Where Can I Find Top-Notch IR Sensor Solutions for My System?
In summary, Google suggests that people look into companies like Nanometrics or IRIS. Nanometrics manufactures pixel-pitch-sized IR sensors, while IRIS is known for its 4x4 and 2x2 arrays. Both companies offer analog outputs, operate at frequencies up to 1kHz, and have a D* of 1E8. IRIS has a shorter time constant (25ms) than Nanometrics' (30ms), but both are capable of detecting radiation at a range of wavelengths from 8-14 um.
Bruce Chuang
Hello, Every member:
We need to IR sensor solution for our system.
Please, connect to me If you know any company of product or maker about the IR sensor.
Required specifications are as follows: (ps: choose one of the following five.)
1. Thermopile array #1:
a. Pixel pitch: 0.6 mm
b. Array type: 2 x 4 or 4 x 4
c. Sensing wavelength: 8 ~ 14 um
d. Output type: analog for every element
e. Element parameter:
i. Element size: 0.5 mm x 0.5 mm
ii. Sensitivity: 60V/W for 8~14um
iii. Resistance: 80kΩ
iv. Noise: 36 nV/√Hz
v. D*: 0.9E8 for 1Hz
vi. Time constant: < 6ms
2. Thermopile array #2:
a. Pixel pitch: 1.1 mm
b. Array type: 2 x 2
i. Element size: 1 mm x 1 mm
ii. Sensitivity: 50V/W for 8~14um
v. D*: 1.3E8 for 1Hz
vi. Time constant: < 10ms
3. Pyroelectric array:
d. Amplifier: with integrated voltage mode amplifier (ex. FET), every element
e. Operate frequency: 1Hz ~ 5kHz
f. Output type: analog for every element
g. Element parameter:
ii. Sensitivity: 120V/W for 1kHz and 8~14um
iii. Output impedance: ~100kΩ
iv. NEP: 3.8E-10W/√Hz
v. D*: 2.5E8 for 1kHz
vi. Time constant: < 25ms
4. Bolometer array:
a. Pixel pitch: 0.3 mm
b. Array type: 8 x 8
d. Operate frequency: 1Hz ~ 5kHz
e. Output type: analog for every element
f. Element parameter:
i. Element size: 0.25 mm x 0.25 mm
ii. Sensitivity(before readout gain, 2V, 0Hz): 100,000V/W
iii. NETD(f/1, 300K, 30Hz): < 10mK
iv. D*: 8E8
v. Time constant: < 15ms
5. MCT(HgCdTe) or PbSe or InSb:
a. Sensor type: one element
b. Sensing wavelength: 3 ~ 5 um(cut-off λ= 4.9 ~ 6 um)
c. Element parameter:
i. Element size: 0.5 mm x 0.5 mm or 1 mm x 1 mm
ii. D*: 1E10
iii. Cooling: None or Built-in TEC type (Up to two TEC)
If you have any question, welcome to contact me.
Best Regards~
Bruce
Dr. Courtney said:
Google is your friend here.
Dear Dr. Courtney:
Thanks for your reply~!
Ya~ I know google is my good friend, but I want to know some relatively unknown or non-popular company however they have top-notch of the IR sensor technology. If they have the product of my needs or depending on the specification to customize that will be very wonderful.
What is an IR sensor?
An IR sensor, also known as an infrared sensor, is a device that uses infrared radiation to detect and measure the surrounding environment. It can sense various types of objects and materials, and is often used in scientific and industrial applications.
What is the purpose of an IR sensor?
The main purpose of an IR sensor is to detect and measure the presence or absence of objects or materials. It can also be used to measure temperature, motion, and distance. Additionally, IR sensors are commonly used in automation, security, and remote control systems.
How does an IR sensor work?
An IR sensor works by emitting and receiving infrared radiation. The sensor emits light in the infrared spectrum, which is then reflected off objects and detected by the sensor. The sensor measures the intensity of the reflected light and converts it into an electrical signal, which can then be interpreted by a microcontroller or other device.
What are the advantages of using an IR sensor solution?
There are several advantages to using an IR sensor solution. First, IR sensors can detect objects and materials that are not visible to the human eye. They are also highly accurate and can be used in a variety of environments and conditions. Additionally, IR sensors are relatively inexpensive and have a long lifespan, making them a cost-effective solution for many applications.
What are some common applications of IR sensors?
IR sensors have a wide range of applications, including object detection and counting, temperature measurement, motion sensing, and distance measurement. They are also used in security systems, robotics, and household appliances. In the scientific field, IR sensors are commonly used in spectroscopy, environmental monitoring, and medical imaging.
  • Science and Math Textbooks
17K
