Need Help with the Logic of my Program
  1. Aug 9, 2009 #1
    This is VBA Excel:
    Here is what I am trying to do. I have a MathML file saved as a .txt file. It is simialr to XML.
    From the XML file, we have a bunch of text that looks something like:
    <mname>Salad</mname><mrow>xyz</mrow>
    I would ultimately like to have an array whose elements are the substrings:
    Array(1) = <mname>
    Array(2) = Salad
    Array(3) = </mname>
    So far what I have done is this
    Load the entire text file into one continuous string.
    I have then fed the string into an array called ElementaryArray such that each individual character of the giant string is an element of the array.
    Now I would like to sweep through the array, element by element, and determine the start and end positions of each substring.
    If it were simply a bunch of substrings like <mmm><mmm><rrr><rrr><ooo><ooo> it would be easy enough. I could simply find the first "<" and then find its corresponding closing ">" and then restart the loop at the ">" position.
    The problem is that not all of the strings start and end with the "<" & ">" characters.
    I need a way to determine if the character after a ">" is another "<" or not. And then if it is not another "<" I must mark that character's position and then find the next occurrence of "<" which will be the end position (+1) of the substring that does not start with a "<".
    Does that all make sense :smile: The tricky part is relating the two different cases via the counter such that I do not get any overlap.
    Any ideas?
  3. Aug 9, 2009 #2
    I am of course also open to suggestions of alternative approaches to this problem.
  4. Aug 9, 2009 #3
    Don't try to hack up a parser by yourself. Use an XML parser library (MathML is XML).
  5. Aug 9, 2009 #4
    Is that your suggestion? Because that was not what I had in mind when I said I was open to suggestions. :wink:
    Also, what does that mean?
  6. Aug 9, 2009 #5
