Need help in factoring algorithms
In summary: FalseFermat's little Theorem is alright, but I'd rather go with the Miller Rabin Test, in my number theory course we integrated the two tests into a single program for the minimum amount of run time needed to work out if the number is a prime to a certain level of probability.In summary, RSA-200 has been reformulated and expressed in bits instead of decimal. The German researchers have attempted to factor the number using the same technique as before, but with more than 200 digits. They are still confused by the same number with separators every 3 digits. Aravindsubramanian suggests that RSA-200 be tested using the Miller-Rabin test to verify that
aravindsubramanian
23
Rsa200, The 200 digit RSA challenge no is factored on may 9.
The German researchers, RSA has reformulated its challenge and now expresses numbers in bits (base 2) instead of decimal (base 10)
source
http://news.com.com/2061-10789_3-5702146.html
So what's the problem?
I'm still confused, it's just the same number with separators every 3 digits...
Yea right. And because of that I would ask aravindsubramanian to kindly prepare a short report detailing how RSA-200 was factored. Include the technique used, how long it took, what kind of computer resources were used, and what criteria was used in selecting the two primes in it's product. :smile: Or just ignore me. :yuck:
Aravindsubramanian, in case you're not already annoyed by me, here's two more:
Download the two prime factors in Mathematica and verify they work. You'll find out quick-like why you don't want any commas in there.
Finally, how do you check that these large numbers are in fact prime? . . . "why don't you Salty?". Suppose I could. Think one way has to do with Fermat's little theorem. Need to check . . .
Edit: Oh yea, I don't think they even need to be prime, just relatively prime. Huh Zurtex?
Fermat’s little Theorem is alright, but I'd rather go with the Miller Rabin Test, in my number theory course we integrated the two tests into a single program for the minimum amount of run time needed to work out if the number is a prime to a certain level of probability.
Where n is the number I was fairly happy to reduce the probability of the number being not being prime down to less than 1/n which took a run time of about:
[tex]\text{O} \left( \frac{1}{\sqrt{2}} \left( \log n \right)^{2} \right)[/tex]
Which was very useful as you can imagine.
Here's the Miller-Rabin test:
Let n be an odd prime and write:
[tex](n-1)=d2^s[/tex]
That is, remove all the s factors of 2.
Then one of the following must be true for some a[itex]\in[/itex][1,n-1]:
[tex]a^d\equiv 1(\bmod n)[/tex]
or, letting:
[tex]k=d2^r[/tex]
[tex]a^{k}\equiv -1(\bmod n)\quad\text{for some}\quad 0\leq r\leq (s-1)[/tex]
So I wrote the Mathematica code below to implement this test (not shown is the routine to get s and d). It actually checks for composite by running through a total of amax trials, and all the values of r if the first test is not satisfied and if none are found, then judges the number to be composite. I checked the two prime factors of RSA-200. What I found interesting was the small number of factors of 2 in (n-1). The first prime had (in n-1), a single factor of 2 and the second had only two factors of 2.
Is this a characteristic feature of RSA primes?
Code:
MillerRabin[pval_, amax_] := Module[{a, s, d, r, aval, rsum, aexp},
      (* get d and s for test *)
      plist = GetSandD[pval];
      s = plist[[1]];
      d = plist[[2]];
      For[a = 1, a <= amax, a++,
        aval = Random[Integer, {1, pval - 1}];
        If[PowerMod[aval, d, pval] != 1,
          rsum = 0;
          For[r = 0, r <= s - 1, r++,
            aexp = d(2^r);
            If[PowerMod[aval, aexp, pval] != pval - 1,
              rsum += 1;
          If[rsum == s,
            Return["composite"];
      Return["possible prime"];
RSA-200 is a really old number so yeah they are likely to have designed it such that it was a bit harder to factor by such methods.
The newer RSA numbers on the other hand have been made when the best methods available to attack such numbers are not bias to any particular type of numbers so I doubt they will have been made quite the same way.
Hai saltydog,
Rsa200 was factored using general number field sieve factoring agorithm.Sieving starts on christmas2003. The initial "sieving" step took the equivalent of 55 CPU-years on a single machine (2.2Ghz Opteron CPU).
see
http://en.wikinews.org/wiki/200_digit_number_factored
for more information
For primality testing we can use AKS primality testing algorithm.This is the only polynominal time algorithm available for primality testing.
Umm correction(!), it is the only "deterministic" polynomial time algorithm available for primality testing [edit]till Riemann Hypothesis is proved true[/edit]. Otherwise we did have probabilistic algorithms earlier which worked in polynomial time.
-- AI
Assuming the truth of the generalized Riemann Hypothesis, if all values of a up to [itex]2 (ln n)^2 [/itex] are tested in the M-R test, then it becomes deterministic with a run-time of [itex]O(ln n)^4[/tex]
Hai saltydog,
see
Hello Aravind, just suggestions. Probably knew it already huh? I noticed your thread on RSA. What's the largest primes you've ever used in an RSA encryption from scratch? I used two 266-digit primes to encrypt a treasure map once. Yea, you didn't know I was a pirate did you? :smile:
Oh yea, here it is: :smile:
584565320456079056472406794697025571766693520913877507241662721424514015287011603416154188536836341015926767446223936487086729380578563273429545303354882999335872814693052640028188293170276069519193534066874924002823402299557574111508994858974296221386784608393260544702126406796897098959631948264896983143307205839708632666773260086979553742525654915079519938492366869933223381055342706622
425031839180665648719174085014618369417651996764817708423914215175891883694441939466211544062220527814839790244648360067898947829169131086041
Post edited :rolleyes: :tongue:
-- AI
1. What is factoring algorithm?
A factoring algorithm is a mathematical procedure used to find the factors of a given number. It involves breaking down a number into smaller numbers that when multiplied together, give the original number.
2. Why is factoring important in mathematics?
Factoring is important in mathematics because it helps in solving complex equations and problems involving large numbers. It also has applications in cryptography, number theory, and computer science.
3. What are some common factoring algorithms?
Some common factoring algorithms include trial division, Pollard's rho algorithm, quadratic sieve algorithm, and elliptic curve factorization.
4. How do factoring algorithms work?
Factoring algorithms work by systematically breaking down a number into its smaller factors. The algorithm uses various mathematical techniques and principles to determine the factors of a given number.
5. What are the uses of factoring algorithms?
Factoring algorithms have various uses in mathematics, computer science, and cryptography. They are used to find prime factors of a number, solve complex equations, generate random numbers, and secure data encryption, among others.
  • Linear and Abstract Algebra
10K
  • Set Theory, Logic, Probability, Statistics
  • Precalculus Mathematics Homework Help
