Negative Pressure: Is There Anything Below Total Vacuum?
In summary, negative pressure is not the same as a vacuum. A vacuum is zero pressure and there are no negative pressures below that, as it is impossible to have a pressure smaller than that of a perfect vacuum. However, in some contexts, people may use the term "pressure" to refer to the difference from atmospheric pressure, and in this case, any pressure lower than atmospheric is considered negative. In the fields of Engineering and Chemistry, negative relative pressure is possible, but in Physics, negative absolute pressure is only achievable in certain circumstances such as in tree sap or pure water under specific conditions. Overall, negative pressure and vacuum are not interchangeable terms.
qitara
Hi guys
Is there any thing such as Negative Pressure, or is there only total vacuum 0 and nothing below that ?
isn't a vacuum and negative pressure the same thing ?.
No, a vacuum is zero pressure and because you can't have a pressure smaller than that of a perfect vacuum, there are no negative pressures.
What's confusing you is that people often say "pressure" when they mean "difference from atmospheric pressure" - by that definition any "pressure" that is less than atmospheric is negative.
Likes 1 person
So it's just a way to say that the pressure is below the reference pressure ?
In almost all areas of Engineering and Chemistry, yes its relative pressure and it can be negative.
In some areas of Physics, it has an entirely different meaning. This is the second post I've answered in the last 10 minutes where the poster didn't explain in what context the term was being used in. *sigh* Unless you are dealing with quantum field theory, you can NOT have negative absolute pressure and you CAN have negative relative pressure (also known as "gauge pressure").
Term used in Engineering, but the picture is clear now thanks to you guys
There is no any perfect vacuum because if there is perfect vacuum than it will exert infinite force to fill it.
Consider the atmospheric at sea level (1atm) as the reference pressure.
Why do you think that?
Sure there are:
http://en.wikipedia.org/wiki/Pressure#Negative_pressures
When attractive forces (e.g., van der Waals forces) between the particles of a fluid exceeds repulsive forces due to thermal motion. These forces explain ascent of sap in tall plants. Negative pressure must exist at the top of any tree taller than 10 m, which is the pressure head of water that balances the atmospheric pressure. Van der Waals forces maintain cohesion of columns of sap that run continuously in xylem from the roots to the top leaves.
Chestermiller said:
This is just negative gage pressure (relative to 1 atm.). It is not negative absolute pressure.
This here is absolute negative pressure:
If you also want to count solids, and, if you define the pressure in a solid under tension as minus the isotropic part of the stress tensor, then, yes, you can have a "negative pressure" in a solid. Tree sap, which is a polymer solution, exhibits viscoelastic rheological behavior, which is a combination of viscous-fluid and solid behavior. So tree sap can also exhibit, to some degree, what would be defined as negative pressure. But ordinary Newtonian viscous gases and liquids are not viscoelastic, and do not exhibit negative pressure.
That wikipedia article is stretching things a bit by characterizing capillary action (which is what the tree is using to lift its sap above 10 meters) as negative absolute pressure. It's more akin to a mechanical system with a pump at the bottom... except that the pump is distributed all along the surface of the xylem cells. It's would be more accurate to say that at all points in the column the pressure is positive and greater than the weight of the fluid above that point.
However, I think that is all a second-order sort of subtlety when OP is asking "isn't a vacuum and negative pressure the same thing?".
Pure water can have negative absolute pressure too:
http://www.nature.com/nature/journal/v455/n7210/full/nature07226.html
No, it's not (just) capillary action (attraction by the walls), but actually negative absolute pressure (attractive forces between the water molecules).
That article is amazing, if correct. I've never heard of this type of thing before. Thanks for calling it to my attention. Maybe you can help me. What is it the enables the water to maintain this metastable state, and prevents it from cavitating? Is it somehow related to the small dimensions of the channel?
Chet
Chet
The article is correct. There is an excellent Veritasium video on youtube called "The Most Amazing Thing About Trees" about that topic. It's worth watching.
Here it is:
https://www.youtube.com/watch?v=BickMFHAZR0
According to the video the key is the lack of air bubbles see (3:33min). The article also discuses probability of cavitation.
That is not correct. the maximum negative pressure (what you are calling force) that can be exerted by a 'vacuum' is Atmospheric Pressure (1Bar). The force on a piston to produce a pressure of 0.01Bar is very little different than the force on a piston producing a pressure of 0.001Bar. The forces needed will be (the Piston area times 0.99 Bar) compared with (Piston area times 0.999 Bar) -i.e. virtually no difference at all.
It's not the need for a massive force that limits how deep a vacuum you can produce; it's the practical matter of how you can extract the molecules of a gas (air) out of a space without more molecules getting back in via the pump. Very low vacuums are limited by contamination by odd molecules coming of the insides of the chamber and pipes.
1. What is negative pressure?
Negative pressure is a condition in which the pressure of a system or space is lower than the surrounding atmospheric pressure. This results in a pressure gradient that causes air or other substances to move from areas of higher pressure towards areas of lower pressure.
2. Is total vacuum the same as negative pressure?
No, total vacuum and negative pressure are not the same. Total vacuum refers to a complete absence of matter in a space, while negative pressure refers to a lower pressure compared to the surrounding environment. Negative pressure can exist in a system without reaching a total vacuum state.
3. How is negative pressure created?
Negative pressure can be created in a system through various methods such as using a pump, creating a sealed or enclosed space, or through temperature changes. It can also be a natural occurrence in some environments.
4. What are some common applications of negative pressure?
Negative pressure is used in a variety of applications, including HVAC systems, vacuum cleaners, medical devices, and industrial processes. It can also be used to create clean rooms and control air flow in buildings.
5. Are there any risks associated with negative pressure?
While negative pressure can be useful in many applications, it can also pose risks if not properly managed. In some cases, it can lead to implosions or damage to structures. It can also affect air quality and cause health issues, so proper ventilation and monitoring are important when working with negative pressure systems.
  • Classical Physics
