Newtonian motion
  • Thread starter Ab17
Ab17
99
1. The problem statement, all variables and given/known
You are playing with your daugther in the snow. She sits on a sled and asks you to slide her across a flat , horizontal field. You have a choice of (a) pushing her from behind by applying a force downward on her shoulders at 30 degrees below the horizontal (b) attaching a rope to the front of the sled and pulling with a force 30 degrees above the horizontal. Which would be easier for you and why
2. Homework Equations
F =ma
I think both situations yield the same net force thus the same acceleration
Answers and Replies
13,161
Consider the case where the sled has a constant velocity. Do you still need a force to keep it moving? What about that effect (it is also relevant while still accelerating)?
Ab17
99
Both options are not in constant velocity. Both options have one force in the horizontal direction
13,161
It does not matter.
There is an effect you missed so far. The force won't all be used for acceleration. There is something else to consider.
Hint: it is snow, not ice.
Ab17
99
Friction
13,161
Correct. How do you calculate the friction force? Does pushing/pulling at an angle change it?
Ab17
99
I think for both cases it will be -Fcos@
13,161
What is F, and where does the sign come from, and in which direction?
Ab17
99
F is the applied force
Ab17
99
The sign is a mistake
nrqed
295
I think that what mfb wants to make you think about is the definition of the friction force. What is the fundamental equation that gives the kinetic friction force on a sliding object?
Ab17
99
Fk = ukN
nrqed
295
Fk = ukN
Right. So what can we say about the normal force in the first case compared to the second case?
Ab17
99
It has a component in one case?
13,161
What does "it has a component" mean? All forces can always be split into separate components. But where do those components point to?
Ab17
99
I mean the force is at an angle so it will result in a horizontal and vertical comp.. but the thing is both forces are at angles. But the components of both forces have different direction
Ab17
99
Are you trying to point that?
13,161
Right.
So what is your conclusion?
Ab17
99
The y comp of first case will be up while down in second case...so maybe more friction in second case? Is that right
13,161
The second case is you pulling up. You expect more force on the ground there?
Ab17
99
The case in which you push
Ab17
99
There will be a higher normal force...but that doesn't make sense because the will be a higher normal for force in the other case too as Efy=O
13,161
What is Efy?
If you push, you have a higher normal force, correct. This leads to larger friction.
If you pull upwards (at an angle), you reduce the normal force.
Ab17
99
Sum of forces in the y direction
Suggested for: Newtonian motion
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
