Calculating Net Force: 930kg Car & 320kg Trailer with 2.16 m/s2 Acceleration
In summary, the net force on the car is 930 x 2.16 N, as the friction force on the car and the force exerted by the trailer on the car cancel out. However, when considering the car and trailer as one system, the net force is (930 + 320) x 2.16 N, as the force exerted by the trailer on the car is in the opposite direction. Drawing a diagram of the forces can help clarify this concept.
frosti
A 930 kg car is pulling a 320 kg trailer. Together the car and trailer move forward with an acceleration of 2.16 m/s2. Ignore any frictional force of air drag on the car and all frictional forces on the trailer. determine the net force on the car.
f = ma
I thought the forces that are acting on the car is a force moving car forward and a force applied by the trailer slowing the car down so the net force on the car should be 930 x 2.16 - 320 x 2.16 = 1317.6. However, it is wrong. I don't really know how to think about this problem, can anyone please provide me with some insight?
I believe you're over thinking this one. The problem clearly states to ignore any frictional force of air drag or frictional forces of the trailer. Therefore, thinking about the system as a whole, the net force would simply equal the mass of the system as a whole times the acceleration of the system.
F=ma
jenglish is wrong, frosti is getting there, kind of: there is one friction force pushing the car forward, and a force exerted by the trailer on the car, backward. But there is also a force on the trailer forward. Draw a pucture with these 3 forces, and you 'll find the answer.
those two "extra" forces you mentioned are the tension on the connecting cable...they should ultimately cancel
No: the question is about the net force on the car, which includes the force the trailer (or the connecting cable if you wish) exerts. The net force on the car is not equal to "the mass of the system times the acceleration of the system": the latter quantity would be the net force on the system of car + trailer, not the net force on the car.
In any case, the question is simple, but not in that way.
thank you for your reply guys.
borgwal, don't force exerted by the trailer on the car backward and the force on the trailer forward on the car cancel out? so all that left me is one force 930 x 2.16?
jenglish, you are saying the net force should be (930 + 320) x 2.16 right? but why would the net force on the car also include mass of the trailer?
I'm confused here on which one sounds more right. Could you guys elaborate a bit more?
Yes, the net force on the car is simply 930 x 2.16 9 (it's simple after all). There is no force the trailer exerts on the car in the forward direction, only one in the backward direction. Since the net force on the total system [a friction force on the car, in the forward direction] is (930+320) x 2.16 it means the trailer is pulling back the car with a force 320 x 2.16, and the car is pulling the trailer forward with that same force in the opposite direction [its an action-reaction pair]. If you draw all the forces it will be clearer, I suppose.
I suppose I didn't read this question thoroughly enough, assuming it was asking for the force on the system
By the way: the action-reaction pair of forces cancels out only when the car and trailer are seen as 1 system. When considering the car by itself there is no such cancellation.
thank you guys so much. I got it now.
1. What is net force?
Net force is the overall force acting on an object. It is the sum of all the forces acting on the object, taking into account both magnitude and direction.
2. How do you calculate net force?
To calculate net force, you must first identify all the forces acting on an object and their respective magnitudes and directions. Then, add all the forces together, taking into account their directions. The resulting sum is the net force.
3. What is the difference between net force and individual forces?
The main difference between net force and individual forces is that net force takes into account all the forces acting on an object, whereas individual forces only consider one specific force. Net force is the overall effect of all the forces combined, while individual forces act independently on an object.
4. How does net force affect an object's motion?
The net force acting on an object determines its acceleration, which in turn affects its motion. If the net force is zero, the object will remain at rest or continue moving at a constant velocity. If the net force is not zero, the object will accelerate in the direction of the net force.
5. Can net force be negative?
Yes, net force can be negative. The negative sign indicates that the force is acting in the opposite direction of the positive direction. It is important to take into account the direction of each force when calculating net force to accurately represent the overall effect on the object.
16K
