NEED HELP with fortran compiler
  1. Aug 4, 2008 #1
    I am having trouble compiling code. Here's my code:
    PROGRAM Sample1
    IMPLICIT NONE
    ! Variables and constants
    INTEGER, PARAMETER :: n=1000, m=10
    INTEGER :: i
    REAL, DIMENSION (1: n) :: x
    REAL, DIMENSION (1:100, 1:m) :: y
    REAL, DIMENSION (1: m):: colavg
    INTEGER :: filestat, IO_stat_num
    ! Open file and Check for error
    OPEN( UNIT=10, FILE= 'Data1.txt', IOSTAT=filestat, STATUS='OLD')
    IF (filestat>0) THEN
    PRINT *, 'Error opening file. Error Code: ', filestat
    STOP
    ENDIF
    DO i=1, n
    READ (UNIT=10, FMT=101, IOSTAT=IO_stat_num) x(i)
    101 FORMAT (2F8.3)
    IF (IO_stat_num == 0) THEN
    CYCLE
    ELSEIF (IO_stat_num == -1) THEN
    PRINT *,'EOF at line ', i
    EXIT
    ELSEIF(IO_stat_num > 0) THEN
    PRINT *,'Non numeric data at line ', i
    EXIT
    ENDIF
    ENDDO
    CLOSE(UNIT=10)
    ! call sorting routine from book
    CALL shell (n,x)
    ! Create ten averaged bins
    y = RESHAPE(x,(/100,10/))
    colavg = sum( y, dim=1)
    colavg = colavg/100
    OPEN(UNIT=20, FILE='Bins1', STATUS='NEW')
    WRITE (UNIT=20) colavg
    CLOSE (UNIT=20)
    END PROGRAM Sample1
    SUBROUTINE shell(n,a)
    INTEGER n
    REAL a(n)
    INTEGER i,j, inc
    REAL v
    inc=1
    1 inc=3*inc+1
    if(inc.le.n) goto 1
    2 CONTINUE
    inc =inc/3
    DO i = inc+1, n
    v= a(i)
    j=i
    3 IF (a(j-inc).gt.v) THEN
    a(j)=a(j-inc)
    j=j-inc
    IF (j.le.inc) GOTO 4
    GOTO 3
    ENDIF
    4 a(j)=v
    ENDDO
    if(inc.gt.1) GOTO 2
    RETURN
    END
    Error reads:
    Begin scan
    amakedepend "@/Users/sbraswell/Release/mkdep_F95"
    Scan completed
    Begin build
    f95 -c -nowdir -mrwe -m32 -O2 -o "./Release/simple.o" "../../Applications/Absoft10.1/examples/simple.f95"
    f95 -c -nowdir -mrwe -m32 -O2 -o "./Release/sample1.o" "Desktop/sample1.f90"
    f95 -lmrwe -framework Carbon -laf90math -lafio_carbon -lmrwe -lafio_carbon -lamisc -labsoftmain_mrwe -laf77math -lm -lmv -osxtarget=10.4 -m32 -O2 "./Release/simple.o" "./Release/sample1.o" -o "./sample.app/Contents/MacOS/sample"
    /usr/bin/ld: multiple definitions of symbol ABSOFT_IO_INITIALIZE
    ./Release/simple.o definition of ABSOFT_IO_INITIALIZE in section (__DATA,__data)
    ./Release/sample1.o definition of ABSOFT_IO_INITIALIZE in section (__DATA,__data)
    /usr/bin/ld: multiple definitions of symbol _MAIN__
    ./Release/simple.o definition of _MAIN__ in section (__TEXT,__text)
    ./Release/sample1.o definition of _MAIN__ in section (__TEXT,__text)
    collect2: ld returned 1 exit status
    Make:
    *** Error code 256 from f95
    link failed.
    Build interrupted
    PLEASE HELP
  3. Aug 5, 2008 #2
    It appears to be compiling two files: simple.f95 and sample1.f90.
    Which gives it two _MAIN_ modules which the linker doesn't like.
    Is there something wrong with your make or project file?
  4. Aug 5, 2008 #3
    Thanks..I didn't realize it was trying to compile 2. My first time using fortran.
Loading...
