How Do Velocities Change After an Elastic Collision?
  • Thread starter physics_geek
  • Tags
    Collisions
In summary: V1. Solve that quadratic equation for V1. Put that value of V1 back into the first equation and solve for V2. If you are having trouble with that, you need to say what trouble you are having.
physics_geek
84
I need help with this question please:
A 25.0g object moving to the right at 20.0cm/s overtakes and collides elastically with a 10.0g object moving in the same direction at 15.0cm/s. Find the velocity of each object after the collision.
The answer is: 17.1cm/s (25.0g obect), 22.1cm/s (10.0g object)
Can someone please explain how to get these answers..im soo lost
Before you receive help, you will have to attempt the problem. What formulas do you think need to be applied?
i can only think of
mv1(initial) + mv2(initial)= mv1(final) + mv2(final)
i don't know what to do next
umm yea is anyone going to help me..??
This is posted in the wrong section. somebody move this please.
You came up with an equation. have you plugged in the numbers yet?
Yea..and it doesn't work!...i guess nobody knows how to do this
physics_geek said:
i can only think of
That step that you did was important. You've written down the momentum conservation for the system. And if we also know that total kinetic energy remains the same before and after the collusion (write it down), can you solve for v1 final and v2 final?
Firstly, please note that we have homework forums, where these questions should be posted. Posting there will enable your question to be answered quicker. Secondly, the people helping you on this site are volunteers, and you cannot expect an answer to your question within ten minutes! Please be patient!
physics_geek said:
i can only think of
With regard to your question; you have the right equation here. Which variables do you know? Can you plug these into the equation? Do you know any other quantity that is conserved here?
lol..alrite..sorry..guess I am a little pushy..anyways ill try the homework forums..thanks
That's ok. You should continue this question here now though, since you've started a thread. (This will probably be moved by a mentor at a later time anyway)
Have you thought about my questions in the last post?
umm i don't even know where to begin or if the above equation is even the right one..please help
umm yea and i plugged in the information i know but I am not getting the right answer..
Energy is also conserved, and you need a second equation to find the two unknowns
Well, post what you get when you plug the numbers into the equation (and not just the answer.. show your working) then I'll be able to see where you're going wrong!
You need another equation since you have 1 equation with two unknowns. That's why cristo was asking if there was another quantity conserved.
hmmm ummm uhhh...alrite I am a blithering idiot 'cuz i can't come up with any equations..
did you read my second reply to see what else is conserved?
Ok, you have this equation m1v1(initial) + m2v2(initial)= m1v1(final) + m2v2(final). Now, you know the masses, and the initial speeds, so plug them in!
Also, since we know the collision is elastic, kinetic energy is conserved. Do you know the equation for kinetic energy?
umm ok how about:
.5mv1(initial)^2 + .5mv2(initial)^2 = .5mv1(final)^2 + .5mv2(final)^2
what now?
yea i know..energy is also conserved..but how is that going to help me?
Here's what you wrote in the other thread:
physics_geek said:
umm ok how about:
what now?
Now you have two equations. Plug the values you know into each of these equations, and you will have two equations, with two unknowns. Post what you get.
(edit: Thanks to the mentor that locked the other thread; it was getting rather confusing!)
I merged the two threads on this topic by the OP.
umm ok
(25g)(20cm/s) + (10g)(15cm/s) = (25g + 10g)V(final)
.5(25g)(20cm/s)^2 + .5(10g)(15cm/s)^2 = .5(25g + 10g)V(final)^2 = 18.7
now wat?
physics_geek said:
umm ok
(25g)(20cm/s) + (10g)(15cm/s) = (25g)V1 + (10g)V2
.5(25g)(20cm/s)^2 + .5(10g)(15cm/s)^2 = .5(25g)V1^2+.5(10g)V2^2
now wat?
Since this is an elastic collision, the objects will still be separate after the collision. See the red amendments to your equation above.
Now, you solve the equations for the two variables you have.
umm i still don't understand...how do u solve for the two variables?
Well, the left hand side of both equations are just numbers, so firstly you should work those out. Then, you will have the first equation in the form of A=25v1+10v2 (where A is the number on the left hand side- I'm not doing the arithmetic for you!) Rearrange this to get v1 on its own, and the substitute this into the second equation. The second equation is then an equation for only v2 which you can solve.
Then, substitute the value obtained for v2 into the first equation, to give you the value of v1
ok well it sounds sooo easy...but for whatever reason i just can't solve it..
umm help someone..please
Why can't you do it? Have you simplified the equations into the form I showed you? If so, post them so I can see what you've done.
So far, you have not even tried anything. You have been told that, in addition to "conservation of momentum", since the collision is elastic, you also have "conservation of "energy". You have two equations:
(25g)(20cm/s) + (10g)(15cm/s) = (25g)V1 + (10g)V2 and
You ask "now what?" Well, how about actually multiplying out the numbers you have above? (25g)(20 cm/s)= 500 gcm/s, etc.
You will get
25V1+ 10V2= 650 and 12.5 V1^2+ 5V2^2= 6125
Try solving the first equation for V2 and putting that formula into the second so you get a quadratic equation for V1.
  • #31
Draw a picture of what's happening and then after that it should become more clear on what equations you need to apply =).
What is a collision in physics?
A collision in physics is an event in which two or more objects come into contact with each other and exert forces on each other. This can result in a change in the motion or shape of the objects involved.
What is the difference between an elastic and inelastic collision?
In an elastic collision, the total kinetic energy of the system is conserved, meaning that the objects involved bounce off each other without any loss of energy. In an inelastic collision, some kinetic energy is lost as the objects stick together or deform upon impact.
How do you calculate the momentum of objects involved in a collision?
The momentum of an object is calculated by multiplying its mass by its velocity. In a collision, the momentum of each object is conserved, meaning that the total momentum before the collision is equal to the total momentum after the collision.
What is the law of conservation of momentum?
The law of conservation of momentum states that the total momentum of a closed system (a system in which no external forces are acting) is constant. This means that in a collision, the total momentum before the collision is equal to the total momentum after the collision.
Can you provide an example of a real-life collision?
One example of a real-life collision is a car crash. When two cars collide, the forces between them cause a change in their motion and can result in damage to the cars and injuries to the passengers. This is an example of an inelastic collision, as some kinetic energy is lost in the form of sound, heat, and deformation of the cars.
