Calculating Elevator Acceleration and Velocity?
In summary, a student with a weight of 500 Newtons is standing on a scale in an elevator, recording the scale reading as a function of time. The data is shown in a graph, with the elevator starting at displacement x=0 and velocity v=0 at time t=0. The positive directions for displacement, velocity, and acceleration are assumed to be upward. The free body diagram for the student at t=8 shows a normal force going up and mg going down. The acceleration of the elevator is calculated for each 5 second interval, with a value of 0 m/s^2 for 0-5 seconds, 3.92 m/s^2 for 5-10 seconds, 0 m/s^
crhscoog
"A student whose weight is 500 Newtons stands on a scale in an elevator and records the scale reading as a function of time. The data is shown in the graph above. At time t=0, the elevator is at displacement x=0 with velocity v=0. Assume that the positive directions for displacement, velocity, and acceleration are upward.
Graph (scale reading 'Newtons' vs time):
0-5 seconds --> 500 Newtons
5-10 seconds --> 700 Newtons
10-15 seconds --> 500 Newtons
15-20 seconds --> 300 Newtons"
a) Free Body Diagram w/ all forces on the student at t=8
Normal Force going up
mg going down
b) Calculate the acceleration of the elevator for each 5 second interval
0-5s=
0 m/s^2 because force stays the same meaning its at rest since velocity is 0 at 0seconds
5-10s=
fnet=ma
700-500=51a
a= 3.92m/s^2
10-15s=
force is back to 500 meaning constant velocity
a= 0m/s^2
15-20s=
fnet=ma
300-500=51a
a= -3.92 m/s^2
c) It asks for velocity when t= 5,10,15,20
v=at
v=0(5)
v= 0 m/s
v=vi+at
v=0+3.92(5)
v= 19.6 m/s
v=vi+at
v=19.6+0(5)
v=19.6 m/s
v=19.6+(-3.92)(5)
v=0 m/s
Now I have to plot this on a velocity vs time graph so I have it at:
0 velocity from 0-5s
line from (5,0) to (10,19.6).
horizontal line from (10,19.6) to (15,19.6)
line from (15,19.6) to (20,0)
Just want to see if I am doing this right... Thank you.
Just from a quick skim, it looks like you're doing it correctly.
thank you.
1. What is Newton's Law on an elevator?
Newton's Law on an elevator refers to the principles of motion and force described by Sir Isaac Newton, which state that an object in motion will remain in motion unless acted upon by an external force, and that the force applied to an object is equal to its mass multiplied by its acceleration.
2. How does Newton's Law apply to an elevator?
In the context of an elevator, Newton's Law describes the relationship between the force applied to the elevator and the resulting motion of the elevator. When the elevator is at rest, the force of gravity and the force of the elevator's support cancel each other out, resulting in no motion. However, when the elevator accelerates or decelerates, an external force is applied, causing the elevator and its contents to also accelerate or decelerate.
3. What happens to the force on an object in an elevator?
According to Newton's Law, the force on an object in an elevator is equal to its mass multiplied by its acceleration. As the elevator moves, the acceleration changes and therefore the force on the object also changes. When the elevator is moving at a constant speed, the force is equal to the force of gravity pulling the object down. When the elevator accelerates or decelerates, the force changes accordingly.
4. What is the difference between the force in an elevator and on the ground?
The main difference between the force in an elevator and on the ground is the presence of an external force. On the ground, the force of gravity is constantly acting on objects, but there are usually no other external forces affecting their motion. In an elevator, the force of gravity is still present, but it is countered by the force of the elevator's support. When the elevator accelerates or decelerates, an external force is applied, resulting in a change in the object's motion.
5. How does Newton's Law on an elevator relate to everyday experiences?
Newton's Law on an elevator can be seen in everyday experiences, such as riding in an elevator or driving a car. In both cases, when the object (elevator or car) is at rest, there is no motion because the forces are balanced. But when the object accelerates or decelerates, an external force is applied, causing a change in motion. This can also be seen in activities like throwing a ball or riding a rollercoaster, where an external force is applied to change the motion of an object.
