Revolutionizing Space Travel: A New Form of Propulsion Without Limitations
In summary, the conversation discusses the limitations and possibilities of space travel, including the use of fuel and propulsion systems. While rockets are currently the most commonly used form of propulsion, there is ongoing research into more advanced technologies such as the Bussard ramjet and ion drives. The conversation also touches on the concept of maintaining a constant speed in space and the challenges of collecting and utilizing fuel in the vacuum of space. Overall, the conversation highlights the importance of continued scientific research and advancements in order to improve our ability to travel through space.
Mackay1011
35
Hey, I know it's easier said then done but why are scientists spending so much money trying to improve the way we travel using "fuel" i.e hydrogen or whatever they use to go mach 2 plus. let's be realistic we are never going to be able to travel far into space because it uses to much fuel and we would run out.
Rockets are crap because they also don't last long. isn't there anything in space itself that we could use to propel "really fast" into space, then we wouldn't run out?
or, send a satelite thingy into space and try to land it on an asteriod and let the asteriod do the work?
please reply in detail, thanks
We've sent people to the moon and unmanned probes a LOT further with existing rocket technology. That said, the world's space agencies do fund research into more advanced technologies.
BTW, Mach 2 is slow. Very, very slow. You have to get to Mach 25 just to get into low Earth orbit.
The Bussard Collector popularised by the Star Trek franchises is actually a factual, though at present theoretical propulsion system; it was given a tongue-in-cheek airing on the series way back in the 60s, which is when the theory was evolved if I recall. They were the red, glowy bits on the front of the warp nacelles.
I think the theory is that ionized EM fields around the engine, scoop hydrogen or some other stellar mass into the ramjet engine. Unfortunately, this stellar mass is only present in nanoscopic amounts per cubic metre of space, meaning the ionised scoops would need to trawl something like 10^18 m of space to collect a gram of anything 'burnable' - which could explain why it'll probably remain on the drawing board for some time yet.
But it does have the interesting feature that as you go faster it gets more efficent - so if you want to go to andromeda it's pretty handy!
Mackay, I suspect that you are making a fundamental error regarding space travel. That's based upon your statement about the fuel running out. It isn't like an aeroplane or car on Earth that stops when it's out of gas. A space vehicle will continue on at the same velocity that it had after its last production of thrust. Realistically, a vehicle will retain sufficient fuel to alter that velocity if necessary, by either changing direction or changing speed.
Colin, the Bussard ramjet is indeed a workable technology, but complicated. Although it's been a few decades since I read anything about it, I seem to recall that it involves using a laser to ionize interplanetary or interstellar hydrogen, and then using a magnetic 'scoop' of several thousand kilometres in area to funnel it into a fusion engine. I'm a pretty serious Star Trek (all versions) fan, and I don't recall the mention of Bussard collectors before TNG. The warp engines were based upon matter/antimatter annihilation, not nuclear fusion. A Bussard ramjet could certainly suck in enough hydrogen, which would be pure protons in its ionized state, but it couldn't gather the antiprotons to react them with.
Danger you have explained pretty good :D thanks, so with the PROVEN technology that we have at the moment how fast could we travel in space and when the fuel runs out we could still maintain that speed.
A gas cylinder is compressed and when it blows up it shoots into the air...
cant you really cram loads and loads of the most explosive fuel know and then ignite it when were in space and stay at a constant speed of say 60,000mph? or something
Scientits don't waste money. Politicians give money to scientists to do certain tasks.
That depends on how much fuel you have on hand. The more fuel your rocket holds, the faster its final speed will be.
The equation goes like this:
[tex]V_{final} = V_{exhaust} \ln (MR )[/tex]
Where MR is the mass ratio, or the mass of the rocket plus its fuel divided by the mass of the rocket alone
The other factor is the exhaust velocity (how fast the gases shoot out the back of the rocket). The higher this velocity, the faster your rocket will end up going for the same amount of fuel. This is a measure of the efficiency of the rocket. The exhaust velocity is a function of the energy content of your fuel and how hot in burns.
In space, as long as the fuel is burning at its hottest, it doesn't really matter if we burn it up fast or slow, we still reach the same final velocity.
There is a limit as to how hgh an exhaust velocity you can achieve with chemical explosives, which is why research is being done in propulsion systems such as ION drives, which can achieve much higher exhaust velocities, and thus can reach higher speeds using less fuel.
the Bussard ramjet is fairly unfeasible as it stands since (a) the density of hydrogen in free space is estimated based upon an average determined within the solar system and (b) by far, nearly all of that scarce hydrogen will not be ions but rather will be in it's electronic ground state - one would be lucky to find a significant amount of free ions. as for somehow actively ionizing and then electrostatically collecting, good luck with that.
1. How does this new form of propulsion work?
This new form of propulsion, called the EmDrive, works by bouncing microwaves back and forth inside a closed metal cone. This creates a difference in radiation pressure, with more pressure on one end of the cone than the other. This imbalance in pressure generates thrust, allowing for movement through space without the need for traditional propellants.
2. What are the potential benefits of this new form of propulsion?
The potential benefits of the EmDrive include faster and more efficient space travel, as it does not require the use of propellants which can be heavy and expensive to transport. It also has the potential to revolutionize long-distance space missions and make space exploration more accessible.
3. Are there any limitations to this new form of propulsion?
While the EmDrive shows promising results, there are still limitations and challenges that need to be addressed. One major limitation is the amount of thrust that can be generated, as it is currently not enough for large spacecrafts. There are also concerns about the feasibility of this technology and the lack of scientific consensus on its underlying principles.
4. What research has been done on this new form of propulsion?
The concept of the EmDrive has been around since the early 2000s, but it has gained more attention in recent years. Several experiments have been conducted, including one by NASA in 2016 which showed a small amount of thrust being generated. However, further research and testing are still needed to fully understand and validate this technology.
5. When do you think this new form of propulsion will be used in space travel?
It is difficult to predict when this new form of propulsion will be used in space travel. While there has been some promising research, there are still many challenges and limitations that need to be overcome. It will likely take many more years of research and development before this technology is ready for practical use in space missions.
  • Science Fiction and Fantasy Media
  • Aerospace Engineering
  • Mechanical Engineering
  • STEM Academic Advising
