Neutron's decay, kintetic energy
So the total momentum is zero, which means the total kinetic energy is equal to the total rest energy of the particles.
rayman123
152
What is the kinetic energy given to the proton in the decay of the neutron when a) the electron has negligibly small kinetic energy; b)antineutrino has small negiligibly energy
The decay reaction
[tex] n\Rightarrow p+e^{-}+\bar{\nu}[/tex]
now I try to work out the Q-value (I assume that neutron is at rest)
[tex] m_{n}c^2=m_{p}c^2+T_{p}+m_{e}c^2+T_{e}+m_{\bar{nu}}c^2+T_{\bar{\nu}}[/tex]
then movin all the therms with c^2 to the left side I get
[tex](m_{n}-m_{p}-m_{e}-m_{\bar{\nu}})c^2=T_{p}+T_{\bar{\nu}}[/tex]
so
[tex] Q=T_{p}+T_{\bar{\nu}}[/tex]
the Q value can be easily calculated but what with the other kinetic energies on the right side? It this correct?
sorry what is the T?
is your decay is as follows:
when one particle has negligible KE, then you can just consider a momentum energy balance for the other 2 particles
so, say there is excess energy E, and the 2 particles of interest (with masses m1 & m2) will move in oppposite dierctions along a single axis (with speeds v1 & v2), then they must satisfy:
conservation of energy
[tex] E = m_1 v_1^2 + m_2 v_2^2[/tex]
conservation of monemtum
[tex] m_1 v_1 + m_2 v_2 = 0[/tex]
T stands for kinetic energy
For part (a), you're assuming the electron is at rest, so what does that tell you about the momenta of the antineutrino and proton?
Instead of separating out the kinetic energy at the beginning of the problem, I'd try solving for the total energy of the proton and then subtract off the rest energy at the end to get the kinetic energy.
that their momenta are equal?
Yes, equal in magnitude but opposite in direction.
1. What is neutron decay?
Neutron decay is the process in which a neutron, one of the three particles that make up an atom, transforms into a proton, an electron, and an antineutrino. This process is also known as beta decay.
2. How does neutron decay happen?
Neutron decay occurs when there is an excess of neutrons in an atom's nucleus. The neutron becomes unstable and decays into a proton, an electron, and an antineutrino. This process releases energy in the form of kinetic energy.
3. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. In the case of neutron decay, the kinetic energy is the energy released when the neutron transforms into a proton, an electron, and an antineutrino.
4. How is the kinetic energy of neutron decay calculated?
The kinetic energy of neutron decay can be calculated using the equation E = mc², where E is the energy released, m is the mass lost during the decay, and c is the speed of light. The mass lost during neutron decay is converted into kinetic energy according to Einstein's famous equation.
5. What are the practical applications of neutron decay and kinetic energy?
Neutron decay has many practical applications in nuclear physics, including the production of nuclear energy and radioactive isotopes for medical and industrial purposes. The release of kinetic energy during neutron decay can also be harnessed to generate electricity in nuclear power plants.
