (words [j], words [j - 1]) < 0)
                    strcpy (swap, words [j]);
                    strcpy (words [j], words [j - 1]);
                    strcpy (words [j - 1], swap);
            printf ("%s\n", words [i]);
        return 0;
    Best regards,
    Eus
