Need help
  1. Jul 28, 2005 #1
    need help, VERY CHALLENGING
    a hemispherical tank of radius 6 meters, is posiitoned so that its base is circular. how much work is required to empty the tank?
    liquid density is 100 kg/ m^3
  3. Jul 28, 2005 #2
    i use equation of a circle to calculate the radius
    circle is
    [tex]x^2 + (y-6)^2=6^2=36[/tex]
    therefore
    [tex]r=\sqrt {36 - (y-6)^2} [/tex]
    [tex]volume= \pi r^2 [/tex]
    F=mg
    F=vol * density * gravity
    [tex]9.8 * 100 * \pi \int_0^6 (36 - (y-6)^2)y dy[/tex]
    ansewr i get is: 16625308 joules
  4. Jul 29, 2005 #3
    HallsofIvy
    I presume you mean "the radius of the circle formed by the surface of the water at different heights".
    And, by the way, the problem is not "well formed". If you just punch a hole in the bottom, the tank will empty without any work being done. I presume that the problem says to empty the tank by pumping it out the top.
    Here's how I would think about it:
    Of course, the work done lifting a mass m a height h is mgh. Imagine a "layer of water" of thickness dz at height z. That layer will be a circle of radius, say, r. It will have volume [tex]\pi r^2 dz[/tex] and so weight [tex]98\pi r^2dz[/tex]. That water has to be lifted a distance 6-z to the top of the tank: the work done on that one "layer" of water is [tex]\pi (6-z)r^2 dz[/tex].
    Now we need to determine r2: x2+ y2+ z2= 36. Since r is measured parallel to the xy-plane, r2= x2+ y2= 36- z2. Putting that into the formula above:
    [tex]\pi (6-z)(36-z^2)dz[/tex].
    We need to integrate that from z= 0 to z= 6 to cover the entire tank:
    [tex]\int_0^6\pi(6-z)(36-z^2)dz= \pi\int_0^6(216- 36z-6z^2+ z^3)dz[/tex].
    That is not what you have. Did you forget the height lifted?
  5. Jul 29, 2005 #4
    yes i meant to say the work needed to pump out water from the top.
    i don't think you did it correctly. i inverted my coordinates upside down so that the +y direction is towards the base of the hemisphere, also there's no need to use spherical coordinates, using 2-d is simpler. W=F*D, my D (dist) is y. i start out pumping the top layer, then i move down to the bottom layer. as i pump out each layer the water travels a distance of y from the origin. origin is the top of the tank.
    i'm surprised that i only received one response, i thought everybody in the math forum was good at this stuff.
Similar Discussions: Need help
  1. Need help (Replies: 1)
  2. Need help (Replies: 6)
  3. Need help (Replies: 5)
  4. Need help (Replies: 6)
Loading...
