Homework Help: Need help with acceleration problem
  1. Jan 25, 2008 #1
    You land on an unknown planet somewhere in the universe that clearly has weaker gravity than Earth. To measure g on this planet you do the following experiment: A ball is thrown upward from the ground. It passes a windowsill 15.0 m above ground and is seen to pass by the same windowsill 2.00 s after it went by on its way up. It reaches the ground again 5.00 s after it was thrown. Calculate the magnitude of g (the acceleration due to gravity) at the surface of this planet.
    I drew the picture and started to sole the problem this way but I keep getting the wrong answers. Any input would be greatly appreciated.
    to me the initial velocity after 2 seconds should be
    v=distance/time which is 15m/2sec so the initial velocity should be 7.5m/s at that point. So from here I used
    xf=1/2at^2+vit+xi
    15=1/2a(2)^2+(7.5)(2)+0
    a=-7.5
    I get a gravitational acceleration of -7.5m/s^2. I tried 7 a well thinking the magnitude would be positive. But both answers are wrong.
  3. Jan 25, 2008 #2
    Shooting Star
    The particle is undergoing accn; it's not traveling at a uniform velo. What you have used is valid if speed is const. Correct it.
    EDIT:
    After another read, it's never even said anywhere that it took 2 secs to travel 15 m. It crossed the window sill at t=t' traveling up and t=t'+5 going down.
    Use the eqns for motion under unifrom accn.
