Why the Neutral Wire Causes No Electric Shock
In summary, the neutral wire does not cause an electric shock because it is essentially at the same potential as the ground. In a properly balanced power distribution system, the neutral should have no current flowing through it and is often grounded. However, in larger transmission systems, a neutral wire is connected to handle excess current. The ground is a safety device, while the neutral is essential for the current to travel and provides resistance. The color codes for phases vary depending on the voltage, with the UK primarily using combinations for 230/240V and 415V. In order for a current to flow, there must be a circuit loop and a reference to ground. Therefore, in a properly built electrical system, it is not possible to receive a shock
Phys988
Why the neutral wire (the cold) does not cause an electric shock?
In a properly balanced power distribution system the neutral should have no current flowing through it, also it is often grounded.
This is incorrect; the neutral conductor provides the return path for the current from the hot conductor. In a properly-built electrical system, the neutral conductor is at the same potential as Earth ground, though, meaning that you cannot receive a shock between it and ground.
- Warren
Technically we are both correct...in 'real' electrical power systems a neutral wire carries only the unbalanced current from a Y-connected system due to unbalanced loads. It is not necessarily earthed, however owing to it's nature and how it is sometimes connected to Earth you are right in saying there is no potential between it and ground.
You are talking of the other use of the word neutral where it is the cable that links back to the grid. NB - if you can be shocked by the neutral if you provide a quicker path to ground when the neutral has current flowing through it.
I assume from your use of the word 'earthed' that you're British. Here, there isn't more than one use of the word 'neutral'. Black is hot, white is system neutral, and green is ground (earth). That's for regular domestic stuff, though. Fancier industrial systems such as 3-phase might have different terms that I'm unaware of.
Nope.
russ_watters said:
Nope.
'Nope' as in I'm wrong, or 'nope' as in the terms are the same? :confused:
Fancier industrial systems use the same type of terms and color schemes.
However neutral in the home and neutral in three phase isn't actually the same thing...not quite.
Can you elaborate upon that, Mike?
Sure, I assume that you know what three phase power is...if not have a read of this article I wrote for the UKSLC...(there is an error in how the 415V (for UK mains) is reached but other than that it's all fine)
http://www.ukslc.org/articles/power/3_phase_power_explanation.html"
Now, in a perfectly balanced three phase system (where each of the phases is loaded with an equal impedance you can connect the ends together as shown in this diagram (from the above article)
http://www.ukslc.org/images/articles/threephase/fig40001.gif"
Unfortunately it's hard to balance the load perfectly in a large transmission system, so a neutral wire is connected between where the three loads and three generators meet taking the excess current. This is the neutral in the three phase system. The neutral in your house just goes from you, the load, to the point where all of the loads connect... while your neutral is connected to the neutral that I have explained it doesn't necessarily have to be.
I suppose what I'm saying is that the current in the neutral line in your house does not necessarily flow down the neutral of the larger three phase system, so it is different while being connected.
Ah ha! My speciality!
I have been doing electrical work for a while, and I might have an answer.
First, Have you ever grabbed a neutral? I've gotten hit with one, and took a meter to it and it had 70v pumping through it. But that was probably someone's screw up.
ANYWAY
there is a difference between it and the ground.
The ground is a safety device. Almost all every day devices can operate without it, but NEC demands it in most cases. The neutral is essential for current to travel, for it provides resistance for the current to push against. There shouldn't be any current going through it, but mistakes happen.
depending of the voltage, the phases have different color codes. you have different combos for 120, 240, 277, and 480 (in USA at least)
well the way i see it the neutral wire is the centre tap of the transformer. not a ground but ussually connectected to ground at a certain point at the electrical box. so say if we have an transformer with three wires and one is the center tap. now until any part of the circuit is referenced to ground there is no circuit and no current path. if somehow the wrong part of the circuit is referenced to ground the neutral wire will have a voltage potential to ground. hope this helps
In the UK you only really have combinations for 230/240V and 415V (That's the phase and line voltages)
let me put it this way. unless you have a circuit loop you can not have a current flow. so regardless of where or what voltages you have. the high voltage is reduced to the operational voltages by transformers. these transformers are referenced or grounded to Earth at a certain point ussually with the centertap of the transformer at a certain point. then you have say 120 v per line wrt the center tap or neutral wire. phase or 240 v across l1 l2. now if you have a long run of wire you will have a resistance and a voltage drop across the wire and you may get a shock if you touch the wire and ground at the same time. as for the wire color in the UK may be different but the principles of the circuit will remain constant. as for 3 phase same thing just your phases wrt neutral
1. What is a neutral wire?
A neutral wire is an electrical wire that carries the return current from a load back to the power source. It is typically colored white and is connected to the neutral bus bar in an electrical panel.
2. Why doesn't the neutral wire cause electric shock?
The neutral wire is grounded at the electrical panel, meaning it is connected to the earth through a ground wire. This allows excess current to flow safely into the ground rather than through a person's body, preventing electric shock.
3. Can the neutral wire still be dangerous?
While the neutral wire itself does not carry a dangerous amount of current, it can still be dangerous if it is not connected properly. If the neutral wire becomes disconnected or damaged, it can cause an imbalance in the electrical system and lead to electric shock.
4. What is the difference between the neutral wire and the ground wire?
The neutral wire is part of the electrical circuit and carries the return current, while the ground wire is a safety feature that provides an alternate path for excess current to flow into the ground. The ground wire is typically colored green or bare copper.
5. Can I touch the neutral wire?
It is not recommended to touch any electrical wires, including the neutral wire, without proper training and safety precautions. While the neutral wire carries a lower amount of current, it can still cause injury if not handled properly.
  • Other Physics Topics
20K
  • Electrical Engineering
  • Classical Physics
