What Does dp/dr Represent in Physics?
  • Thread starter Brad_Ad23
In summary, the conversation discusses the equation for momentum, p=mv, and its physical representation in different scenarios. The concept of dp/dr, the change in momentum with respect to distance, is also explored and its relation to force and velocity is discussed. It is clarified that dv is not equal to dr/dt, and that this equation only applies to 1-dimensional motion. In 2-dimensional motion, another coordinate, such as angle theta, is needed to determine the velocity.
Brad_Ad23
502
Ok, we are given the known equation that momentum = mass times velocity.
p=mv.
What is dp/dr physically representing?
Given:
r = position.
dr/dt = v.
so
p = mdr/dt.
dp/dr = m/dt ? If so, that remains constant (or zero?) correct?
Okay, momentum equals mass times velocity.
(That's basically the definition of momentum rather than a "known equation".)
p= mv.
IF m is a constant then dp/dt= m dv/dt= m a (mass times acceleration).
If m is not a constant (a very important consideration) then
dp/dt= m dv/dt+ dm/dt v.
dp/dt is, of course, "force"- that's basically, the definition of force.
dp/dr= (dp/dt)(dt/dr) (chain rule) or
dp/dr= (dp/dt)/(dr/dt)= (1/v)*force
Assuming constant mass, dp/dr= (m a)/v
I don't know that that "physically represents" anything in particular. I'm pretty sure it doesn't have a specific name.
As far as "dp/dr = m/dt" is concerned, that makes no sense at all- you have an "unattached" dt on the right.
That's what I am all confused about. Whether it represents anything at all, or if it will be a constant. A better way to visualize this is to imagine the mass is in an orbit.
This is the force law for a rocket. The force dp/dt has rwo components, current mass times acceleration (m dv/dt) and rate of change of mass times current speed (v dm/dt). This latter is due to the exhaust; dm/dt is the rate that reaction mass is being shot out the back. Note that the higher v is, the more that a given dm/dt contributes to the force on the rocket.
Yes, that much I knew. But this is the question:
p =mv.
dp/dt =mdv/dt (m is constant in this case)
dp = mdv
dp/dr = mdv/dr
Now, dv = dr/dt so we get 1/dt
dp/dr = m/dt.
I am just interested in this. The change in momentum with respect to distance, or mass with respect to time. In an orbit (notice this condition) would this quantity whatever it is, be constant, or zero?
You can't just divide out the dr's. derivatives like dr/dt aren't quotients exactly, they are the limits of quotients. It's allowable to multiply through, such as dr/dt = K, yields dr = Kdt ready for integration, but dividing out doesn't make sense.
Alright then.
dp = mdv
What does
dp/dr = mdv/dr represent?
First, about calculus:
You said dv=dr/dt. That is quite wrong. v=dr/dt (as you said in a previous post). Therefore, dv=d(dr/dt)=d^2r/dt. So you are misunderstanding the math.
Now about physics:
You are using v=dr/dt. This is only true for 1-dimensional motion, for example, a mass moving along a straight line. In that case, what Hallsofivy said is right. dp/dr=F/v; in words, dp/dr is the ratio of force applied, to the velocity attained. It's not zero and not constant. For example, if the force is pushing the mass in the direction opposite to its motion, the mass will slow down, stop, and reverse. At the point at which it has stopped, v=0 so dp/dr=F/v is infinite.
Now about orbits:
If you are thinking of something like a central force problem like planetary motion, and r is the distance between the masses, then the speed v is NOT dr/dt in general. The motion is 2-dimensional so you need another coordinate besides r to locate the mass. Usually use angle theta. Then the velocity has 2 components, dr/dt and
r*d(theta)/dt, and v is the square root of the sum of the squares of these 2 components.
Got it, thanks!
as for the dv = dr/dt thing, that was a mistype on my part. I was getting a bit type happy with d's and other things. Sorry for the math error!
1. What is the first step in getting help with something odd?
The first step is to clearly explain the issue or problem you are experiencing. This will help the person trying to help you understand the situation and provide the most effective assistance.
2. Is it important to provide details when asking for help with something odd?
Yes, providing specific and relevant details will greatly improve the chances of getting helpful responses. Make sure to include any relevant background information, steps you have already taken, and any error messages you have received.
3. How can I find someone who can help me with something odd?
There are a few options for finding help. You can reach out to friends or colleagues who may have experience with similar issues, search online forums or communities for experts in the topic, or consult with a professional in the field.
4. What should I do if the first solution suggested does not work?
If the first solution does not work, it is important to provide feedback and any new information. This will help the person trying to assist you to understand the problem better and provide alternative solutions.
5. How can I prevent similar odd issues from occurring in the future?
To prevent similar odd issues from occurring in the future, it is important to document the steps taken to resolve the issue and any relevant information. This will serve as a reference for future troubleshooting and can also be shared with others who may encounter similar problems.
