Need outputs for fortran 77 programs
  1. Feb 9, 2009 #1
    hi
    i need fortran program outputs very urgently.
    i have the programs , but i'll not able to run the compiler.
    can someone please post the complete outputs for these programs..
    THANK YOU
    Code (Text):
    Program 15:
    Program to interpolate a value of dependent variable ‘y’ for a given value of independent ‘x’ using Lagrangian Interpolation Method
        real y [allocatable](:), x [allocatable](:)
        real product, sum, xx
        integer n, i, j, error
        write (*, ‘(1x,a\)’) ‘Number of tabulated points (n): ’
        read (*,*) n
        allocate (x (n), y(n), stat = error)
        if (error .ne. 0) stop ‘Not enough memory’
        write (*, ‘(/1x, a, i2, a)’) ‘Enter ‘,n,’ pairs of (x,y)’
        read (*,*) ( x(i), y(i), i =, n)
        write (*, ‘(1x, a\)’) ‘Enter value of x for interpolation: ’
        read (*,*) xx
        if ((xx .lt. x(1)) .or. (xx .gt. x(n))) then
            stop ‘Value outside tabulated range’
        endif
        sum = 0.0
        do i = 1, n
            product = 1.0
            do j = 1, n
                if (i .ne. j) then
                    product = product * ((xx-x(j))/(x(i)-x(j)))
                endif
            enddo
            sum = sum + y(i) * product
        enddo
        write (*,50) sum, xx
    50  format (1x, ‘Interpolated value of y =’, f8.3, ‘for x = ’, f6.3)
        deallocate (x, y, stat = error)
        if (error .ne. 0) stop ‘Error in releasing memory’
        end
    Output:
    Program 16:
    Program to find the solution of a linear system of equations by Gauss Jordan method
    real a [allocatable] (: , :)
    integer n, k, i, j, error
    write (*, ‘(1x,a\)’) ‘Enter number of equations (n): ’
    read (*,*) n
    allocate (a(n, n+1), x(n), stat = error)
    write (*,*) ‘Enter coefficients equation wise’
    read (*,*) ((a(i,j), j = 1, n+1), i = 1, n)
    do k = 1, n
        temp = a (k,k)
        if (temp .eq. 0) stop ‘Pivot element becomes zero’
        do j = k, n+1
            a (k,j) = a (k,j)/temp
        enddo
        do i = 1, n
            if (i .ne. k) then
                temp = a (i,k)
                do j = k, n+1
    a (i.j) = a (i,j) - temp * a (k,j)
                enddo
            endif
        enddo
    enddo
    write (*,*) ‘The solution of the system of the equations is: ’
    do i = 1, n
        write (*, ‘(1x, ‘x(‘, i2, ’) = ‘, f7.3)’) i, a(i, n+1)
    enddo
    deallcoate (a, stat = error)
        end
    Output:
    Program 17:
    Program to find the solution of a linear system of equations by Gauss-Elimination method
    Equation:-
    real a [allocatable] (: , :), x [allocatable] (:), temp1, temp2
    real sum
    read (*,*) n
    do k = 1, n-1
        temp1 = a (k,k)
        if (temp1 .eq. 0) stop ‘Zero division’
        do i = k+1, n
            temp2 = a (i,k)/temp1
            do j = k, n+1
                a (i.j) = a (i,j) - temp2 * a (k,j)
            enddo
        enddo
    enddo
    x(n) = a(n,n+1)/a(n,n)
    do i = n-1, 1, -1
        sum = 0.0
        do j = i+1, n
            sum = sum + a(i,j) * x(j)
        enddo
        x(i) = (a(i,n+1)-sum)/a(i,i)
    enddo
    write(*,*) ‘Solution of the system of the equations is: ’
    do i = 1, n
        write (*,15) i, x(i)
    15      format (1x, ‘x(‘, i2, ’) = ’, f7.3)
