New prime series?
Loren Booda
3,119
Consider all primes
2, 3, 5, 7, 11, 13...
and their products such that
2x3=6, 2x3x5=30, 2x3x5x7=210, 2x3x5x7x11=2310, 2x3x5x7x11x13=30030...
Is this latter series used in number theory?
Likewise, can one determine
lim (2+3+5+7+11+13...pn-1)/(2+3+5+7+11+13...pn)
n-->[oo]
in analogy to phi of Fibonacci numbers?
Answers and Replies
Hurkyl
Staff Emeritus
This function is called the primorial function.
Loren Booda
3,119
Thanks for the helpful hyperlink, Hurkyl.
Do you or anyone else have a hint about the second series I mentioned, the prime Fibonacci analog, and its limit:
lim (2+3+5+7+11+13...pn-1)/(2+3+5+7+11+13...pn)=?
n-->[oo]
Hurkyl
Staff Emeritus
I'm not sure why you call it a Fibonacci analog...
Anyways, your fraction can be rewritten as:
[tex]
\frac{2 + 3 + \dots + p_{n-1}}{2 + 3 + \dots + p_n}
= 1 - \frac{p_n}{2 + 3 + \dots + p_n}
= 1 - \frac{1}{1 + \frac{2 + 3 + \dots + p_{n-1}}{p_n} }
[/tex]
So solving your limit reduces to finding
[tex]
\lim_{n\rightarrow\infty}\frac{2 + 3 + \dots + p_{n-1}}{p_n}
[/tex]
No proof of any value for this leaps to mind, however.
Hurkyl
Staff Emeritus
I don't know how I managed not to read the big thread on TeX. :frown:
(PS you got some groupings wrong)
chroot
Staff Emeritus
40
Whoops! Feel free to edit my posts to reflect the correct TeX, or delete them altogether if you wish.
Also, please note that I don't intend to coerce people into using TeX if they are already comfy and happy with basic HTML.
- Warren
Hurkyl
Staff Emeritus
I need to learn LaTeX eventually anyways, might as do it here where I can get some practical benefit out of it. :smile: The only LaTeX I've written thus far was for writing a tutorial to use some code I had written, so I haven't gotten to play with any of the math stuff!
Hurkyl
Staff Emeritus
All right, here goes.
Define
[tex]
S(n) := \frac{2 + 3 + ... + q_n}{n}
[/tex]
where [tex]q_n[/tex] is the largest prime less than [tex]n[/tex]. I aim to prove:
[tex]
\lim_{n\rightarrow\infty} S(n) = \infty
[/tex]
From which we can deduce
[tex]
\lim_{n\rightarrow\infty} \frac{2 + 3 + \dots + p_{n-1}}{p_n}
= \infty
[/tex]
and thus
[tex]
\lim_{n\rightarrow\infty} \frac{2 + 3 + \dots + p_{n-1}}{2 + 3 + \dots + p_n}} = 1
[/tex]
It's clear that
[tex]
\lim_{n\rightarrow\infty} S(n) = \lim_{\substack{ n\rightarrow\infty \\ n~{\it even}} } S(n)
[/tex]
So I will restrict my attention to the case where [tex]n[/tex] is even.
The general approach is to estimate the numerator of [tex]S(2n)[/tex] by just looking at the primes in the range [tex][n, 2n)[/tex], and underestimating [tex]S(2n)[/tex] by [tex]n[/tex] times the number of primes in this range. To do this, I will use Chebyshev's bound on the prime counting function:
[tex]
\frac{7}{8} < \frac{ \pi(n) }{ \frac{n}{ln~n} } < \frac{9}{8}
[/tex]
So here goes:
[tex]
\begin{equation*}
\begin{split}
S(2n) &= \frac{2 + 3 + \dots + q_{2n}}{2n} > \frac{1}{2n} (\pi(2n) - \pi(n)) n \\
&> \frac{1}{2} \left (\frac{7}{8} \frac{2n}{ln~2n} - \frac{9}{8} \frac{n}{ln~n} \right)
\end{split}
\end{equation*}
[/tex]
A bit of elementary calculus proves that
[tex]
\lim_{n\rightarrow\infty} \frac{1}{2} \left( \frac{7}{8} \frac{2n}{ln~2n} - \frac{9}{8} \frac{n}{ln~n} \right) = \infty
[/tex]
And we're done.
