New study about the rise in global sea levels
In summary, the study found that if the world continues on the current path, sea levels will rise by 2 meters by the year 2100. This could result in the displacement of up to 187 million people, loss of food production in critical regions, and the displacement of salt marsh wildlife.
  • #36
Before i panicked i'd have to go back and check all the 20th century data to see whether it is based on the 1929 or the 1988 sea level datum and if it's all been adjusted to the latter or did the computer plots just smooth out the step change.
https://www.ngs.noaa.gov/datums/vertical/national-geodetic-vertical-datum-1929.shtmlhttps://www.ngs.noaa.gov/datums/vertical/north-american-vertical-datum-1988.shtml
I started that exercise once but gave up when i read that around the US gulf coast much of apparent water level rise is due instead to land sinking.
I decided geophysics is not my area of expertise
so now i just dismiss anything related to climate that i sense is trying to arouse my emotions. old jm
Likes davenn, Evo and Bystander
  • #37
Something that was noted in times past, but the Mississippi delta and the surrounding coastlines have been dropping due to oil extraction for over a century and was rather well documented and pegged to the volume of oil pumped. And places like Jakarta they are having a constant, losing battle to loss of land due to fresh water extraction.
Likes jim hardy and Evo
  • #38
NTL2009 said:
It was surprising to me that it seems within the realm of possibility that ~ 40% of sea level rise is related to human water use, rather than global warming. Yet, we don't seem to hear of that, or actions to take?
There is a review with a different conclusion here: https://link.springer.com/content/pdf/10.1007/s10712-016-9399-6.pdf
It seems that the study from Pokhrel et al. is overestimating greatly the contribution from water use.
Evo said:
To the OP - We humans need to understand that as we come out of the last ice age that melting will continue . Human activity may be accelerating what would happen anyway.
Actually, the Holocene temperatures are cooling for 6'000 years. See the following papers:
Pacific Ocean Heat Content During the Past 10,000 Years
Moderator edit: link replaced - original link is copyright violation of paper behind paywall.
Use this link if you have access
https://science.sciencemag.org/content/342/6158/617
Deep Heating
Global warming is popularly viewed only as an atmospheric process, when, as shown by marine temperature records covering the last several decades, most heat uptake occurs in the ocean. How did subsurface ocean temperatures vary during past warm and cold intervals? Rosenthal et al. (p. 617) present a temperature record of western equatorial Pacific subsurface and intermediate water masses over the past 10,000 years that shows that heat content varied in step with both northern and southern high-latitude oceans. The findings support the view that the Holocene Thermal Maximum, the Medieval Warm Period, and the Little Ice Age were global events, and they provide a long-term perspective for evaluating the role of ocean heat content in various warming scenarios for the future.
Abstract
Observed increases in ocean heat content (OHC) and temperature are robust indicators of global warming during the past several decades. We used high-resolution proxy records from sediment cores to extend these observations in the Pacific 10,000 years beyond the instrumental record. We show that water masses linked to North Pacific and Antarctic intermediate waters were warmer by 2.1 ± 0.4°C and 1.5 ± 0.4°C, respectively, during the middle Holocene Thermal Maximum than over the past century. Both water masses were ~0.9°C warmer during the Medieval Warm period than during the Little Ice Age and ~0.65° warmer than in recent decades. Although documented changes in global surface temperatures during the Holocene and Common era are relatively small, the concomitant changes in OHC are large.
A Reconstruction of Regional and Global Temperature for the Past 11,300 Years
https://science.sciencemag.org/content/339/6124/1198.full
StandardsGuy said:
Forecasts have been very wrong before. Instead of panicking about a forecast, please provide some data that shows how much change there has been in the last 50 or 100 years. Be sure to provide data that has uncertainties, so that we all can evaluate the situation together.
There is an article by professor Clint Conrad on the European Geosciences Union's blogs about the accuracy of the previous forecast. Here the link:
How good were the old forecasts of sea level rise?
https://blogs.egu.eu/divisions/gd/2017/09/13/modern-day-sea-level-rise/
Likes lomidrevo and Bandersnatch
  • #39
Most of our historic cities are built near the Sea as transport of goods relied on shipping. Movement of goods from ships to the population centers is trivial if the ports if next to the city. Imagine hundred of years ago trying to move enough goods for a city of 1 millions people any distance.