        enddo
        deallcoate (a, x, stat = error)
        end
    Output:
    Program 18:
    Program to integrate a known function using Trapezoidal Rule
        real a, b, sum, h, integral, f
        integer n, i
        f(x) = x + 5
        write (*, ‘(1x, a\)’) ‘Lower limit of integration (a): ’
        read (*,*) a
        write (*, ‘(1x, a\)’) ‘Upper limit of integration (b): ’
        read (*,*) b
        write (*, ‘(1x, a\)’) ‘Number of intervals (n): ’
        read (*,*) n
        h = (b-a)/n
        sum = (f(a) + f(b))/2
        do i = 1, n-1
            sum = sum + f(a+i*h)
        enddo
        integral = h*sum
        write (*, ‘(//1x, a, f6.3)’) “Value of integral: ”, integral
        end
    OUTPUT:-
    Program 19:
    Program to integrate a known function using Simspon’s 1/3rd Rule
        real a, b, sum, sum2, sum4, h, integral, f
        integer n, i
        f(x) = x**2+3*x+5
        read (*,*) a
        read (*,*) b
        read (*,*) n
        h = (b-a)/n
        sum = f(a) + f(b)
        sum2 = 0
        sum4 = 0
        do i = 1, n-2, 2
            sum4 = sum4 +f(a+i*h)
            sum2 = sum2 +f(a+(i+1)*h)
        enddo
        integral  = (h/3)*(sum + 2*sum2 + 4*sum4)
        write (*, ‘(//1x, a, f6.3)’) “Value of integral =”, integral
        end
    OUTPUT:-
    Program 20:
    Program to solve a first order differential equation using Runge-Kutta (Heun’s) second order method
        real s1, s2, x1, xf, y1, x, y, h, f
        integer i
        f(x,y) = x*y
        write (*, ‘(1x, a\)’) ‘Starting solution point (x1,y1): ’
        read (*,*) x1,y1
        write (*, ‘(1x, a\)’) ‘Last point of the interval (xf): ’
        read (*,*) xf
        write (*, ‘(1x, a\)’) ‘Enter step size to be used (h): ’
        read (*,*) h
        x = x1
        y = y1
        i = 1
        write (*, ‘(//1x, a//)’) “Solution points”
        write (*, ‘(1x, 4x, i2, 5x, f6.3, 5x, f6.3)’) i, x, y
        do while (x .lt. xf)
            s1 = f(x,y)
            x= x+h
            s2 = f(x, y+h*s1)
            y = y+h*(s1+s2)/2
            i = i+1
        enddo
        end
    OUTPUT:-
    Program 21:
    Program for Bisection Method to find the root of the equation
    f(x) = x^4-x-10 = 0
    C   program BisectionMethod
    real x1, x2, x3, ep, f
    f(x) = x**4-x-10
    write (*,‘(1x,a\)’) ‘First point of search interval: ’
    read (*,*) x1
    write (*,‘(1x,a\)’) ‘Second point of search interval: ’
    read (*,*) x2
    write (*,’(1x,a\)’) ‘Enter permitted error: ’
    read (*,*) ep
    do while (abs(x1-x2) .gt. ep)
            x3 = (x1+x2)/2
            if (f(x1)*f(x2) .lt. 0) then
                x2 = x3
            else
                x1 = x3
            endif
    enddo
    write (*,‘(1x,a,f8.4)’) ‘Approximate Root: ’,x3
    end
    OUTPUT :-
    Program 22:
    Program for False Position Method to find the root of the equation
    f(x) = x^3-x-4 = 0
    C   program FalsePositionMethod
    f(x) = x**3-x-4
    read (*,*) x1
    read (*,*) x2
    read (*,*) ep
    write (*,’(1x,a\)’) ‘Enter lower bound on slope: ’
    read (*,*) delta
    f1 = f(x1)
    f2 = f(x2)
    do while (abs((x1-x2)/x2) .gt. ep)
            if (fabs(f2-f1) .le. delta) then
                print*, “Slope of the function becomes too small”
                stop
            endif
