Newton's 1st Law: Motion & Astronauts
In summary: Earth would stop rotating will the object's on Earth's surface will get "pushed" at a velocity of 1k miles per a second?It's not really clear what you're asking here.
aikawax
Newton's first law states that a body in motion tends to stay in motion and that's why when you're driving a car and then suddenly stop you get pushed at the same speed you were traveling.
the Earth orbits the sun at 64,000 miles and the Earth's rotation is 1000 miles per a hour.
my question is that how come that when astrountes leave Earth they don't get pushed away at a speed of 64,000 miles per a hour.
and the second question is that if theoretically Earth would stop rotating will the object's on Earth's surface will get "pushed" at a velocity of 1k miles per a second?
Science news on Phys.org
Astronauts do move at 64,000mph, but since the Earth is moving with them at 64,000mph, there is no difference. I mean, they would HAVE to move that fast in that direction to keep up.
If Earth suddenly stopped, I'm pretty sure there would be something major going on which would change everything, but if it just happened to, everything on one side would be launched into space, everything on the other would be squished into the ground. If it stopped rotating, everything would go outwards/upwards the same way rotating a bucket filled with water and suddenly stopping would, taking into account the effects of gravity.
"The Shuttle travels about 5 miles per second give or take, which is 26,000 feet per second."
the shuttle actully goes much slower.
5X3600 = 18,000 mph.
and about the Earth rotation , say you're driving at a speed of 100{->} mph with the Earth rotation then if you suddenly come to a stop you will fly at at a speed of 1100 mph { relative to space } , but then again if you go at 100{<-} againts the Earth rotation , and then come to a stop aren't you suppose to get pushed at a velocity of 900 mph <- ?
I don't know what you mean by "pushed at the same speed", but it doesn't work that way. If you're driving along and you suddenly stop the car (by arranging for the ground to push on the tires) you tend to keep going because you are not being pushed. It requires a force to change your motion, that's why you strap yourself in--so the seatbelt can exert a force on you to change your speed so you don't go flying through the windshield. So you're not being pushed forward, it just seems that way because the car is being pushed back.
If you're on the equator, then your speed with respect to the center of the Earth is roughly about 1000 mph. If you're driving along at 100 mph in the direction that the Earth rotates (towards the east), your speed would be 1100 mph with respect to the Earth's center.
If, by some magic, the Earth just suddenly stopped rotating you'd keep going at your speed of 1100 mph until gravity, friction, and collisions began exerting their forces on you and slowed you down.
No, actually it's the opposite way around, gravity would just become a little stronger at the equator. The difference is not really noticeable (about 1% or something). We wouldn't notice any other effect.
opps, we'd only have one day per year. That would be the only really noticeable difference for us.
If Earth stopped orbiting the Sun we'd all fall into the Sun, that's all. There would be no more Christmases, New Years, or summer holidays...
aikawax said:
...when you're driving a car and then suddenly stop you get pushed at the same speed you were traveling.
my question is that how come that when astrountes leave Earth they don't get pushed away at a speed of 64,000 miles per a hour. [emphasis added]
The space shuttle doesn't have brakes! In a car, you get thrown forward (in the car's reference frame) because the car stops. When an astronaut leaves earth, they aren't stopping with respect to the Earth's motion around the sun - that would require a lot of power from their engines.
and about the Earth rotation , say you're driving at a speed of 100{->} mph with the Earth rotation then if you suddenly come to a stop you will fly at at a speed of 1100 mph { relative to space } , but then again if you go at 100{<-} againts the Earth rotation , and then come to a stop aren't you suppose to get pushed at a velocity of 900 mph <- ? [emphasis added]
Stop with respect to what? The only thing your car's brakes and wheels can apply a force on is the ground, so they can only stop with respect to the ground. To stop with respect to an arbitrary outside reference frame would require some other means of applying a force (such as a rocket engine).
YellowTaxi said:
No, actually it's the opposite way around, gravity would just become a little stronger at the equator. The difference is not really noticeable (about 1% or something). We wouldn't notice any other effect..
DST was actually talking about the immediate effect of if the Earth *suddenly* stopped rotating and we didn't. We'd still be moving forward at 1000 miles per hour.
What is Newton's 1st Law of Motion?
Newton's 1st Law of Motion, also known as the Law of Inertia, states that an object at rest will remain at rest and an object in motion will remain in motion at a constant velocity unless acted upon by an external force.
How does Newton's 1st Law apply to astronauts in space?
In space, there is very little resistance or friction to slow down an object's motion. Therefore, an astronaut traveling at a constant speed will continue to do so until acted upon by another force, such as the pull of gravity or the thrust of a rocket.
What are some examples of Newton's 1st Law in space?
One example is how astronauts float inside a space shuttle or space station. Since there is no gravity or other external forces acting upon them, they will remain in motion at a constant velocity until they use a force, such as pushing off a surface, to change their motion.
Another example is how satellites remain in orbit around the Earth. Once they are launched into space, they continue to move at a constant speed without the need for additional propulsion due to the lack of friction and resistance in space.
How does Newton's 1st Law differ from the Law of Universal Gravitation?
While Newton's 1st Law deals with an object's state of motion, the Law of Universal Gravitation explains how objects are attracted to each other due to their mass and distance. It is the force of gravity that acts as the external force to change an object's motion.
How does understanding Newton's 1st Law benefit space exploration?
By understanding Newton's 1st Law, scientists and engineers can design spacecraft and equipment that can withstand the forces of space, such as the lack of gravity and the intense speed and acceleration of space travel. This knowledge also helps astronauts safely navigate and perform tasks in space.
  • Mechanics
  • Classical Physics
  • Classical Physics
  • Thermodynamics
