Understanding Neutron Decay in Elementary Particle Physics
In summary, David Griffiths discusses the concept of decay and scattering in 'Introduction to Elementary Particles'. He mentions that a neutron decays into a proton, an electron, and an antineutrino (1.8), but the decay of an antineutrino and a neutron into a proton and an electron is not observed (1.13). This was expected due to the assumption that lepton number is conserved, and that the antineutrino would be changed into a neutrino through crossing symmetry. However, the idea of conservation of spin angular momentum also played a role in this expectation, as the decay channel of (1.13) violates this conservation law. Additionally, there is no evidence to suggest that this decay
elas
In ‘Introduction to Elementary Particles’, David Griffiths makes the following two statements:
And later:
but the following decay is not observed
an antineutrino plus a neutron decay into a proton and an electron (1.13)
But why was it expected? Surely the expected decay for (1.13) would be to a proton, electron and two antineutrinos
Clearly I am missing something, but I cannot see what; any clarification would be appreciated.
First of all (1.13) is not a decay- it is a scattering event. Second, when you bring the antineutrino to the left hand side of (1.8) it must be changed into a neutrino by crossing symmetry. Read pages 20-21 for information on crossing symmetry. The idea here is the concept of conservation of lepton number. In 1.12 lepton number is conserved, while in 1.13 it is not. While there may be reactions where lepton number is not conserved, the assumption at the time was that lepton number was conserved and the expectation in the scattering experiment was that if the neutrino and its antiparticle were distinct particles they would carry different lepton numbers (by the definition of antiparticle) and therefore reaction (1.12) would occur but (1.13) would not.
And later:
There are many reasons, but one most obvious is conservation of spin angular momentum. The latter was "expected" because the initial situation before decays has the possibility of spin of either zero or 1 (1/2 from antineutrino, 1/2 from neutron). The situation after the decay has the same possibility (1/2 from proton, 1/2 from electron). So just going by this conservation along, such decay channel can't be ruled out. So there are other criteria why this decay isn't possible.
Zz.
Thanks for the replies, but I am still not clear for the following reasons-
Griffiths does not use the term "scattering" but at this point is also unclear about decay, so I checked with 'Wikipedia' and they clearly state that Cowan and Reines experiment used decay events.
On the left of 1.13, antineutrino (1/2 spin); neutron (0 spin).
On the right of 1.13 (proton (1/2 spin); electron (1/2 spin)
I assume that the antiparticle 1/2 spin of the antineutrino cancels the particle 1/2 of the proton within the (0 spin) neutron. But where is the antiparticle half spin, needed on the right of the equation, in order to reduce the total particle spin to 1/2.
Which brings me back to my original question - why did Cowan and Reines expect to find something predicted by an unbalanced equation?
On the right of 1.13 (proton (1/2 spin); electron (1/2 spin)...
Why do you believe a neutron is spinless?
A "decay" in particle physics typically means a process where one initial particle is converted into other stuff. The term may be used liberally in some contexts; I don't know.
Neutron has spin 1/2.
There simply exists no mechanism within the SM to run (1.13). Of course, this means very little, since the SM is not final. Even considering extensions of the SM, it may be the case that (1.13) would still not proceed, since it violates lepton number conservation. This conservation law is largely empirical - it does not lie on equal footing with eg. conservation of energy or charge. If neutrinos were Majorana particles, (1.13) could proceed. There is simply no evidence that it does.
My mistake, thanks for correction and for explanation, can now proceed with studies
I have two question, hope someone can help me...
1) Is the neutron decay isotropic? Or does it somehow depends on the spin direction?
2) Does anybody know a book, or even a code dealing with the calculation of the
energy distribution of the electron/neutrino after the decay?
Neutron decay is anisotropic. That's because the neutron decays weakly, and the weak interaction violates parity conservation. This was predicted by Lee and Yang, and confirmed by Madame Wu.
It's been a while since I've looked it up, but I would think that any book that treats fermi statistics would provide you with the machinery for this. Someone else will probably have a more specific answer.
1. What is Neutron Decay?
Neutron decay is the process in which a neutron, one of the building blocks of an atom, breaks apart into smaller particles. This process is important in understanding the behavior of subatomic particles and their interactions.
2. Why is Neutron Decay important in Elementary Particle Physics?
Neutron decay is important in elementary particle physics because it helps us understand the fundamental structure of matter. By studying the decay of neutrons, we can gain insight into the forces and interactions between particles at the subatomic level.
3. How does Neutron Decay occur?
Neutron decay occurs through the weak nuclear force, which is one of the four fundamental forces in nature. During the decay process, a neutron transforms into a proton, an electron, and an antineutrino. This transformation is governed by the laws of quantum mechanics.
4. What are the different types of Neutron Decay?
The two main types of neutron decay are beta-minus decay and beta-plus decay. In beta-minus decay, a neutron emits an electron and an antineutrino, while in beta-plus decay, a neutron captures an electron and emits a proton and a neutrino.
5. How is Neutron Decay studied in experiments?
Neutron decay is studied through experiments that involve observing and measuring the particles produced during the decay process. These experiments can provide valuable data that can be used to test and refine theories about the behavior of subatomic particles.
