Can You Prove These Two Questions About a One-to-One Function f: R -> R?
  • Thread starter guox1560
  • Tags
    Function
In summary, the conversation discusses two questions related to a function f: R -> R with certain properties. The first question (1a) asks to prove that if there exists a value y such that f(y) = y + r, then f(y - nr) = (y - nr) + r for all positive integers n. The second question (1b) adds the assumption that f is one-to-one and asks to prove the same statement for all integers n. The second question (2) introduces a one-to-one function f: R -> R with additional properties and asks to prove that f(x) = x for all x in the real numbers. A hint is given to use the precise definition of limits and the result of
guox1560
Realli need help on those two questions! any1 can help with that, or post the solution. Thank you guys!
1. Suppose f : R -> R is a function such that
f(2x - f(x)) = x
for all x and let r be a fixed real number.
(a) Prove that if there exists y such that f(y) = y + r, then f(y - nr) =
(b) Prove that if, in addition to the assumptions in part a), f is also oneto-
one, then f(y - nr) = (y - nr) + r is true for all integers n.
2. Suppose that f: R -> R is a one-to-one function such that the following
are true
f is continuous at all points a 2 R; that is to say that
lim f(x) = f(a) for all a 2 R.
x->a
* f(0) = 0, and
* f(2x - f(x)) = x for all x 2 R.
Prove that f(x) = x for all x 2 R. (Hint: use the precise definition of limits
and the result of question 1.)
For 1a) notice that if f(y) = y + r, then f(2y - f(y)) = y = f(2y - (y + r)) = f(y - r). Can you repeat this process?
1. What is a function?
A function is a mathematical relationship between two sets, where each input from the first set is associated with exactly one output from the second set. In programming, a function is a block of code that performs a specific task and can be reused multiple times.
2. How do you prove a function?
To prove a function, you need to show that for every input value, there is exactly one output value. This can be done by using mathematical methods such as substitution and logic, or by providing a table or graph that demonstrates the relationship between inputs and outputs.
3. What is the importance of proving a function?
Proving a function is important because it ensures that the relationship between inputs and outputs is well-defined and follows certain rules. This allows for the function to be used reliably in mathematical calculations or in programming applications.
4. Can a function be disproved?
Yes, a function can be disproved if it fails to meet the criteria of a well-defined relationship between inputs and outputs. This could happen if there are multiple outputs for a single input, or if there are no outputs for certain inputs.
5. What are some common methods for proving a function?
Some common methods for proving a function include using algebraic manipulation, using truth tables, and using mathematical induction. In programming, testing the function with a variety of inputs and checking for expected outputs is also a common method for proving its validity.
  • Calculus
