Newton laws
  • Thread starter ashvuck101
A landing craft of mass 12,000 kg prepares itself for a Moon landing. When at a
vertical distance 160m above the Moon’s surface it’s downwards velocity is 15 m/s.
A retrorocket is fired to give the craft an upward thrust to slow its speed to zero as it
meets the surface. Calculate the needed thrust to decelerate the craft its initial
downwards velocity to zero as it lands. The value for gravity on the Moon is g/6.
(Where g is 9.81m/s2).
f=ma
Gravity =9.81/6
=1.635
F (craft)= ma
=12 000. 1.635
=19620
Therefore the craft will need a a thrust of 19620 N upwards. Is that right or is that other information needed??
Answers and Replies
117
No that is not right. That upward thrust of 19620N merely counteracts the gravitational force acting on the landing craft. As such, there will be no net force on the craft, and it will continue moving downwards at a constant velocity of 15m/s.
In order to decelerate the craft, you are going to need a net upwards force acting on the craft. Based on the information in the question, what is the magnitude of the upward acceleration that the craft must undergo?
ok...but i cant calculate an upward force without, Acceleration im only given constant velocity?? which means there is no acceleration
ideasrule
2,271
There has to be an acceleration for the craft's velocity to reduce to 0 m/s from 15 m/s. I think you should start by calculating the acceleration required to bring the craft's velocity down by 15 m/s in the given distance.
ok i did that and got -0.703125 as acceleration
then i got a force of -8437.5 N
so the craft needs a downward force of 8437.5N to come to 0 m/s??? is it downward or upward??
Related Threads on Newton laws
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
