Need help with Logs
  1. Apr 22, 2016 #1
    (1/25)^x+3=125^x+3
    2. Relevant equations
    I have used log on both sides but keep getting an incorrect answer.
    3. The attempt at a solution
    How would solve this type of equation. I set the bases both to 5, make them equal to each other and i cant get the right answer.
  3. Apr 22, 2016 #2
    Math_QED
    Is the + 3 in the exponent? If not you can substract it from both sides.
  4. Apr 22, 2016 #3
    SammyS
    Staff Emeritus
    If the exponent DOES include the + 3 , then the whole exponent should be enclosed in parentheses.
    We follow standard Order of Operations here at PF .
  5. Apr 22, 2016 #4
    yes the +3 is in the exponent. So i should put the whole thing in parentheses.
  6. Apr 22, 2016 #5
    Math_QED
    Make the substitution k = x + 3, then take the log of both sides.
  7. Apr 22, 2016 #6
  8. Apr 22, 2016 #7
    what is k. Is that the (1/25)?
  9. Apr 22, 2016 #8
    Math_QED
    So the equation is:
    (1/25)^(x+3) = 125^(2x) ?
    EDIT: The equation you initially posted seems to be not the same as the one you wrote down here. Never mind what I said about substitution.
  10. Apr 22, 2016 #9
    yes that is the equation my apologies.
  11. Apr 22, 2016 #10
    Mark44
    Staff: Mentor
    What you wrote in the first post is different from the image in your later post.
    The equation apparently is ##(\frac 1 {25})^{x + 3} = 125^{2x}##
    Link to our LaTeX primer: https://www.physicsforums.com/help/latexhelp/
  12. Apr 22, 2016 #11
    the equation (1/25)^(x+3)= 125^2X thats the equation on the paper.
  13. Apr 22, 2016 #12
    sorry i didnt click on the link before i replied i will use the Latex thing next time.
  14. Apr 22, 2016 #13
    Math_QED
    Regarding your equation. You must have seen that 1/25 and 125 can be written as 5^(-2) and [itex]5^3[/itex]
    Rewrite your equation with this. Post what you get then.
  15. Apr 22, 2016 #14
    SammyS
    Staff Emeritus
    If you write expression in that "in-line" sort of format, please use adequate parentheses.
    For example:
    (1/25)^(x+3)= 125^(2x)​
  16. Apr 22, 2016 #15
    I make it 5^(-2)(X+3)=5^(3)(2x) and this is where I think I mess up. I multiply the numbers in parentheses
  17. Apr 22, 2016 #16
    Math_QED
    Now use: [itex](a^b)^c [/itex] = a^(bc)
  18. Apr 22, 2016 #17
    SammyS
    Staff Emeritus
    f(x) = 5x is a one-to-one function.
    Therefore, just equate the arguments of the two sides.
  19. Apr 29, 2016 #18
    Sorry for starting up this thread again, but what do I put in that equation. Like is 5=A, I don't understand what numbers to plug in.
  20. Apr 29, 2016 #19
    Math_QED
    You can ignore that. Once you have the expression in #16, you can say make an equation where you say the exponents are equal. (Do in fact you take the 5 bases log of what's left and right from the equality sign. Once you do that, you get an easy equation in x to solve. Let us know when you found the answer :)
  21. Apr 30, 2016 #20
    NascentOxygen
    Staff: Mentor
    Yes, but incorporating the extra necessary parentheses as SammyS corrected for you in post #18.
    Please apply more care in your future threads. Careless mistakes and omissions in presentation don't give confidence that you are valuing the assistance of forum helpers.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Need help with Logs
  1. Help with a log (Replies: 6)
  2. Help with logs! (Replies: 2)
  3. Logs math help (Replies: 2)
  4. Log subtraction help (Replies: 5)
  5. Log equations help! (Replies: 10)
Loading...