Loren Booda
3,119
Hurkyl,
What experience do you have in math? You seem the most competant of a talented bunch here at PF. I hope you have seen the http://www.quantumdream.net at my website, my greatest accomplishment in mathematics.
LB
Hurkyl
Staff Emeritus
It's the LaTeX. It makes one look smarter. :smile:
I'm relatively fresh out of school, actually. I got my BS's in math and computer science two years ago, and started work this January. I've been hired as a mathematician, but my work thus far has been leaning more towards the programming.
However, math has been my hobby since I was little, so I have experienced a lot more than these credentials would suggest.
Sorry.
But is this right then?
2p - 1 = p
2 - 1
4 - 1
8 - 1
32 - 1
128 - 1
2048 - 1
Am I wrong?
Sariaht
357
p*p
A multiple between two primes is always right in the middle of two primes.
1, 2*1, 3, 2*2, 5, 2*3, 7, /, 3*3, 2*5, 11, /, 13 etc.
3*3 is right in the middle of 7 and 11
2*5 is right in the middle of 7 and 13
etc.
(11*3 is right in the middle of 37 and 29)
Erik-Olof Wallman
HallsofIvy
43,021
970
2<sup>p</sup> - 1 = p
2 - 1
4 - 1
8 - 1
32 - 1
128 - 1
2048 - 1
Am I wrong?
?? Yes, "2<sup>p</sup>-1= p" is wrong. In fact, the example you give show that :
4-1= 2<sup>2</sup>-1= 2 NOT 2.
8-1= 2<sup>3</sup>-1= 7 NOT 3, etc.
What exactly did you intend to say?
suyver
248
I think he means to suggest that for every p, 2p-1 is a prime number? These are the so-called Mersenne-numbers and not all of them are prime. Although the largest prime numbers found to date are typically Mersenne-numbers, not every p generates a prime number. Simplest example: 211-1 is composite (23*89).
Sariaht
357
Originally posted by suyver
That's what I, eh, he ment.
Best wishes Erik-Olof Wallman!
Loren Booda
3,119
I had never seen that before
suyver
248
The Mersenne-numbers are very interesting because of the so-called Lucas-Lehmer Test, which is a (relatively) easy method of deciding if any Mersenne-number is prime or composite.
Sariaht
357
p1 = 1
p2 = 2
p3 = 3
p4 = 5
p5 = 7
p6 = 11
All numbers within the serie:
p1*p2*p3*p4*...*pn +/- 1 are primenumbers.
In this serie, pn can be raised to all primenumbers between 1 and p; the serie will still be giving primes.
All primes, that in the serie are raised to zero, multiplied with eachother becomes the degree of conjugative.
I can prove that this equation is new:
p1*p2*p3*p4*...*pn = ( can't we call it p?, when n! = 1*2*3*...*n ? ).
It's to good to be old!
suyver
248
Two observations:
1) The smallest prime number is 2, not 1.
2) p1*p2*p3*p4*p5*p6*p7 = 2*3*5*7*11*13*17 = 510510
510510 - 1 = 510509 = 8369 * 61
Sorry, but if things were so simple...
Sariaht
357
I'm sorry
Sorry, but if things were so simple... [/B]
I'm sorry. Thanks anyway. but... wait.. 510 510 is a double query.
Maybe it don't work on them? THANX!!
by the way, 510 is 11111110 binary.
Maybe both sides don't have to be primes either? Or?
Sariaht
357
The smallest primenumber is one.
That's not true, though.
1 is the smallest primenumber.
Hurkyl
Staff Emeritus
1 is not a prime number.
Sariaht
357
förlåt mig. I Sverige säger vi:
Primtal är alla tal som bara är delbara med 1 och sig självt.
sorry. In Sweden we say:
Primes are all numbers that you only can divide with 1 and itself.
1/1 = 1
1/1 = 1
suyver
248
Originally posted by Sariaht
In Sweden we say:
Primes are all number that you only can divide with 1 and itself.
This may be the case, but that is not the normally accepted definition of a prime number. Normally the smallest prime number is said to be 2...
Sariaht
357
What about the equation?
What is your definition of a prime?
suyver
248
That makes no difference of course: 1*x = x for all x. So including your p1=1 doesn't change the fact that your equation is incorrect...
The commonly accepted definition for a prime number is any number having no factor except itself and one. From this rule it follows that 1 is not a prime number, but 2 is.
