- #1
shenie
- 3
- 0
I am having trouble compiling code. Here's my code:
PROGRAM Sample1
IMPLICIT NONE
! Variables and constants
INTEGER, PARAMETER :: n=1000, m=10
INTEGER :: i
REAL, DIMENSION (1: n) :: x
REAL, DIMENSION (1:100, 1:m) :: y
REAL, DIMENSION (1: m):: colavg
INTEGER :: filestat, IO_stat_num
! Open file and Check for error
OPEN( UNIT=10, FILE= 'Data1.txt', IOSTAT=filestat, STATUS='OLD')
IF (filestat>0) THEN
PRINT *, 'Error opening file. Error Code: ', filestat
STOP
ENDIF
DO i=1, n
READ (UNIT=10, FMT=101, IOSTAT=IO_stat_num) x(i)
101 FORMAT (2F8.3)
IF (IO_stat_num == 0) THEN
CYCLE
ELSEIF (IO_stat_num == -1) THEN
PRINT *,'EOF at line ', i
EXIT
ELSEIF(IO_stat_num > 0) THEN
PRINT *,'Non numeric data at line ', i
EXIT
ENDIF
ENDDO
CLOSE(UNIT=10)
! call sorting routine from book
CALL shell (n,x)
! Create ten averaged bins
y = RESHAPE(x,(/100,10/))
colavg = sum( y, dim=1)
colavg = colavg/100
OPEN(UNIT=20, FILE='Bins1', STATUS='NEW')
WRITE (UNIT=20) colavg
CLOSE (UNIT=20)
END PROGRAM Sample1
SUBROUTINE shell(n,a)
INTEGER n
REAL a(n)
INTEGER i,j, inc
REAL v
inc=1
1 inc=3*inc+1
if(inc.le.n) goto 1
2 CONTINUE
inc =inc/3
DO i = inc+1, n
v= a(i)
j=i
3 IF (a(j-inc).gt.v) THEN
a(j)=a(j-inc)
j=j-inc
IF (j.le.inc) GOTO 4
GOTO 3
ENDIF
4 a(j)=v
ENDDO
if(inc.gt.1) GOTO 2
RETURN
END
Error reads:
Begin scan
amakedepend "@/Users/sbraswell/Release/mkdep_F95"
Scan completed
Begin build
f95 -c -nowdir -mrwe -m32 -O2 -o "./Release/simple.o" "../../Applications/Absoft10.1/examples/simple.f95"
f95 -c -nowdir -mrwe -m32 -O2 -o "./Release/sample1.o" "Desktop/sample1.f90"
f95 -lmrwe -framework Carbon -laf90math -lafio_carbon -lmrwe -lafio_carbon -lamisc -labsoftmain_mrwe -laf77math -lm -lmv -osxtarget=10.4 -m32 -O2 "./Release/simple.o" "./Release/sample1.o" -o "./sample.app/Contents/MacOS/sample"
/usr/bin/ld: multiple definitions of symbol ABSOFT_IO_INITIALIZE
./Release/simple.o definition of ABSOFT_IO_INITIALIZE in section (__DATA,__data)
./Release/sample1.o definition of ABSOFT_IO_INITIALIZE in section (__DATA,__data)
/usr/bin/ld: multiple definitions of symbol _MAIN__
./Release/simple.o definition of _MAIN__ in section (__TEXT,__text)
./Release/sample1.o definition of _MAIN__ in section (__TEXT,__text)
collect2: ld returned 1 exit status
Make:
*** Error code 256 from f95
link failed.
Build interrupted
PLEASE HELP
PROGRAM Sample1
IMPLICIT NONE
INTEGER :: i
STOP
ENDIF
DO i=1, n
101 FORMAT (2F8.3)
CYCLE
EXIT
EXIT
ENDIF
ENDDO
CLOSE(UNIT=10)
CALL shell (n,x)
colavg = colavg/100
CLOSE (UNIT=20)
END PROGRAM Sample1
INTEGER n
REAL a(n)
INTEGER i,j, inc
REAL v
inc=1
1 inc=3*inc+1
if(inc.le.n) goto 1
2 CONTINUE
inc =inc/3
DO i = inc+1, n
v= a(i)
j=i
a(j)=a(j-inc)
j=j-inc
GOTO 3
ENDIF
4 a(j)=v
ENDDO
if(inc.gt.1) GOTO 2
RETURN
END
Error reads:
Begin scan
Scan completed
Begin build
Make:
link failed.
Build interrupted
PLEASE HELP