In this day an age we still rely mostly on shipping but there is nothing stopping us building on higher ground just having our ports at sea level as transportation by road/rail back to the population centers is a trivial concern and easily achievable.
Opinion: Sea levels continue to vary, even without human inteference we will eventually have another Ice Age and another period where all the Ice melts. There is no point in trying to fight nature as we can't win, the best we can do is plan around it so that we are less affected when not if that change occurs.
Likes Evo and Steelwolf
  • #40
Not every country has higher ground to retreat to !
And so by your way, all/many of the existing ports become unusable and zillions of $$ rebuilding
new infrastructure that no one ( very few) can really afford to do
Likes fresh_42
  • #41
I don't think it is the question the humanity is facing. Climate change and sea level rise will happen anyway (and is happening now), the question is more about how far we should go in the increasing of the phenomenon. Basically we have simply the control of the thermostat and our decisions will define the temperatures of the next decades and centuries.
Likes lomidrevo and russ_watters
  • #42
Ok, I don't want to get involved in this thread, but seriously, there is something that needs to be said here, if it hasn't already. Sea level rise is not the same everywhere, it actually can lower in some areas.
Regional effects cause sea levels to increase on some parts of the planet, decrease on others, and even to remain relatively flat in a few places, including, in recent decades, on the California coast.
https://sealevel.nasa.gov/understanding-sea-level/overview
On the misnomer of "global" sea level rise.
Understanding trends in sea level, as well as the relationship between global and local sea level, provides critical information about the impacts of the Earth's climate on our ocean and atmosphere. The image above shows sea level change since 1993 and demonstrates the variation globally.Most people are surprised to learn that, just as the surface of the Earth is not flat, the surface of the ocean is not flat, and that the surface of the sea changes at different rates around the globe. For instance, the absolute water level height is higher along the West Coast of the United States than the East Coast.
You may have heard the term “global sea level,” which refers to the average height of all of the Earth's ocean basins. "Global sea level rise" refers to the increase in the average global sea level trend.
"Local sea level" refers to the height of the water measured along the coast relative to a specific point on land. Tide stations measure local sea level. "Relative sea level trends" reflect changes in local sea level over time. This relative change is the one most critical for many coastal applications, including coastal mapping, marine boundary delineation, coastal zone management, coastal engineering, sustainable habitat restoration design, and the general public enjoying their favorite beach.
https://oceanservice.noaa.gov/facts/globalsl.html
Likes jim hardy, Rive, davenn and 1 other person
  • #43
I was not suggesting that we actively try and relocate everyone, as rightly stated the cost would be stratastophic. Merely that going forward we plan accordingly. Climate change is a global challenge that needs a global response from humanity as a whole. We are all currently silo'd into our own countries and that just does not work for this challenge.
  • #44
Yes sure. It is the same problem than the temperature, regional changes are different than global change in average. This is why you need to look at the whole picture, with global data.
"Sea-level data since 1994, taken by the TOPEX and JASON missions, reveal complex changes in sea level that vary across the globe — but the overall trend is a strong increase."
https://www.space.com/30379-nasa-sea-level-rise-model-video.html
Here the visualization from NASA: https://svs.gsfc.nasa.gov/11927
Likes lomidrevo, Rive and Bandersnatch
  • #46
If you mean we ultimately can't control the climate on a geological time scale, sure, but we are proving we can control it (currently to our detrement) on a generational scale.
And on a day-to-day scale I'd say we spend the majority of our time and resources fighting nature and mostly winning.
Likes lomidrevo, Rive, Genava and 3 others
  • #47
The main point is that rapid climate changes that we can observe recently are almost surely driven by human activities, and there is a consensus about that in scientific community, see this article:
Multiple studies published in peer-reviewed scientific journals show that 97 percent or more of actively publishing climate scientists agree: Climate-warming trends over the past century are extremely likely due to human activities.
