• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Neutron capture calculation
Summary: Problem: nuclear physics, neutron capture
In the problem one should calculate time dependence of number of nuclei.
Problem statement:
Neutron beam radiates sample A with initial number of atoms N0. With neutron capture nuclei (cores) of A are transitioning to nuclei B (they are just one neutron richer isotope).
A + n → B + ϒ
Expected time for neutron capture on core is equal to τN. With an assumption that neutrons do not affect the sample B, calculate time dependence number of nuclei B if:
1. cores B are stable
2. cores B are unstable with average lifetime of τ0 and they decay to the nuclei (cores) different then A
3. cores B are unstable with average lifetime τ0 and they decay back to the nuclei (cores) A.
There are also two hints in helping problem to solve:
Hint 1:
Parameter τN considers that contribution to the destroying of nuclei A with neutron captures is described as:
##(\dfrac{dN_A}{dt})_{capture} = \dfrac{-N_A}{\tau_N}##
Hint 2:
Sometimes it is useful to assume solution in advance, but sometimes it is easier to switch to the new set of variables like:
##\Sigma = N_A+N_B## and ##\Delta = N_A-N_B##
So, this is the problem. It is hard for me to actually attack it anyhow, because problem is generalized and what bothers me the most are conditions for 1, 2 an 3. On the other side, kind of confused with hint 2.
How should I treat here stable and unstable nuclei B. To just assume N/Z ratio, like even - even nuclei or similar. But the also to assume the same for nuclei A.
For any advice and help, thanks in advance!
[Moderator's note: Moved from a technical forum and thus no template.]
vanhees71
Insights Author
4,622
Then you just write down rate equations. For case (3)
$$\dot{N}_A=-\lambda_N N_A+\lambda_0 N_B,\\
\dot{N}_B=\lambda_N N_A -\lambda_0 N_B.$$
Want to reply to this thread?
"Neutron capture calculation" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
