Need Help With Circuit Troubleshooting
  • Thread starter Pooya_M
  • Tags
    Circuit
In summary: Scopes are expensive, no way around that. I picked up a 20MHz one online that wasn't terribly expensive. It seems to do the job for...me.
Pooya_M
Hi!
I was working on a circuit today.I soldiered all the capacitors, resistors, transistors,... just as the paper-guide said except the Microphone;Because it was said in there that if you want to use this kit as an earphone, simply solder the MIC to the board,else use a "shield wire(?)" to attach the MIC to it's slots...I assumed that shield wire is simply the ones that have some golden torn wires as their kernel...I used a 3.5 mm standard headphone
But after plugging the batteries, some irrelevant noise(not the environment sound) and sometimes continuous beep is heard (However, when I blow to the MIC some relevant noise can be heard)
WHERE IS THE PROBLEM?
My suspects[!]:
-the "shied wire"?
-mis-soldering the shield wire to the MIC?
-mis-soldering the battery wires?
-I misplaced a 4.7 capacitor in a 0.47 capacitor,then I desoldered it with lots of troubles[!]. Perhaps the capacitor failed?
This is a picture of my cuisine[!]:
http://i52.tinypic.com/339n0qg.jpg
I will be glad if you help...
Thanks
Pooya_M said:
Hi!
I was working on a circuit today.I soldiered all the capacitors, resistors, transistors,... just as the paper-guide said except the Microphone;Because it was said in there that if you want to use this kit as an earphone, simply solder the MIC to the board,else use a "shield wire(?)" to attach the MIC to it's slots...I assumed that shield wire is simply the ones that have some gold torn wires as their kernel...I used a 3.5 mm standard headphone
My suspects[!]:
-the "shied wire"?
Thanks
Welcome to the PF.
It almost looks like a transmitter and receiver together? I see the microphone in the picture, but also see what looks like an earpiece jack. Is this meant to be a wireless microphone, or a wireless receiver? Or can it do both somehow?
a 3.5 mm headphone would be plugged into the down left device in the picture
I think it is just a sensitive amplifier.
Ah, I see. It is an audio amplifier from the microphone to the earphone jack.
Can you post a copy of the schematic? That would be helpful in debugging the circuit operation.
Also, what measurement equipment do you have? Do you have a digital multi-meter (DMM)? How about an oscilloscope?
Here:http://www.freeimagehosting.net/t/ea24f.jpg
Sorry about photo's poor quality
Well,I don't have any measurement tools yet!(Say, I am a first year electrical engineering student and I don't even have a multimeter!)
Going to buy a good DMM tomorrow... (It is 2:15 A.M now in here!)
Do you have the schematic? That is the paper diagram of the parts, and how they are connected together. The photo that you posted just now is the "layout" of the circuit, not the "schematic".
you mean kind of these things:[PLAIN]http://www.dekits.com/images/images_big/shematic8.jpg
No,I don't.
BTW,the picture in this post is something like my circuit
No,I don't.
The schematic example link at dekits.com is not working.
It will be very difficult to help you debug the problem without the schematic for the kit. Can you get it from dekits.com somehow?
I've been using the http://www.shopextech.com/c938/multimeters.php, less expensive than a Fluke and seem to be competetive in quality.
Scopes are expensive, no way around that. I picked up a 20MHz one online that wasn't terribly expensive. It seems to do the job for me.
It isn't my circuit's schematic.But I think it is similar to it in practice:
http://www.freeimagehosting.net/e7b2d
Also:
Never assume anything when building circuits. *wink*
1. How do I troubleshoot an electrical circuit?
To troubleshoot an electrical circuit, start by checking for loose connections or damaged wires. Use a multimeter to test the voltage and continuity of each component. If necessary, replace faulty components. It may also be helpful to refer to the circuit diagram or consult with an experienced electrician.
2. Why is my circuit not working?
There could be several reasons why a circuit is not working. It could be due to a loose connection, a blown fuse, or a faulty component. It's important to check each component individually to determine the root cause of the issue.
3. How do I fix a short circuit?
To fix a short circuit, start by turning off the power to the circuit. Then, inspect the wires and connections for any signs of damage or loose connections. If you find a damaged wire, replace it. If the issue persists, it may be necessary to replace the entire circuit.
4. What is a ground fault and how do I troubleshoot it?
A ground fault occurs when an electrical current strays from its intended path and flows through an unintended conductor. To troubleshoot a ground fault, you can use a ground fault circuit interrupter (GFCI) outlet. This will automatically shut off the circuit if a ground fault is detected.
5. How can I prevent circuit issues in the future?
To prevent circuit issues in the future, make sure to use high-quality components and follow proper installation procedures. Regular maintenance and inspections can also help identify and prevent potential issues before they become major problems. It's also important to use caution when working with electricity and follow all safety precautions.
  • Electrical Engineering
11K
  • Computing and Technology