So the current situation is not about "trying to fight nature". It is the mess that we ourselves have produced that we should fight against. The best we can do (for beginning), is to reduce the emissions of greenhouse gasses (mainly CO2), but we are constantly failing in this task: https://www.iea.org/geco/emissions/
Likes russ_watters and BillTre
  • #48
To clarify, I was not suggesting the current climate issue are not human induced, neither am I stating that we shouldn't try to reduce our impact as much as possible.
I am saying we should start planning for life away from the coasts in addition to doing everything we can to try and reduce human related warming.
Cities have lifespans in the thousands of years. We now have the technology and foresight to appreciate what might happen in those timescales, why not plan accordingly for the long term future?
  • #49
It is quite trivial that we need to adapt to the changed climate. However, living away from the coasts would include abandoning entire countries. Nobody knows if something like that is possible at all and if yes, how it would impact the rest of the world. At least Netherland prefers to flee forward and supports floating cities instead.
  • #50
He who evokes Star Trek in a serious discussion loses.
But...
This discussion smells exactly like ONE Vulcan displaying "intellectual superiority" before a LARGE group of "irrational humans". Not in 'real life', but on TV. FICTIONAL. And not because it makes sense, but in order to illustrate the difference between humans and Vulcans, who understand (sorry, ran out of scare quotes) everything yet seem to care about nothing. Except intellectual superiority. And not because there is any truth behind or reason for it, but rather, as a plot device intended to piss the audience off. I had no idea this forum prohibited discussion of the existential crisis of our times, not nuclear war, no ==> global warming <==. And why? Because ===> it's political <===. As existential crises tend to be...
Oh, for christs sake. (swear, not prayer). I would like a clear headed, Vulcan style explanation of how we are going to solve problems we are not permitted to discuss.
Thank you.
  • #51
Discuss? Not here. It degrades into a flame war. In the prevention of that problem - thread closed. This my job here. PF discussions are based on respectable journal papers and textbooks. Thanks.
Likes jim hardy
  • #52
jim mcnamara said:
. . . thread closed. This my job here.
Well, where is the. . . ?
Likes davenn and BillTre
  • #53
Right here, thank you for noticing. Got rerouted to another problem before I did what I should have done :)
Likes davenn
<h2>1. What is the cause of the rise in global sea levels?</h2><p>The rise in global sea levels is primarily caused by the melting of glaciers and ice sheets, as well as the thermal expansion of seawater due to increasing global temperatures. Human activities such as burning fossil fuels and deforestation also contribute to the rise in sea levels.</p><h2>2. How much have global sea levels risen in recent years?</h2><p>According to the latest research, global sea levels have risen by approximately 8 inches (20 cm) since 1880. However, the rate of rise has been accelerating in recent decades, with an average increase of 0.13 inches (3.2 mm) per year since 1993.</p><h2>3. What are the potential impacts of rising sea levels?</h2><p>Rising sea levels can have a range of impacts, including coastal flooding, erosion, and saltwater intrusion into freshwater sources. It can also lead to the displacement of coastal communities and damage to infrastructure and ecosystems.</p><h2>4. Are there any regions that are more vulnerable to the effects of rising sea levels?</h2><p>Low-lying coastal areas, small island nations, and delta regions are particularly vulnerable to the impacts of rising sea levels. These regions are already experiencing increased flooding and erosion, and are at risk of being completely submerged if sea levels continue to rise.</p><h2>5. What can be done to mitigate the effects of rising sea levels?</h2><p>To mitigate the effects of rising sea levels, it is crucial to reduce greenhouse gas emissions and limit global warming. This can be achieved through transitioning to renewable energy sources, reducing carbon emissions, and implementing sustainable land-use practices. Additionally, coastal communities can implement adaptation strategies such as building sea walls and elevating infrastructure to protect against flooding.</p>
  • Earth Sciences
  • Earth Sciences
27K
13K
  • Earth Sciences
Writing: Input Wanted Great Lakes Earth Map
