Net Electric Field Strength
  1. Oct 17, 2014 #1
    A uniform electric field exists everywhere in the x, y plane. This electric field has a magnitude of 3600 N/C and is directed in the positive x direction. A point charge -9.8 × 10-9 C is placed at the origin. Find the magnitude of the net electric field at y = +0.20 m.
    2. Relevant equations
    E=kq/r^2
    3. The attempt at a solution
    I thought at first because the the y-direction is perpendicular to the electric field direction that the field strength would be 0, but this is wrong. I then thought the field would be the same at that point i.e. be 3600N/C, but that was wrong too. So how do I correctly solve this problem?
  3. Oct 17, 2014 #2
    Orodruin
    Staff Emeritus
    2017 Award
    Remember that you have two contributions to the electric field here. One from the uniform field and one from the added point charge.
  4. Oct 17, 2014 #3
    So because the uniform field acts perpendicular to the field from the point charge, the electric field at y=0.2m would be just the electric field from the point charge alone? Is my understanding correct?
  5. Oct 17, 2014 #4
    collinsmark
    That's not quite right. The electric field at the location y = 0.2 m, is [itex] \mathrm{(3600 \ N/C)} \hat a_x [/itex] plus whatever the electric field is from the point charge. (In my notation, I am using [itex] \hat a_x [/itex] as the unit vector pointing in the x direction.)
    Don't forget that they are vectors. (Don't merely sum the magnitudes.) [Edit: Hint: you need to break up each, individual electric field into its components, then you may sum the corresponding components of the individual fields.]
  6. Oct 17, 2014 #5
    So 3600N/C field acts in the x-axis direction, and the field from the point charge acts in all directions with a value of (9x10^9 x 9.8 x 10^-9)/0.2^2. So what I do is add these two together to find the total electric field in the x axis direction (let this sum be A), and the field in the y axis direction is just the field from the point charge (let this sum be B). And then I can use Pythagoras' formula here to say total electric field at y=0.2m = square root of (A^2+B^2). Is this now correct?
  7. Oct 18, 2014 #6
    Orodruin
    Staff Emeritus
    2017 Award
    No, does the point charge give a field component in the x direction?
  8. Oct 18, 2014 #7
    Doesn't the point charge give a field in all directions?
  9. Oct 18, 2014 #8
    Orodruin
    Staff Emeritus
    2017 Award
    It gives a field pointing in the radial direction. Along the y-axis, the radial direction is the y-axis and therefore the point charge does not give any component in the x-direction.
  10. Oct 18, 2014 #9
    Oh I see. So basically letting A= field due to point charge (which is in y axis direction) and B = field due to field in x-axis direction, because they are at right angles to each other net electric field at y=0.2m = square root of [ [(9x10^9 x 9.8x10^-9)/(0.2^2)]^2 + (3600^2)]?
  11. Oct 18, 2014 #10
    Orodruin
    Staff Emeritus
    2017 Award
    That would be the correct idea, yes.
  12. Oct 18, 2014 #11
    The answer still came out wrong?
Have something to add?
Draft saved Draft deleted
Similar Discussions: Net Electric Field Strength
Loading...
