Homework Help: Need help with declaration!
  1. Jul 25, 2011 #1
    library ieee;
    use ieee.std_logic_1164.all;
    entity miniproject is
    port (dg1, dg2 : in std_logic_vector (3 downto 0);
    led1, led2 : out std_logic_vector ( 6 downto 0);
    output :eek:ut std_logic(6 downto 0));
    end miniproject;
    architecture arc of miniproject is
    begin
    with dg1 select
    led1 <= "0010010" when "0010",
    "1001100" when "0100",
    "1111111" WHEN others;
    with dg2 select
    led2<= "0010010" when "0010",
    process( dg1,dg2 )
    begin
    if (dg1 = "0010" and dg2 = "0000") then
    led1 <= '0' ; led2 <= '0' ;
    elsif (dg1 = "0100" and dg2 = "0000") then
    else
    led1 <= '1'; led2 <= '1';
    end if;
    end process;
    end arc;
    Error (10380): VHDL error at miniproject.vhd(6): std_logic type is used but not declared as an array type
    Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 0 warnings
    Error: Processing ended: Tue Jul 26 09:21:14 2011
    Error: Elapsed time: 00:00:02
  3. Jul 25, 2011 #2
    The programme I want to do is using 8 inputs which represent 2 digits from 00 -99. Using 7- segments displays and Led1 and Led2 will light up when the values are "20" and "40". Hope you can help me.
  4. Jul 25, 2011 #3
    Need help with my lab!
    Question: 8 inputs are used to represent 2 digits from 00 to 99. Show the value on the 7-segment displays and the Led1 and Led2 will light up when the values are “20” and “40” respectively.
    My answer:
    library ieee;
    end miniproject;
    begin
    with dg1 select
    with dg2 select
    process( dg1,dg2 )
    begin
    else
    end if;
    end process;
    end arc;
    What is wrong? can anyone help me?? THX in advance. (If possible Help me edit)
  5. Jul 25, 2011 #4
    jtbell
    Staff: Mentor
    Just out of curiosity, what language is this? I don't recognize it.
    [added] OK, I see from the error message that it's VHDL. Carry on...
  6. Jul 26, 2011 #5
    Re: Need help with my lab!
    Perhaps you need to use "std_logic_vector" instead of "std_logic" in line 6 as you did in lines 4 and 5.
