Is Negative Kinetic Energy Real in Quantum Systems?
In summary, the concept of negative kinetic energy can arise in quantum tunneling and other quantum models, where the particle's wave-like properties allow it to pass through a potential barrier. However, this is in violation of classical physics and the uncertainty principle dictates that attempting to measure or observe negative kinetic energy leads to a very small tunneling probability. This concept has also been explored in the tachyon theory, where particles with negative mass can have negative energy.
Adrian Baker
378
Negative Kinetic Energy?
I have heard that in processes like quantum tunneling and other quantum models, the KE can be considered to be negative when compared to a classical system. (A very odd concept!)
I've tried searching the web, but only found one or two very technical sites that go way over my head..
Can anyone enlighten me on this please, or perhaps point me in the right direction?
perhaps this may help you..
In fact in tunneling effect we must take into account the term:
sqrt(E-V) so when tunneling V>E i think you misunderstood the terms
The energy is not negative but the factor (E-V)<0 (a classical forbidden region).
hope it helps...
If it were possible to measure the energy of a particle inside of a potential barrier (ewhich had tunnelled there) it would indedd be negative.
errr... thanks for the comments guys, but we are still a bit over my head!
Any chance of some more detail. [?]
Thanks
Quantum mechanics can be pretty counterintuitive sometimes! Classically, if you have a potential barrier of height V and a particle incident on that barrier with E < V, the particle would reflect off the barrier completely.
The same system in quantum mechanics gives a non-zero probability that the particle will be transmitted through the barrier. This is a wave phenomenon, but in quantum mechanics particles exhibit wave-like properties.
So while the particle is tunneling, does it have negative KE? This would be in violation of classical physics, so there has to be a way to rectify this. What it comes down to is the condition required to observe the negative kinetic energy leads to an exceptionally small tunneling probability. The argument follows from the uncertainty principle. Even if you set up your system to maximize your chance to measure the negative kinetic energy, you would minimize the probability of the particle tunneling through your barrier!
The wavefunction of the tunneling particle decreases exponentially in the barrier. The tunneling probability is strongly dependent on the width of the barrier, the mass of the particle, and the quantity V-E. For instance, the ratio of tunneling probability for protons to electrons is around a factor of 10^-91. So electrons are much more likely(!) than protons at the same energy to tunnel through the same barrier. This also precludes you tunneling through your front door. :-)
Experimentally, tunneling does occur. Examples include nuclear alpha decay and Josephson junctions.
Is there an uncertainty principle that says this? Attempt to observe/measure negative KE => small tunneling probability? Elaboration please.
Thanks for that xeguy - it is appreciated.
I wouldn't say I fully understand it now , but I certainly now understand what it is that I don't know!
You're welcome, Adrian. If you take a QM course you'll have a better understanding of the concept.
You can do a calculation from the Heisenberg uncertainty relations. If tunneling occurs, you have to localize the particle in a range [del]x << (barrier width). From this you get a condition on [del]p, and hence [del]E. The uncertainty must be much less than |E-V|, where V is the height of your potential barrier, if you want to observe negative KE. The final relation you get is a condition on the exponent of the decaying exponential. The exponent must be >> 1 in order to observe this negative KE. Since the transmission probability depends directly on this term, it approaches zero.
it is possible to have negative energy. in some spatial anomalies like star going supernova and stuff, some particles were expelled at above c speed. then the tachyon theory came up, and (by that theory) if it has negative mass if must have negative energy (e=mc2, and mass isn't vector but scalar.)
In a quaint way what you don't see is what you get!
In e=mc2, space/ENERGY transforms into mass/ENERGY without the c2. The normal E=MC2 relates to 3-dimensional transformations, a deeper inquiry and one finds that Space(1-d negative matter) can transform into Matter(2-d negative space) or the Vacuum Force.
i see, thanks for replying. but i didnt invent tachyon theory, and one of reports from mathematical construction model of tachyon cleary stated that e=mc2 statement. and if something has a mass and velocity it has kinetic energy. in non-relativistic energy ranges we could apply e=(mv2)/2. but I am sure that more quantum laws interfere in that example than simple explanation between mass and energy.
if tachyons were real, it would be pretty handy to have'em around. lift your car into space, sit in it, and if it weights 1.5 tons, load 1.6 tons of tachyons into trunk. your mass is -100 kg, and off you go ;) (warp 9)
Humm..not so I am afraid! The technical difficulties would far outway the practical fuel consumption savings!
The main thing would be how do you "head-them-off-at-the-pass", as you would have to intercept Tachyons, you cannot 'load them prior'.
You would have to know well in advance 'where and when' they be?
heisenberg's postulate dictates that on that level of quantum engineering you can't know both where and when. and of course, i was joking about the faster-than-light car...
as for "engage" negative mass and "disengage" it wouldn't be so hard maybe. i read that bond between two tachyons is so strong that twists (?) laws of physics and mt=mt1+mt2=2mt1 doesn't apply. what applies is some strange stuff like mt=(mt1)^2. so they have positive mass because negative mass is squared. so for negative mass you would need to decouple them.
about tachyons they arent considered to be real. it's more like mathematical model of particle that has negative mass because it exists only in faster-than-light enviroment. even at fermilab they are ruled out.
1. What is Negative Kinetic Energy?
Negative kinetic energy is a concept in physics where the kinetic energy of a system is less than zero. It occurs when the velocity of an object is moving in the opposite direction of its momentum, resulting in a decrease in kinetic energy.
2. How is Negative Kinetic Energy calculated?
Negative kinetic energy can be calculated using the same formula as regular kinetic energy, which is 1/2 * mass * velocity^2. However, the velocity must be negative in order to result in a negative value for kinetic energy.
3. What causes Negative Kinetic Energy?
Negative kinetic energy can be caused by various factors such as a change in direction of motion, friction, or a collision with an object moving in the opposite direction. It can also occur when an external force is applied in the opposite direction of an object's motion.
4. Is Negative Kinetic Energy possible?
Yes, negative kinetic energy is a valid concept in physics and can occur in certain situations. However, it is not a common occurrence and is often only observed in theoretical scenarios or at the atomic level.
5. What are the implications of Negative Kinetic Energy?
Negative kinetic energy can have important implications in understanding the behavior of systems in physics. It can help explain the motion of objects in various scenarios, as well as the impact of external forces on a system. It is also a key concept in the study of thermodynamics and energy conservation.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Mechanics
