Homework Help: Need help on a vector problem by tomorrow.
  1. Oct 27, 2007 #1
    Need help on a vector problem by tomorrow. :(
    A woman walks 277. m in the direction 41.6° east of north, then 171 m directly east. Find
    (a) her resultant vector displacement from the starting point
    There were other parts to the question which I got right, I can't seem to get this one.
    2. Relevant equations
    None except the pythagorean theorem:
    In this case, D=[tex]\sqrt{Dx^2 + Dy^2}[/tex]
    3. The attempt at a solution
    D1X=cos(41.6°) * 277
    D1X=207.1400711
    D2X=171
    D1Y=sin(41.6°) * 277
    D1Y=183.9075609
    D2Y=0
    Dx=378.14
    Dy=183.9075604
    D=sqrt(378.14^2+183.9075609^2)
    D=420.49 =~ 420.5
    Ok, so I got 420.5 and plugged in it. Nope, the computer says it's wrong. I tried rounding it to 421 and that was wrong also. I don't think I made any math errors, what am I doing wrong?
  3. Oct 27, 2007 #2
    PhanthomJay
    You used the wrong angle..problem says east of north but you used north of east.....otherwise, your work looks good once you correct for the proper angle.
  4. Oct 27, 2007 #3
    Now I'm confused, what is the difference between east of north and north of east? >_> Which angle would I use?
    EDIT: The only other angle I can think of is 48.4 degrees, found by: 90+41.6+x=180
  5. Oct 27, 2007 #4
    cristo
    Staff Emeritus
    x degrees "east of north" means x degrees from north in a clockwise manner. x degrees "north of east" means x degrees from east in an anticlockwise manner. Unless x=45, the angles will not be the same.
  6. Oct 27, 2007 #5
    PhanthomJay
    And don't forget to get the resultant angle.
  7. Oct 27, 2007 #6
    Thanks for explaining that, I changed the angle and it worked. :)
