Miki Abe
- 5
how much is the current in a neutral line of 3phase and 4 wire system with voltage of 0.38/0.22kV. where we have 8 loads which each load is 2 kVA. 3 loads connected to each phase of A and B and 2 loads connected to phase c.
A 3Phase, 4Wire System is an electrical power distribution system that uses three live conductors and one neutral conductor to provide three phases of alternating current (AC) power. This type of system is commonly used in industrial and commercial settings.
The main difference between a 3Phase and single-phase system is the number of live conductors used. Single-phase systems have one live conductor and one neutral conductor, while 3Phase systems have three live conductors and one neutral conductor. This allows for a more efficient distribution of power and can handle larger loads.
One of the main advantages of a 3Phase, 4Wire System is its ability to handle high power loads more efficiently than single-phase systems. It also provides a more stable power supply, as the three phases are offset from each other, resulting in less fluctuation in voltage. Additionally, 3Phase systems require less wiring and have a lower risk of overload, making them more cost-effective and reliable.
The fourth wire, also known as the neutral wire, is used to provide a return path for the unbalanced current in the system. In a 3Phase system, the three phases will not always have the same amount of load, resulting in an imbalance. The neutral wire helps to balance the load and prevent overloading of the system.
In a 3Phase, 4Wire System, loads are connected evenly across the three phases to achieve a balanced load. This means that each phase will have an equal number of loads, resulting in a more efficient use of power. The neutral wire is then connected to provide a return path for any unbalanced current.
