Newton theory of gravity
  • Thread starter fredrick08
fredrick08
376
[SOLVED] Newton theory of gravity
what are the magnitude and direction of the net gravitational force on the 20kg mass.
Now this is kinda tricky but there is an 20kg ball on the origin, and two 10kg balls 20cm above the x axis, and one is 5cm right and the other is 5cm left of the y axis.
F=GMm/R^2
G=6.67x10^-11
F(on m1)=F(m2 on m1)+F(m3 on m1)
F(m2 on m1)=GMm/R^2=(6.67x10^-11*20*10)/0.2^2=3x10^-7jN
F(m3 on m1)=" "=" "=" ' "
Thus F(on m1)=3x10^-7j+3x10^-7j=6.67x10^-7jN
Now i thought this question was kinda straight forward, but in the answers in the book the answer is 3x10^-7jN, half of what i got... and i don't know where i went wrong, can someone please help me?
Answers and Replies
fredrick08
376
anyone have any idea? i know that -.05i and .05i cancel out, but maybe do you double the .2j value?
malawi_glenn
2022 Award
6,196
1,687
Please wait a bit more. One hour is nothing.
the majority of PF users are sleeping at the moment, so please wait.
Also, this is NOT advanced physics..
tiny-tim
25,838
256
Hi fredrick08! :smile:
Yes, it is straightforward … but not if you don't draw a proper diagram, and label it carefully. :rolleyes:
R isn't .02, is it?
Use Pythagoras, and try again! :smile:
fredrick08
376
yes, i tried pythagoras, but then your r values would be, -.05i+.2j and .05i+.2j, which would give a magnitude of sqrt(.05^2+.2^)=.206m, but i don't understand why you would use pythagoras since the 2 10kg balls, is the same as one 20kg ball... since the i cancel out? and even if you use this u still get
F(on m1)=(6.67x10^-11*20*20)/.2^2=6.67x10^-7? how do they half that value?
im srry tiny-tim, but i don't see how R can be anything else but R=0.2m... if its not could you please show me why??
fredrick08
376
hey, and anyone tell me how to paste pictures in the thread? do i need to upload it the net or something? i can't just give the directory of the file on my comp??
tiny-tim
25,838
256
yes … but i don't understand why you would use pythagoras since the 2 10kg balls, is the same as one 20kg ball... since the i cancel out? …
ok, you obviously did draw a diagram … my apologies! :redface:
But you're trying to make physics too simple … and unfortunately it isn't! :frown:
Think of the gravitation force as a vector along the hypotenuse.
(Force always is a vector, of course.)
Then that force is equal to the sum of two forces along the two sides, isn't it?
The x-direction forces are opposite, so they cancel.
It is only the y-direction forces which add up! :smile:
But the value of each y-direction force has to be calculated using R for the hypotenuse direction.
Use .206m for R, but then only use the j component of the result.
I think you have to upload onto something like photobucket, and then quote the url (leaving out the http://) [Broken].
fredrick08
376
ok, well if i understand you correctly...
F(m2 on m1)=6.67x10^-11*20*10/.206^2=3.14x10^-7? but then if you multiply that by 2, well i dunno... srry
have you tried doing it yourself? did it work out? i will try and upload a picture, in case I am giving you the wrong picture.
fredrick08
376
i did a similar problem in class, but that was with m1 and m2 had different i and j values. where you added the component vectors, and then did pythag to find the resultant magnitude... but this one has just confused me, coz it looks simple.. but somehow not as i thought...
fredrick08
376
btw, thanks everyone who has helped, very much appreciated = )
fredrick08
376
heres a pic hope it works = )
tiny-tim
25,838
256
nice pic!
erm … yes, I have tried it, and I can't make it 3x10^-7.
mystery … :confused:
fredrick08
376
did u get my answer? or is it possible that the book is wrong? i might ask tomoz at uni... thanks heaps anyways = )
Nick89
555
I'll give it a go:
From the symmetry of the problem we can see directly that the net force on the 20 kg ball will be in the y direction.
Also, the force will be exactly twice the y-component of the force of one ball.
