Solving Neuton's Second Law: Mass and Tension Calculations for Hanging Objects
In summary, the two objects are hung vertically over a frictionless pulley. The tension is determined by the force applied to the objects and the mass of the objects.
chocolatelover
239
Two objects of unequal mass are hung vertically over a frictionless pulley of negigible mass. Determine vector a1, vector a2, and the tentions. m1<m2
ΣFy=t-m1g=m1ay
ΣFy=m2g-T=m2ay
-m1g+m2g=m1ay+m2ay
ay=m2-m1/(m1+m2)g
ay=(m2-m1)/(m1+m2)h
ay=(15-5kg)/(15kg+5kg)(-9.8m/s) (Would gravity be negative?)
=4.9m/s^2
Is a1= a2? that is, a1=-4.9m/s^2 and a2=-4.9m/s^2
T=m1(g+ay)=(2m1m2)/(m1+m2)g
T=5kg(9.8m/s^2+9.8m/s^2+4.9m/s^2)
=2(5kg)(15kg)(9.8m/s^2)/(5kg+15kg)
T=73.5kg
Does this look right?
Would you also get the same answer if you did vector a =change in velocity/change in time?
Thank you very much
ΣFy=t-m1g=m1ay
ΣFy=m2g-T=m2ay
You should make really clear what axis you are using. Is it clear to you what are the directions you are using? It's a bit confusing because you use two opposite directions for the two objects. But you can do that as long as everything is clear to you.
-m1g+m2g=m1ay+m2ay
ay=m2-m1/(m1+m2)g
ay=(m2-m1)/(m1+m2)h
=4.9m/s^2
well, you made two mistakes which by luck canceled out, leaving you with the correct answer. You should have used +9.8 for g. And you made a mistake in going from the first to the second line since you dropped the minus sign.
Are you talking about [tex] (a__y)_1 [/tex] and [tex] (a_y)_2 [/tex]? To answer your question, you must make clear what your directions are for your two axis.
And why do you now have a minus sign when there was no minus sign on the previous line?
T=73.5kg
Thank you very much
A tension is a force so it's not in kg.
Thank you very much
It's along the y-axis.
I ended up getting kg(kg)(m/s^2)/(kg). Would that be kgm/s^2?
Is ay the same thing as vector a1? Vector a1 and a2 are equal, right? even though m1<m2, would the tention and gravity be the same?
Does it look correct now?
Thank you
Thank you very much
Yes, and that's the same as a Newton.
There are three things involved and people keep mixing them up which causes a lot of confusion. You may talk about the vectors [tex] \vec{a}_1, \vec{a}_2 [/tex], you may talk about their components [tex] (a_y)_1, (a_y)_2 [/tex] and you may talk about their magnitudes (usually written as [tex] a_1, a_2 [/tex]).
The two acceleration vectors are clearly not equal! But the two magnitudes are equal. As for the y components, it depends on the choice of y-axis for each object.
Thank you
It's not clear because you jump from positive to negative to positive values of the y acceelration.
Thank you very much
Regards
What is Neuton's Second Law?
Neuton's Second Law, also known as the Law of Acceleration, states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass.
How is Neuton's Second Law expressed mathematically?
F=ma, where F is the net force, m is the mass of the object, and a is the acceleration.
What is the significance of Neuton's Second Law?
Neuton's Second Law is significant because it explains the relationship between force, mass, and acceleration, and how they affect the motion of an object. It is a fundamental law of physics and is used to calculate the motion of objects in various scenarios.
What are some real-life examples of Neuton's Second Law?
Some examples include pushing a shopping cart, throwing a ball, or riding a bike. In each of these scenarios, the force applied determines the acceleration of the object.
How does Neuton's Second Law relate to the other laws of motion?
Neuton's Second Law is often referred to as the fundamental law of motion because it is used to derive the other two laws of motion - the Law of Inertia and the Law of Action-Reaction. Together, these three laws form the basis of classical mechanics.
22K
