Newton's 2nd Law Problem: Finding Force and Direction of Travel
In summary, using the given decoupled position functions, the magnitude and angle of the net force on the particle can be calculated using the Pythagorean theorem and trigonometric functions. However, caution must be taken when determining the correct quadrant for the angles due to the signs of the acceleration components.
Jrlinton
134
A 0.25 kg particle moves in an xy plane according to x(t) = -15 + 2t - 4t3 and y(t) = 25 + 7t - 9t2, with x and y in meters and t in seconds. Find formulas at time t<35 sec for the (a) the magnitude and (b) the angle (relative to the positive direction of the x axis) of the net force on the particle (in radians), as well as (c) the angle of the particle's direction of travel (in radians)
F=ma
Pythagorean thereom
Fx=Fcosθ
Fy=Fsinθ
With the x(t) and y(t) being the decoupled position vector, I thought I would use Pythagorean Thereom to come up with the vector r
r=((-4t^3+2t-15)^2+(-9t^2+7t+25)^2)^0.5
r=(16t^6+65t^4-6t^3-397t^2+290t+850)^.5
approximating the square roots for the coeffecients:
r=4t^3+9.06t^2-2.45t^1.5-19.92t+17.03t^0.5+29.15
I have a strong suspicion that I went about this in a very wrong way
As Force=mass*acceleration and the acceleration in each direction is the second derivative of the decoupled position function the acceleration functions would be ax(t)=-24t ay(t)=-18
Making the force function=((576t^2+324)^.5)/4 ?
Yes.
Okay so the angle of the force would then be .25 arctan(-18/-24t) ??
or .25 arctan(3/4t) simplified and the angle of the velocity being arctan(-18t/.12t^2)=arctan(3/2t)
Those last two were incorrect.
Pay attention to the quadrant that the acceleration vector lies in. The arctan function can be a trap when the signs of the x and y components are not both positive. You need to sort out the correct quadrant yourself and adjust the result accordingly.
What is Newton's 2nd Law Problem?
Newton's 2nd Law Problem, also known as the Second Law of Motion, is a fundamental concept in physics that explains the relationship between an object's mass, acceleration, and the applied force. It states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass.
How do you solve Newton's 2nd Law Problem?
To solve a Newton's 2nd Law Problem, you need to follow three steps: 1) Identify the known and unknown variables, including the mass, acceleration, and force; 2) Write out the Second Law equation, F=ma, and plug in the known values; 3) Solve for the unknown variable using basic algebra.
What is the difference between mass and weight in Newton's 2nd Law Problem?
Mass is a measure of an object's inertia, or resistance to change in motion, and is measured in kilograms (kg). Weight is the force exerted on an object by gravity and is measured in newtons (N). In Newton's 2nd Law Problem, the mass of an object is used to calculate its acceleration, while its weight is used to calculate the force acting on it.
Can Newton's 2nd Law Problem be applied to all objects?
Yes, Newton's 2nd Law Problem can be applied to all objects, regardless of their size, shape, or composition. As long as there is a net force acting on the object, it will experience an acceleration that follows the Second Law equation, F=ma.
What are some real-life examples of Newton's 2nd Law Problem?
Some real-life examples of Newton's 2nd Law Problem include a car accelerating on a straight road, a rocket launching into space, a person jumping off a diving board, and a ball being thrown in the air. In each of these scenarios, there is a net force acting on an object, resulting in a change in its motion.