            x3 = (x1*f2-x2*f1) / (f2-f1)
            f3 = f(x3)
            if (f1*f3 .lt. 0) then
                x2 = x3
                f2 = f3
            else
                x1 = x3
                f1 = f3
            endif
    enddo
    end
    OUTPUT :-
    Program 23:
    Program for Newton Raphson Method to find the root of the equation
    f(x) = x^3-x-10 = 0
    program NewtonRaphsonMethod
    real x0, x1, ep, f, df, relerror, f0, df0
    integer I,n
    f(x) = x**3-x-10
    write (*,‘(1x,a\)’) ‘Enter starting approximation: ’
    read (*,*) x0
    read (*,*) ep
    read (*,*) delta
    write (*,‘(1x,a\)’) ‘Enter maximum iterations permitted: ’
    read (*,*) n
    do i = 1, n
            f0 = f(x0)
            df0 = df(x0)
            if (abs(df0) .le. delta) then
                stop
            endif
            x1 = x0–f0/df0
            relerror = abs((x1-x0)/x1)
            x0=x1
            if (relerror .le. ep) then
                write (*,10) i
    10          format (//1x,‘Solution converges in ’, i2,‘iterations’)
                write (*,‘(1x,a,f8.4)’) ‘Approximate Root: ’,x1
                stop
            endif
    enddo
    write (*,20) n
    20  format (//1x,‘Solution does not converge in ’, i2,‘iterations’)
    end
    OUTPUT :-
    Program 24:
    Program to solve a first order differential equation using Runge-Kutta fourth order method
        real s1, s2, s3, s4, x1, xf, y1, x, y, h, f
        integer i
        f(x,y) = x*y
        read (*,*) x1,y1
        read (*,*) xf
        read (*,*) h
        x = x1
        y = y1
        i = 1
            s1 = f(x,y)
            s2 = f(x+h/2, y+s1*h/2)
            s3 = f(x+h/2, y+s2*h/2)
            s4 = f(x+h, y+s3*h)
            x= x+h
            y = y+h*(s1+2*s2+2*s3+s4)/6
            i = i+1
        enddo
        end
    OUTPUT:-
    Program 25:
    Program to find the solution of a linear system of equations by Gauss Seidel method
    real sum, temp, big, absoluteerror, ep
    integer n, k, i, j, error, max
    read (*,*) n
    write (*,*) ‘Enter elements row wise’
    write (*, ‘(1x,a\)’) ‘Enter permitted error: ’
    read (*,*) ep
    write (*, ‘(1x,a\)’) ‘Enter maximum iterations permitted: ’
    read (*,*) max
    do i = 1, n
        x (i) = 0.0
    enddo
    do k = 1, max
            big = 0.0
            do i = 1, n
                sum = 0.0
                do j = 1, n
                    if (1 .ne. j) sum = sum+a(i,j)*x(j)
                enddo
                temp = (a(i,n+1) – sum)/a(i,i)
                absoluteerror = abs (x(i)-temp)
                if (absoluteerror .gt. big) big = absoluteerror
                x(i) = temp
            enddo
            if (big .le. ep) then
                write (*,100) k
    100         format (//1x, ‘Converges in’, i3, ‘iterations’)
                write (*, ‘(1x, a//)’) ‘The computed solution is: ’
                do i =1, n
                    write (*, ‘(1x, ‘x(‘, i2,’) = ‘, f7.3)’) i, x(i)
                enddo
                stop
            endif
        enddo
        write (*,200) max
    200 format (//1x, ‘Does not converge in ’, i3, ‘iterations’)
        end
    Output:
Draft saved Draft deleted
Similar Discussions: Need outputs for fortran 77 programs
  1. Fortran 77 output bugs (Replies: 2)
  2. Fortran 77 (Replies: 1)
Loading...
