Where Should a Third Charge Be Placed for Zero Net Force?
In summary, we are looking for the placement of a positive charge on the x-axis to create a zero resultant force between three charges. Using Columb's Law and the given values, we can set up an equation and solve for x, which gives us the answer of x = -0.809m.
johnnyies
93
1. Homework Statement
Three charges lie along the x -axis. The positive charge q1 = 10.0 microC is at x = 1.00 m, and the negative charge q2 = -2.00 microC is at the origin. Where must a positive charge q3 be placed on the x-axis so that the resultant force on it is zero?
Answer: x = - 0.809 m
2. Homework Equations
Columb's Law
F= k q1 q2
r^2
k = 8.9875 x 10^9
3. The Attempt at a Solution
Force of 1 acting on 3 = - k q1 q3 / (1 - x)^2
Force of 2 acting on 3 = k q2 q3 / x^2
k q2 q3 / x^2 - k q1 q3 / (1 - x)^2 = 0
k's and q3's cancel out and I get
q2(1 - x)^2 = q1(x^2)
-2(1 - 2x + x^2) = 10x^2
-2 + 4x - 2x^2 = 10x^2
12x^2 - 4x +2 = 0
x = .167 m
Needing a bit of help in setting this one up perhaps. No solutions guide is available. Can someone have a more conceptual explanation on how to solve this one?
Thanks for showing your work -- makes this much easier.
This line has a math error in it: q2(1 - x^2) = q1(x^2)
The term on the left should be quantity squared (you pulled the squared inside the parens. So re-write as:
[tex]q_2 (1-x)^2 = q_1 x^2[/tex]
oh, that's just a typing error, it doesn't change the answer from what I had originally.
Fixed and thanks.
Okay, then I think the issue that is left is that you double-did the negative sign for the negative charge:
You should let the sign on the charges themselves dictate whether the force is in the + or - x direction.
BTW, the book answer of -0.809m works in the equation you got to this point:
double-did the negative? That doesn't make sense. I thought you had to arbitrarily add the negative sign cause that's the direction the force will be in?
What is net force on a charge?
Net force on a charge is the overall force acting on a charged particle, taking into account all the individual forces acting on it.
What is the equation for calculating net force on a charge?
The equation for calculating net force on a charge is Fnet = qE + qv x B, where q is the charge of the particle, E is the electric field, v is the velocity of the particle, and B is the magnetic field.
How does the direction of the net force on a charge relate to the direction of the electric and magnetic fields?
The direction of the net force on a charge is determined by the direction of the electric and magnetic fields. The force will be in the same direction as the electric field and perpendicular to both the electric and magnetic fields.
What is the difference between net force and electric force on a charge?
Net force on a charge takes into account all the forces acting on the charge, including both electric and magnetic forces. Electric force on a charge only considers the force due to the electric field.
How does the magnitude of the net force on a charge change with the strength of the electric and magnetic fields?
The magnitude of the net force on a charge is directly proportional to the strength of the electric and magnetic fields. If the electric or magnetic field is increased, the net force on the charge will also increase.
9K