Sariaht
357
2*3 = 6 | +/- 1 | 5, 7
2*3*5 = 30 | +/- 1 | 29, 31
2*2*3 = 12 | +/- 1 | 11, 13
2*3*3 = 18 | +/- 1 | 17, 19
2*3*5*5 = 150 | +/- 1 | 149, 151
2*3*5*7*7 = 1470 | +/- 1 | 1469, 1471
allright.
Only one primesquare is aloud.
3*5*7*7 = 735 | +/- 2 | 733, 737
3*5*5*7 = 525 | +/- 2 | 523, 527
3*3*5*7 = 315 | +/- 2 | 313, 317
5*7*11 = 385 | +/- 2*3 | 379, 391
7*7 = 49 | +/- 30 | 19, 79
etc?
suyver
248
2*3 = 6 5 7
2*3*5 = 30 29 31
2*2*3 = 12 11 13
2*3*3 = 18 17 19
2*3*5*5 = 150 149 151
2*3*5*7*7 = 1470 1469 1471
allright.
You should really learn to write your ideas (or whatever they are) more clearly. I have NO IDEA what you are trying to say....
Sariaht
357
Were does my equation error?
suyver
248
The prime numbers have a RANDOM distribution over the natural numbers. You will not succeed in finding such an (easy or not) algorithm to always generate a new prime number from a set of already known ones. However, the numbers tend to become large, making it difficult to see that they are not prime.
If you find a simple algorithm and PROVE that this algorithm works for at least the first 100 prime numbers, then I will look at it again. But like this it's becomming a waste of my time: you're just guessing new algorithms without any idea about why they should work in the first place...
  • #31
Sariaht
357
(uip = un-included prime in serie)
Yes. I'll check. Sorry... (only one square is aloud).
No prime is aloud to have a negative conjugate.
.................................uip.(pp)...prime or square
2........................= 2.....+-1............1 | 3
3........................= 3.....+-2............1 | 5
2*2......................= 4.....+-1............3 | 5
2*3......................= 6.....+-1............5 | 7
2*3*3....................= 18....+-1...........17 | 19
3*3......................= 9.....+-2............7 | 11
2*2*3....................= 12....+-1...........11 | 13
2*5......................= 10....+-3............7 | 13
3*5......................= 15....+-2...........13 | 17
3*5*7....................= 105...+-2..........103 | 107
2*3*7....................= 42....+-5...........37 | 47
5*7*7....................= 245...+-6..........239 | 251
3*7*7....................= 147...+-10.........137 | 157
2*7*7....................= 98....+-15..........83 | 113
2*5*7....................= 70....+-3...........67 | 73
5*5*7 ..................= 175...+-6..169(square) | 181
5*7......................= 35....+-6...........29 | 41
2*3*5*7*11...............= 2310..+-1.........2309 | 2311
The numbers in the serie must be a prime (3 5 7 11 are four numbers)
2*5*11...................= 110...+-21..........89 | 131
5*7*11...................= 385...+-6..........379 | 391
3*7*11...................= 231...+-10....17*13(?) | 241
(maybe this has got something to do with that diff (3,7) = diff (7,11)
is not a prime, and that diff(x,y) cannot be a non-prime twice in a row?)
3*5*11...................= 165...+-14.........151 | 179
11*5.....................= 55....+-42..........13 | 97
Damit... Who cares if it works anyway: the permutations becomes to many.
  • #32
Sariaht
357
In the middle of two conjugative primes is a third number oftenly divideable
with 6.
Can two such queries have the same factor-sum if the sum is a prime?
2*2 = 4 | 2 + 2 = 4
2*3 = 6 | 2 + 3 = 5
2*2*3 = 12 | 2 + 2 + 3 = 7
2*3*3 = 18 | 2 + 3 + 3 = 8
2*3*5 = 30 | 2 + 3 + 5 = 10
2*3*7 = 42 | 2 + 7 + 3 = 12
2*2*3*5 = 60 | 2 + 2 + 3 + 5 = 12
  • #33
suyver
248
  • #34
Sariaht
357
Have you read this thread? You might find some of the contents interesting...
No, i have not read his thread. What does he mean?
But if this was true, you could find alot higher primes alot easier.
  • #35
suyver
248
No: this is indeed a function that generates all the primes. But it is a function with 26 parameters that can vary.... Computationally very intensive!
Suggested for: New prime series?
  • Last Post
  • Last Post
  • Last Post
