Neutron Star Collision Homework: Layer Thickness & Gravitational Potential
In summary, the conversation discusses a scenario in which an earth-like object collides with a neutron star, forming a thin layer on top of the neutron star's surface. The thickness of this layer can be calculated using the given masses and volumes, and the potential energy released by the object's fall can be compared to the total nuclear energy released by the Sun. The conversation also mentions that the problem was created by the professor and there is no textbook for reference.
egsid
Suppose that an earth-mas object collides with a neutron star with radius 10 km and mass 1.4 $M_{sun}$. The material of the earth-like object would wrap around the neutron star and form a thin layer on top of the original neutron star surface. Assume the material gets converted to neutron star material so the density of the layer increases to become the same as the average density of the neutron star.
a) How thick would this layer be?
b) Assuming the object falls from infinity to the neutron star surface, how much gravitational potential energy is released? Compare this to the total nuclear energy released by the Sun during its main sequence lifetime.
U = -GMm/r
So I actually think I can solve part b of the question if I know what the answer to part a is. I would just take the thickness of the layer, add it to 10 km and that would be my r value in the equation above. I know the masses so I could calculate potential energy. The problem though is this thickness in the layer. Please help.
Thanks
The volume of the neutron star before collision is [itex] \frac{4}{3}\pi 10^3 km^3 \approx 4\times 10^3 km^3 [/itex] so the average density becomes [itex] \frac{1.4}{4 \times 10^3}=3.5 \times 10^{-4} \frac{M_{sun}}{km^3}[/itex].The mass of the Earth like object is approximately [itex] 3 \times 10^{-6} M_{sun} [/itex] and the volume of the layer is[itex] \frac{4}{3} \pi [(10+\delta)^3-10^3]\approx 4[\delta^3+30\delta^2+300\delta] [/itex] so we should have [itex] \frac{3\times 10^{-6}}{4[\delta^3+30\delta^2+300\delta]}=3.5 \times 10^{-4} [/itex] from which you can find [itex] \delta [/itex] which is the thickness of the layer.
Anyway,never heard of such collisions.It was interesting.What's your book?
Thanks, I pretty much agreed with your answer. We don't have a book; our professor just comes up with problems by himself.
Shyan -- please check your PMs. The student must do the bulk of the work on their homework. Please do not do their work for them.
for your question. I would approach this problem by first determining the density of the neutron star. This can be calculated by using the given radius and mass of the neutron star, as well as the formula for volume of a sphere (V = 4/3 * π * r^3). This will give us the average density of the neutron star.
Next, I would use this density to calculate the thickness of the layer formed by the collision. This can be done by considering the total mass of the earth-like object and dividing it by the density of the neutron star. This will give us the volume of the layer, and from there we can use the formula for volume of a cylinder (V = π * r^2 * h) to solve for the thickness (h).
Once we have the thickness of the layer, we can proceed with calculating the gravitational potential energy released during the collision. As you mentioned, we can use the formula U = -GMm/r, where r is now the sum of the original neutron star radius and the thickness of the layer. This will give us the potential energy released during the collision.
In terms of comparing this energy to the total nuclear energy released by the Sun during its main sequence lifetime, this would require some further calculations and assumptions. It would depend on the specific mass and composition of the earth-like object, as well as the efficiency of the conversion of its material to neutron star material. Nevertheless, this comparison could provide some interesting insights into the incredible forces involved in this type of collision.
I hope this helps and provides a starting point for your solution. Keep in mind that as a scientist, it's important to carefully consider all the given information and use appropriate equations and methods to arrive at a solution. Good luck with your homework!
1. What is a neutron star collision?
A neutron star collision is when two neutron stars, which are extremely dense and compact objects formed from the remnants of a supernova explosion, collide with each other due to their strong gravitational pull.
2. How does layer thickness affect the gravitational potential in a neutron star collision?
The layer thickness of a neutron star can affect the gravitational potential in a collision because it determines the density and mass distribution of the star. Thicker layers result in a higher gravitational potential, making the collision more powerful.
3. What is the relationship between layer thickness and the strength of a neutron star collision?
The strength of a neutron star collision is directly proportional to the layer thickness. Thicker layers result in a stronger collision due to the increased gravitational potential and mass.
4. How do scientists measure the layer thickness of neutron stars?
Scientists use various methods to measure the layer thickness of neutron stars, such as observing the x-ray spectra emitted from the surface of the star or studying the gravitational waves produced during a collision.
5. What are the potential implications of studying neutron star collisions and their layer thickness?
Studying neutron star collisions and their layer thickness can provide insight into the behavior of matter under extreme conditions and help us better understand the formation and evolution of these objects. It can also aid in the development of new models and theories in astrophysics and cosmology.
  • Astronomy and Astrophysics
