Net Work of Pulling 10kg Box Up 5m Incline
In summary, the net work done by a man pulling a 10 kg box up an incline at a constant speed to a vertical height of 5 m depends on the angle of the incline and the distance the box is dragged. If the man is pulling along the ramp, the net work can be calculated by multiplying the net force (ma) by the distance. However, if the man is accelerating up the slope, the net work can be calculated by using the formula (10 kg)(5 m/s^2)(d) = net work, where d is the distance the box is dragged along the ramp.
dnt
238
a man pulls a 10 kg box up an incline at a constant speed to a vertical height of 5 m. what is the net work being done?
w= fd
i know in the plane perpendicular to the surface there is no net work done because all the forward forces (the pull) cancel out the backward forces (friction and gravity). however, isn't there a net force being done by gravity because he rose the box up 5 meters?
would the answer be (5m)(9.8)(10kg) = 490 J
or would it be 0 J because its not accelerating at all? whihc one is correct? thanks.
No. Gravity is not the only force acting on the box. The net force is zero.
That's the work done by the man, not the net work.
Exactly.
thanks. what if the question did say he was accelerating up the slope with a = 5 m/s2? would that change the answer then?
Absolutely. In that case there would be net work done on the box.
would it be:
(10kg)(5 m/s2)(5m) = 250 J
is that right?
dnt said:
would it be:
is that right?
That implies that the box accelerates straight up! The net work done depends on the angle of the incline and thus how far the force needs to act. For example, if the angle were 30 degrees you'd have to drag the box up 10 m to raise it 5 m vertically. So, the net work would be: (10 kg)(5 m/s^2)(10) = 500 J.
so basically you can take the net force (ma) in the same direction as its moving and then just calculate that distance to multiply to get the net work?
so gravity has no real part here?
Theres not enough information to solve the problem. Net work done on the object is equal to its change in kinetic energy
[tex]W_{net}=\frac{1}{2}mv_f^2-\frac{1}{2}mv_i^2 [/tex]
to know the net work performed you need to know the initial velocity (did the box start from rest) and the angle of the ramp
but if i know the distance the box traveled i could also multiply that by ma (net force) to get work, right?
Make sure it is net distance (not just vertical), so if you are using W = F*D*Cos(theta) which is W = M*A*D*Cos(theta) those are all scalar values where theta is the angle between the force and distance vectors (distance vector should always be along the ramp). If the man is pulling along the ramp then theta = 0 and cos(theta) = 1. So if you are talking about distance along the ramp and the man is not pulling at an off angle then yes that should work
Yep.
Gravity is already included in the net force.
Sure. You don't need the initial velocity to find the net work done. (You would need the initial velocity to find the final kinetic energy.)
1. How much work is required to pull a 10kg box up a 5m incline?
In order to calculate the work required, we need to use the formula W = mgh, where W is work, m is the mass of the box, g is the gravitational acceleration (9.8 m/s^2), and h is the height of the incline (5m). Plugging in the values, we get W = (10kg)(9.8 m/s^2)(5m) = 490 Joules.
2. How much force is needed to pull a 10kg box up a 5m incline?
To determine the force required, we can use the formula F = mg sin(theta), where F is force, m is the mass of the box, g is the gravitational acceleration, and theta is the angle of the incline. In this case, the angle of the incline is 0 degrees, so sin(theta) = 0. Therefore, the force required to pull the box up the incline is 0 Newtons.
3. Does the length of the incline affect the amount of work required to pull the box up?
No, the length of the incline does not affect the amount of work required. As long as the height of the incline remains the same, the work required will also remain the same. The length of the incline only affects the distance over which the work is done.
4. Can we use a different unit to measure the work required to pull the box up?
Yes, work can be measured in different units such as joules, foot-pounds, or kilogram-meters. However, it is important to make sure that all other values used in the formula (mass, height, etc.) are in corresponding units.
5. Is the work done on the box by pulling it up the incline considered positive or negative?
The work done on the box is considered positive, as the force applied is in the same direction as the displacement (up the incline). Work is only considered negative when the force and displacement are in opposite directions.
