• Support PF! Buy your school textbooks, materials and every day products Here!
Net resistance
  • Thread starter Asphyx820
The diagram represents a regular hexagon. The resistances are r each
Find the effective resistance across points A & B
http://tinypic.com/r/153n39d/7
A resistance less wire passes through one of the diagonals. so can we remove the wire and then solve.
i tried but i didnt get the answer.
do none of the points have same potential
Answers and Replies
gneill
Mentor
20,799
2,777
What exactly do you mean by "remove the wire"? You can't just erase it because that would create more nodes than the original circuit has (all points connected by unbroken wire conductor belong to same node).
Doc Al
Mentor
44,945
1,206
Show what you did.
I assume that when you "remove the wire" you mean that points connected by the wire can be joined. Do that and look for combinations of resistors in series or parallel that can be replaced by their equivalent. Step by step you can simplify this arrangement.
lewando
135
Try redrawing the circuit after you collapse the horizontal line into a point. [edit: what Doc said :redface:]
Ok !! so what do I do?
I cant find any points having same potential. how will i simplify the circuit?
Doc Al
Mentor
44,945
1,206
:confused: Points connected by a wire have the same potential.
Related Threads on Net resistance
  • Last Post
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
11K
  • Last Post