The distance between one of the 10kg balls and the 20kg ball is according to pythagoras:
[tex] r= \sqrt{0.2^2 + 0.05^2} = 0.206 m[/tex]
The angle between the line from one of the 10kg balls and the 20 kg balls and the y-axis is:
[tex]\phi = \arcsin \frac{0.05}{0.2} = 0.25 rad[/tex]
Now, the force, directed along the line between the two balls (note that it therefor has both an x and y component) is given by:
[tex]F = G \frac{m_1 m_2}{r^2} = 6.67 \times 10^{-11} \frac{200}{0.206^2} = 3.14 \times 10^{-7}[/tex]
The y-component of this force can be calculated using the angle in the right triangle that is created by this force vector and the y-axis:
[tex]F_y = F \cos \phi = 3.14 \times 10^{-7} \cos(0.25 rad) = 3.04 \times 10^{-7}[/tex]
The force by both balls (in the y-direction) will ofcourse be just twice this:
[tex]F_{total} = 6.08 \times 10^{-7}[/tex]
I hope I didn't make any mistakes but it's definitely not 3 *10^-7...
fredrick08
376
oh ok i see... thanks nick, i didnt realize that there was still x and y components... i gunna ask today anyways, knowing my physics course, they prob got the wrong answer from the book lol.
Nick89
555
No, the net force is ONLY in the y-direction!
The force of only one of the 10kg balls (acting on the 20kg ball) has a x and y direction.
However, the x-component of the force of one ball will be exactly the same as the x-component of the force of the other ball, but in the opposite direction, and the effects of these two forces will therefore cancel out.
fredrick08
376
yes that's what i meant to say... srry, but thanks for your help = )
fredrick08
376
can anyone explain to me why nick used Fy=FCos(theta) because isn't sin(theta) in the y direction?
jimvoit
70
Here is an approach that appears to give the answer in the book. It’s a bit brute force but it works for a more general case also.
The position vectors p1 and p2 from the 20 kg mass m3 to the 10 kg masses m1 and m2 are:
p1=-0.05 i+0.20 j p2=+0.05 i+0.20 j
Their magnitudes are:
r1=√(p1.p1) r2=√(p2.p2) where the period indicates the dot product.
The values of the gravitational field at mass m3 (20 kg) due to the masses m1 and m2 (10 kg) are:
g1= (g m1 m2)/〖r1〗^2 g2=(g m1 m2)/〖r2〗^2
The net vector result of the field due to m1 and m2 is:
g1 p1/r1+g2 p2/r2
Note that p1/r1 and p2/r2 are unit vectors
The answer obtained in this way is 0 i +3.05 〖x 10〗^(-7) j
jimvoit
70
Sum of field vectors
g1= (g m1 m2)/〖r1〗^2 g2= (g m1 m2)/〖r2〗^2
g1 p1/r1+g2 p2/r2
The answer obtained in this way is 0 i+3.05 〖x 10〗^(-7) j
PS. The key idea here is to set up the two field vectors by multiplying the magnitude of the field by a unit vector in the direction of the field, then adding the vectors to get the resultant.
fredrick08
376
hi everyone, I am still going at it, the lecturer said today that along the line of wat nick said... but I am still not 100% sure my new effort is
for 1 ball.
r=pythag of .05 and .2= .206
and theta equal arctan(.05/.2)=.25rad
F(on m3)=(2GMm/r^2)*Cos(theta) or F(on m3)=2GMm/(r^2*Cos(theta))
this is wat the lecturer give me the impression how it was meant to be done?? can anyone make any sense of what he has tried to do?
fredrick08
376
btw my lecturer also said that the answer in the book 3x10^7jN was wrong by a factor of 2... what ever that means...
fredrick08
376
ive been trying for so many hours and i think what nick did on page 1, is what the lecturer told me to do... can anyone concur that this is correct?
jimvoit
70
Common Error
I believe I managed to get the same result as the book by making the same error..That is by computing the forces between the wrong masses.
tiny-tim
25,838
256
I don't think much of your teacher … telling you the book answer is wrong after you've had all the worry. :mad:
It's arguable whether putting answers in the book at all is a good idea … but it's definitely bad to put the wrong answers in, or to leave them with you without telling you! :mad:
Yes … Nick89's method is the right one. :smile:
The only difference I'd make is that you needn't find the angle to find its cosine … cos = adjacent/hypotenuse, so it's just 0.05/0.206 :smile:
fredrick08
376
ok tiny tim, can i just ask why cosine(.05/.206) instead of cosine(.2/.206) coz isn't .2 the adj, 0.05 the opp and .206 the hyp?
tiny-tim
25,838
256
oops!
ooh yes … you're right … :smile:
:redface: I didn't check the diagram! :redface:
fredrick08
376
ok well I am just gunna call it solved. my final answer is
F(on m1)=(2GMm/r^2)Cos(theta)jN
=(2*6.67x10^-11*20*10/.206^2)Cos(.2/.206)=3.55x10^-7jN!
thanks everyone for your help very much appreciated, i don't really care if its right or wrong now, way too much effort has gone into this question lol = )
Suggested for: Newton theory of gravity
  • Last Post
  • Last Post
  • Last Post
  • Last Post
