Newtonian Limit in G.R.: Differences Explained
In summary, according to Sean Carroll’s Lecture Notes on General Relativity, the Newtonian limit is obtained when g_{00} = -(1+2\phi), and in Schutz’s “A first course in General Relativity”, an additional requirement is put, stating that g_{11} = g_{22} = g_{33} = (1+2\phi). This additional requirement is for completeness, although the spatial components of the metric are not needed to recover the Newtonian equations of motion. Both metrics are correct Newtonian limits and are not separate things, as the spatial components drop out of the equations of motion when close to \delta_{ij}.
hellfire
According to Sean Carroll’s Lecture Notes on General Relativity, equation (4.20) and text below, the Newtonian limit is obtained when [itex]g_{00} = -(1+2\phi)[/itex]. However, in Schutz’s “A first course in General Relativity” it is additionally required that [itex]g_{11} = g_{22} = g_{33} = (1+2\phi)[/itex]. I do not understand the need for this. Are both metrics a correct Newtonian limit? Why does Schutz put this additional requirement?
To be complete. But the spatial components of the metric aren't needed to recover the Newtonian equations of motion. Look at the geodesic equation for objects moving at slow speeds.
Thanks Stingray. So both are correct Newtonian limits. What do you mean with "to be complete"?
I mean that the "Newtonian metric" satisfies both of those conditions. They are not separate things. It's just that the spatial components happen to drop out of the equations of motion as long as they're close to [tex]\delta_{ij}[/tex].
1. What is the Newtonian Limit in General Relativity?
The Newtonian Limit in General Relativity (G.R.) refers to the situation where the predictions made by G.R. closely resemble those made by Newtonian mechanics. It is a special case that arises when the gravitational field is weak and the velocities of objects are much smaller than the speed of light.
2. How is the Newtonian Limit different from Newtonian mechanics?
The main difference between the Newtonian Limit in G.R. and Newtonian mechanics is that G.R. takes into account the curvature of space-time caused by massive objects, while Newtonian mechanics assumes a flat space-time. G.R. also predicts a smaller value for the force of gravity compared to Newtonian mechanics.
3. Can you explain the concept of "differences" in the Newtonian Limit in G.R.?
The main differences in the Newtonian Limit in G.R. arise due to the fact that G.R. treats gravity as a curvature in space-time, while Newtonian mechanics treats it as a force between masses. This leads to differences in the predictions of the two theories, particularly in extreme cases such as near black holes or at high speeds.
4. How does the Newtonian Limit in G.R. relate to Einstein's theory of relativity?
The Newtonian Limit in G.R. is a special case of Einstein's theory of relativity. It is a simplified version that can be used to explain the behavior of objects in weak gravitational fields and at low velocities. In the more general theory of relativity, the effects of gravity on space-time are taken into account, leading to more accurate predictions.
5. What are the practical applications of understanding the Newtonian Limit in G.R.?
Understanding the Newtonian Limit in G.R. is important for many practical applications, such as predicting the orbits of planets and satellites, calculating the effects of gravity on GPS systems, and understanding the behavior of objects near massive bodies like black holes. It also helps to bridge the gap between classical mechanics and the more advanced theory of relativity.
